Problems with Knights of Sidonia (Movie)
VictorBravoLV1
Post by VictorBravoLV1 »
Hey y'all. I have a problem with one of the Knights of Sidonia discs. The bonuses work fine but it failed to pick up the movie. When I looked up on the logs, I saw this. Is there anything that should be worked around?
004004:10000 The source file '/BDMV/STREAM/00006.m2ts' is corrupt or invalid at offset 6257111040, attempting to work around
005003:0000 Failed to save title 0 to file D:/Video/Knights of Sidonia 21 BD-5/title_t00.mkv
002023:0000 Encountered 7 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
error=0x06031105 count=7 name=Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR
002023:0000 Encountered 150 errors of type 'HashCheck Error' - see http://www.makemkv.com/errors/hashcheck/
error=0x070B0D08 count=150 name=Internal error - M2TS hash check failed (3336)
Encountered 5 unclassified errors
error=0xC000009C count=5 name=OS error - STATUS_DEVICE_DATA_ERROR
I attempted this on the NAS, then to my PC, with the LG WH16NS40 but to no avail.
Re: Problems with Knights of Sidonia (Movie)
Those errors typically mean the optical was unable to correctly read the disc. The standard advice is to gently clean the disc and try again.
