Not sure if this is the disk? Or decrypt? Or hardware! Martial Law 2 4k (German media book orange cover)
Jman5150
Post by Jman5150 »
Just gets stuck and stalls at this point…doesn’t crash or fail…just continues indefinitely like all is well but not….
Martial law the original backsup fine…no issues
Also it straggly ejected the disk once before ripping however its not repeated. No other disk has done this.
MakeMKV v1.17.5 darwin(x64-release) started
Debug logging enabled, log will be saved as /Users/
Optical drive "BD-RE PIONEER BD-RW BDR-XS07U 1.01 BADL005088UCd" opened in OS access mode.
Using LibreDrive mode (v01.0 id=1534D764B687)
Backing up disc into folder "/Volumes/
DEBUG: Code 100864261 at y#zq5'69UH;<A2hn~*:121263429
DEBUG: Code 100864261 at y#zq5'69UH;<A2hn~*:121262302
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading 'BD-RE PIONEER BD-RW BDR-XS07U 1.01 BADL005088UC' at offset '33361952768'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading 'BD-RE PIONEER BD-RW BDR-XS07U 1.01 BADL005088UC' at offset '33363329024'
DEBUG: Code 0 at c1+F%s}k}jIZip*:121262509
DEBUG: Code 0 at c1+F%s}k}jIZip*:213129846
DEBUG: Code 1 at c1+F%s}k}jIZip*:29395264
DEBUG: Code 0 at *^.f=92l-H&#vwSz>pF:213142887
Failed to load content hash table, unable to verify integrity of M2TS files.
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading 'BD-RE PIONEER BD-RW BDR-XS07U 1.01 BADL005088UC' at offset '33360969728'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/AACS/ContentHash001.tbl' at offset '192512'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/AACS/ContentHash001.tbl' at offset '194560'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/AACS/ContentHash001.tbl' at offset '196608'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/AACS/ContentHash001.tbl' at offset '200704'
Re: Not sure if this is the disk? Or decrypt? Or hardware! Martial Law 2 4k (German media book orange cover)
looks like bad disc
try cleaning it with a damp lint free microfiber cloth and dry with another
jordanwalkert
Post by jordanwalkert »
I just had this happen with my brand new UHD disc of The Fugitive. Doesn't appear to be dirty or scratched but tried several times with the same errors at the same spot. Guess I have to get a replacement from Best Buy. What a bummer. I'm 0 for 2 on recent Harrison Ford UHD discs. Witness won't rip correctly due to mastering issues.
Sometimes brand new, first time out of the case discs can have an impossible to spot haze that evenly coats the disc. A gentle cleaning can remove it and improve your chances of getting a clean rip.
jordanwalkert
I just exchanged for a brand new disc and I’m getting the exact same type of errors at the exact same spot. I think this might have more to do with the mastering process or the type of disc than just a disc being dirty. The new disc I got is absolutely flawless with not a mark anywhere in sight. I have never run into this problem before, seems to only be with newly released films. Very odd.
