20231117-beta key is not working
jamesevarts3
#1 Post by jamesevarts3 » Sat Nov 18, 2023 3:00 am
the current beta key that is suppose to work until 2023 nov is not working. today is 20231117
Re: 20231117-beta key is not working
#2 Post by Woodstock » Sat Nov 18, 2023 3:46 am
You're referring to the key in the beta message, viewtopic.php?f=5&t=1053 ?
jamesevarts3
#3 Post by jamesevarts3 » Sat Nov 18, 2023 6:19 am
i fixed it, i was stupid....the copy/paste added a "space" at the end, working now
#4 Post by Woodstock » Sat Nov 18, 2023 11:40 pm
Ah, yes... copy/paste has come a long way since when it work-as-designed, and became work-as-if-it-is-braindead...
I've started doing copy/paste-to-Notepad/copy-again/paste-where-it-is-needed. Then you don't get formatting commands embedded in with the text, as well. It helps avoid converting to "[use font COURIER 12-point]string of characters[/font]".
