Square Box
elkiehound
Square Box
#1 Post by elkiehound » Sat Jul 09, 2011 12:28 pm
I have successfully created the MKV file and viewing it with VTC on Mac is fine.
Now, I am trying to convert via iSkysoft to AppleTV format, and it only puts it into a 4x3 ratio box. The resolution in the options is 1920x720.
Anyone know how to get this to be 16x9 ?
Smithcraft
Re: Square Box
#2 Post by Smithcraft » Sun Jul 10, 2011 2:25 am
You would have to disable the cropping to get it back to 1920 by 1080.
While I'm not sure, I think the AppleTV only handles 720 files so you would have to scale it down to 1280 by 720.
SC
