Auto enable / disable audio language
Kizar
Post by Kizar » Sat Nov 18, 2023 9:27 pm
I want to suggest an option, that MakeMKV detect the available audio languages and auto enable / disable the checkboxes by default. For example: I never need a french or spain audio, but I have to manually disable it.
Re: Auto enable / disable audio language
Post by d00zah » Sat Nov 18, 2023 9:38 pm
Kizar wrote: Sat Nov 18, 2023 9:27 pm I want to suggest an option, that MakeMKV detect the available audio languages and auto enable / disable the checkboxes by default. For example: I never need a french or spain audio, but I have to manually disable it.
Like this? :)
Changing default track selection
To expose the 'Advanced' tab (if you haven't already), select MakeMKV's Preferences > General tab & check 'Expert mode'.
Kizar
Post by Kizar » Sun Nov 19, 2023 1:08 pm
I think that is too complicated for a normal user. Why not using checkboxes for this?
Post by d00zah » Sun Nov 19, 2023 1:20 pm
Kizar wrote: Sun Nov 19, 2023 1:08 pm I think that is too complicated for a normal user. Why not using checkboxes for this?
Developer's choice, I imagine. It is considered an 'Advanced' function.
If you described the specific (behavior) languages you prefer, someone might offer some suggestions.
Although it can have other implications (& I haven't experimented w/ this in years), have you tried setting a "Preferred language' on Prefs > Languages tab? I don't recall how this affects default behavior.
