Finding Nemo (WS)
bugdude
Finding Nemo (WS)
#1 Post by bugdude » Fri Nov 17, 2023 2:36 pm
All,
I have tried all I can think of to get this DVD converted with no success after trying an HP sata drive, and older LG slim multi DVD and an older LG slim multi bluray. Since I was using using older drives I went out and bought a new LG slim external drive, but it also failed.. Tried each of the protection removal models manually and they all failed. Bought another copy of the DVD and it also failed. Tried manually opening only the main title "1" and that also failed. Noticed my new drive was Libredrive supported so I flashed the drive firmware with libredrive and tried the whole sequence again and it also failed.. Noticed it always removed the last cell, so I tried manual selection with a chapter range 1:1-32 excluding the last one and it also failed. Seeing another post where someone said it worked with Passkey I downlaoded a trial and gave that a shot and it also failed, then ditto for anyDVD. I see several past posts about this DVD being an issue. I did pop in the full frame which is on disc 2 and it worked on the first attempt.. The wide screen DVD plays fine, but cannot be converted at all as far as I can tell.
I wondered if anyone has ever succesfully been able to convert the WideScreen version of this DVD at all, and if so how ??
The logs for my libredrive attempts are pretty long, but here is the first attempt which was done using CELLFULL method.
Debug log started at Fri Nov 17 13:44:18 2023 , written by MakeMKV v1.17.5 win(x64-release)
001005:0000 MakeMKV v1.17.5 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file://C:\Users\cookie/MakeMKV_log.txt
001003:0020 DEBUG: Code 0 at aD?(SI~)muxN:\n{|~a4)n@U:121261704
001003:0020 DEBUG: Code 3221225486 at aD?(SI~)muxN:\n{|~a4)n@U:121261727
001003:0020 DEBUG: Code 3221225486 at SR$nVx7[+nQ95SKCA=Tf:213130582
DEBUG: Code 3 at p#THBi/ll*BA2gQ6"dN^+C5W:29395310
SDF  v098: HL-DT-ST_BD-RE_BP50NB40_1.03_212005070917_SIK01N15E2616
001011:0000 Using LibreDrive mode (v06.3 id=D79E993B8FCA)
001012:0000 Open DVD manually : "1"
003038:0000 Cells 122-122 were removed from title end
003028:0000 Title #1 was added (121 cell(s), 1:39:31)
001009:0000 Profile parsing error: Invalid token '=1:video*(!mvcvideo)+sel:audio*multi*lossy*(!core)*(!havecore)*(eng|spa|nolang)'
005014:0000 Saving 1 titles into directory file://H:/MOVIES
001003:0020 DEBUG: Code 3221225488 at p#THBi/ll*BA2gQ6"dN^+C5W:121262371
001003:0020 DEBUG: Code 3221225488 at e0)""ua'FL?Ifeb9:213130559
001003:0020 DEBUG: Code 101000192 at 6XX(~WMlif ;_K(I:121271617
001003:0020 DEBUG: Code 101000192 at e0)""ua'FL?Ifeb9:213130559
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '1497088'
002003:0000 Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom4' at offset '1497088'
DEBUG: Code 3221225488 at T*66mI"9R%2H!-6CI':29394896
001003:0020 DEBUG: Code 3221225488 at T*66mI"9R%2H!-6CI':213131502
DEBUG: Code 101000192 at T*66mI"9R%2H!-6CI':29394896
001003:0020 DEBUG: Code 101000192 at T*66mI"9R%2H!-6CI':213131502
001003:0020 DEBUG: Code 0 at %K{3+D<I-p.W2g)K$P73:29395471
001003:0020 DEBUG: Code 0 at Z|}2O^LgDo#G1R{T{y :29393562
001003:0020 DEBUG: Code 0 at %K{3+D<I-p.W2g)K$P73:213131157
001003:0020 DEBUG: Code 0 at %K{3+D<I-p.W2g)K$P73:121262647
001003:0020 DEBUG: Code 731 at %K{3+D<I-p.W2g)K$P73:121261773
001003:0020 DEBUG: Code 0 at "I0?2XJ_UPV9?r3<b,B}qq:121263751
001003:0020 DEBUG: Code 0 at 5#w%HEc@g}P<=`%X^J>Av:213137068
001003:0020 DEBUG: Code 0 at #U-CH*_@vi7X5z=Cjizv:29394022
001003:0020 DEBUG: Code 0 at #U-CH*_@vi7X5z=Cjizv:121266764
001003:0020 DEBUG: Code 0 at 5#w%HEc@g}P<=`%X^J>Av:29400462
001003:0020 DEBUG: Code 0 at 5#w%HEc@g}P<=`%X^J>Av:213136700
001003:0020 DEBUG: Code 0 at F(;hmsvFkL!;Ut_P^=::29394482
001003:0020 DEBUG: Code 0 at F(;hmsvFkL!;Ut_P^=::121264740
001003:0020 DEBUG: Code 0 at F(;hmsvFkL!;Ut_P^=::29396138
001003:0020 DEBUG: Code 0 at F(;hmsvFkL!;Ut_P^=::213134906
001003:0020 DEBUG: Code 0 at rW7LRhJZY*VT:"D7:213130904
001003:0020 DEBUG: Code 0 at rW7LRhJZY*VT:"D7:213130582
001003:0020 DEBUG: Code 0 at ~oh{+ReP=Y.St+[i$j:121269731
001003:0020 DEBUG: Code 0 at ~oh{+ReP=Y.St+[i$j:29401819
005003:0000 Failed to save title 0 to file H:/MOVIES/Finding Nemo.mkv
Encountered 53 unclassified errors
error=0x06052400 count=32 name=Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB
error=0xC0000010 count=21 name=OS error - The specified request is not a valid operation for the target device
005004:0080 0 titles saved, 1 failed
