Hello! I recently got PowerDVD 22 to play Blu-Rays, as I've found VLC to be a bit of a headache with stuttering and stopping playback at random points. Every time I try to play a disc in PowerDVD 22, I get the error "Cyberlink PowerDVD cannot play this content because it is corrupted". DVDs play fine, and the discs I've been testing load up in VLC as well. Any help on how to fix this is greatly appreciated.
P.S: My drive is the LG BP50NB40.
Cyberlink PowerDVD 22 will not play any Blu-Rays.
chandler010
Re: Cyberlink PowerDVD 22 will not play any Blu-Rays.
Are you opening them.in makemkv before you open cyberlink?
If so don't do that as maklv.removes buss encryption on libredrives and cyber link probably don't like that.
It should work on stand blu-ray but will never work on UHD Blu rays
With a flashed drive that's not official
chandler010
No, I am not opening MakeMKV before using PowerDVD. I've tried a fresh restart too just to ensure that wasn't the issue. MakeMKV isn't a startup program either to my knowledge.Billycar11 wrote: Thu Nov 16, 2023 12:00 am Are you opening them.in makemkv before you open cyberlink?
and these are standard blurays not UHD?
chandler010
Yes, they are just standards Blu-Rays.
Original Blu-ray discs, not copies?
chandler010
Yes, they're original. Strangely enough though, my custom BD-Rs work fine (not copyrighted stuff, just concert footage).MartyMcNuts wrote: Thu Nov 16, 2023 8:27 pmOriginal Blu-ray discs, not copies?
So you don't have MakeMKV, AnyDVD or DVDFab Passkey running at all?chandler010 wrote: Sat Nov 18, 2023 6:21 amYes, they're original. Strangely enough though, my custom BD-Rs work fine (not copyrighted stuff, just concert footage).
chandler010
No, I don’t have any of that running at all.MartyMcNuts wrote: Sat Nov 18, 2023 7:01 amSo you don't have MakeMKV, AnyDVD or DVDFab Passkey running at all?chandler010 wrote: Sat Nov 18, 2023 6:21 amYes, they're original. Strangely enough though, my custom BD-Rs work fine (not copyrighted stuff, just concert footage).
