jt5298
Re: SDFtool Flasher
#856 Post by jt5298 » Fri Nov 10, 2023 8:34 pm
I'm trying to flash my LG WH16NS40 v 1.05 using the latest SDFtool Flasher. The dropdown doesn't recognize my drive. It shows as installed in the device manager.
Not sure what to do.
Re: SDFtool Flasher
#857 Post by d00zah » Fri Nov 10, 2023 8:40 pm
jt5298 wrote: Fri Nov 10, 2023 8:34 pm Hello,
Is MakeMKV installed? The tool is a front-end for MakeMKV's native flash tool.
viewtopic.php?p=143084#p143084
jt5298
Re: SDFtool Flasher
#858 Post by jt5298 » Fri Nov 10, 2023 8:45 pm
Just installed it, sorry.
Thanks.
djs1394xd
Re: SDFtool Flasher
#859 Post by djs1394xd » Tue Nov 14, 2023 5:53 pm
Hello, I have been trying to figure out what I did wrong here. I have the Lg BP50NB40 and I thought I followed the steps correctly by using the SDFtool Flasher to write the BP50NB40 (NB50) 1.03-MK. file from the customer firmware pack then to use recovery to the same file. Then to write the BP60NB10 1.00-MK file. Did I miss something? Thank you in Advanced
Current profile: DVD-ROM
Product: BD-RE BP50NB40
Revision: 1.03
Serial number: SIK07N7MJ0259
Highest AACS version: 68
Firmware version: 1.03
Re: SDFtool Flasher
#860 Post by MartyMcNuts » Tue Nov 14, 2023 9:43 pm
djs1394xd wrote: Tue Nov 14, 2023 5:53 pm Hello, I have been trying to figure out what I did wrong here. I have the Lg BP50NB40 and I thought I followed the steps correctly by using the SDFtool Flasher to write the BP50NB40 (NB50) 1.03-MK. file from the customer firmware pack then to use recovery to the same file. Then to write the BP60NB10 1.00-MK file. Did I miss something? Thank you in Advanced
Revision: 1.03
Yes, you didn't do the recovery process correctly. Also I recommend you use the BU40N 1.00 firmware as it is better than the BP60NB10 firmware.
Select your drive. When you select recovery, in the popup window, select the BP50NB40 firmware you have currently on the drive. Now in the normal firmware dropdown box, select the BU40N 1.00 firmware and press START.
djs1394xd
Re: SDFtool Flasher
#861 Post by djs1394xd » Tue Nov 14, 2023 11:38 pm
MartyMcNuts wrote: Tue Nov 14, 2023 9:43 pm
Great thank you so much, I completely overlooked that. Appreciate the help it works now!
edo@usa.com
Re: SDFtool Flasher
#862 Post by edo@usa.com » Thu Nov 16, 2023 6:34 pm
Hi Marty,
I'm trying the flasher on a Win10 Enterprise and it's crashing. Is there any update?
