A Pause/Resume feature?
My UHD Drives tend to get hot and that causes issues with the process. A pause/resume function would be great as it would allow me to give the drive time to "rest". I have two LG UHD Drives and they both experience the issue. Anyone else have those issues?
Re: A Pause/Resume feature?
Be aware that some drives disconnect if they're paused long enough to stop turning.
You could also limit their top speed to reduce heat build-up.
It's best to just let them cool off for a least 10 mins between discs pause half way through is not necessary.
The only thing that kills drive super quick is live encoding on a slow PC.
Makemkv never does that but some other rippers do seen some lgs drives die overnight when someone let's their dual core from 2006 reencode a 4K UHD.
