Does Makemvk work with hd dvd player?
meber
Hi I want to rip my hd dvd’s and the way I last did it many years back was a Xbox hd dvd player, does makemkv work on this ?
Re: Does Makemvk work with hd dvd player?
If you have a HD DVD drive that works with your computer then MakeMKV should still be able to work with it.
RobTi
just started using an xbox hd dvd drive on mine although less than 1/2 are reading