Here's the info:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
   at SDFtool_Flasher_Updated.Form1.Check_MakeMKV_Installation()
   at SDFtool_Flasher_Updated.Form1.Form1_Load(Object sender, EventArgs e)
   at System.Windows.Forms.Form.OnLoad(EventArgs e)
   at System.Windows.Forms.Form.OnCreateControl()
   at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
   at System.Windows.Forms.Control.CreateControl()
   at System.Windows.Forms.Control.WmShowWindow(Message& m)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
   at System.Windows.Forms.ContainerControl.WndProc(Message& m)
   at System.Windows.Forms.Form.WmShowWindow(Message& m)
   at System.Windows.Forms.Form.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, WM msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
System.Private.CoreLib
    Assembly Version: 6.0.0.0
    Win32 Version: n/a
    CodeBase:
    Assembly Version: 1.3.5.0
    Win32 Version: n/a
    CodeBase:
System.Runtime
    Win32 Version: n/a
    CodeBase:
    Assembly Version: 6.0.2.0
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Drawing.Primitives
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Drawing.Common
    Win32 Version: n/a
    CodeBase:
System.Threading
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Collections
    Win32 Version: n/a
    CodeBase:
System.Diagnostics.Process
    Win32 Version: n/a
    CodeBase:
Microsoft.Win32.Primitives
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Threading.Thread
    Win32 Version: n/a
    CodeBase:
Accessibility
    Assembly Version: 4.0.0.0
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Numerics.Vectors
    Win32 Version: n/a
    CodeBase:
System.Memory
    Win32 Version: n/a
    CodeBase:
System.ComponentModel
    Win32 Version: n/a
    CodeBase:
System.Resources.Extensions
    Win32 Version: n/a
    CodeBase:
System.Drawing
    Win32 Version: n/a
    CodeBase:
System.ObjectModel
    Win32 Version: n/a
    CodeBase:
System.Linq
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Collections.Concurrent
    Win32 Version: n/a
    CodeBase:
mscorlib
    Win32 Version: n/a
    CodeBase:
Microsoft.Win32.SystemEvents
    Win32 Version: n/a
    CodeBase:
System.Collections.NonGeneric
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Private.Uri
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Xml.ReaderWriter
    Win32 Version: n/a
    CodeBase:
System.Private.Xml
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Net.WebClient
    Win32 Version: n/a
    CodeBase:
    Win32 Version: n/a
    CodeBase:
System.Xml.XmlSerializer
    Win32 Version: n/a
    CodeBase:
Microsoft.Win32.Registry
    Win32 Version: n/a
    CodeBase:
System.Runtime.Loader
    Win32 Version: n/a
    CodeBase:
System.Diagnostics.StackTrace
    Win32 Version: n/a
    CodeBase:
System.Reflection.Metadata
    Win32 Version: n/a
    CodeBase:
System.Collections.Immutable
    Win32 Version: n/a
    CodeBase:
************** JIT Debugging **************
edo@usa.com
Re: SDFtool Flasher
#863 Post by edo@usa.com » Thu Nov 16, 2023 7:36 pm
Marty,
Naver mind, my fault. I didn't installed MKV first as I just saw it on one of the latest messages.. Sorry It's running now No issues.
Buzzlite1926
Re: SDFtool Flasher
#864 Post by Buzzlite1926 » Wed Nov 29, 2023 2:11 am
Still error code 0x82052603......sooo nothing is working
Buzzlite1926
Re: SDFtool Flasher
#865 Post by Buzzlite1926 » Wed Nov 29, 2023 2:19 am
Still not working!!!!
Re: SDFtool Flasher
#866 Post by Billycar11 » Wed Nov 29, 2023 2:58 am
Buzzlite1926 wrote: Wed Nov 29, 2023 2:19 am Still not working!!!!
try following the guide and use cli to flash see if its any different what does that output say?
Re: SDFtool Flasher
#867 Post by MartyMcNuts » Wed Nov 29, 2023 5:17 am
Buzzlite1926 wrote: Wed Nov 29, 2023 2:11 am Still error code 0x82052603......sooo nothing is working
Before you begin, ensure you have MakeMKV v1.15.2 or greater installed and that the drive is empty and tray closed.
To flash the BP50NB40 SVC:NB52, using the latest SDFtool Flasher, follow the steps below:
1. Flash the drive to BP50NB40 (NB50) 1.03-MK.
Now for the cross-flash:
2. Select the RECOVERY option and in the pop up window, select the BP50NB40 (NB50) 1.03-MK firmware that you just flashed.
3. Select the BU40N 1.00 firmware in the normal drop box.
4. Click START
If you follow these steps exactly it should work.
Buzzlite1926
Re: SDFtool Flasher
#868 Post by Buzzlite1926 » Wed Nov 29, 2023 5:31 am
Ong!!! Thank u!!! :shock: :D 😱🥰👍👍👍👍👍
Re: SDFtool Flasher
#869 Post by MartyMcNuts » Wed Nov 29, 2023 5:39 am
Buzzlite1926 wrote: Wed Nov 29, 2023 5:31 am Ong!!! Thank u!!!
So what was your problem? Cause those steps are exactly what is written in the first post of this thread, which is what I have been telling you to follow.
Buzzlite1926
Re: SDFtool Flasher
#870 Post by Buzzlite1926 » Fri Dec 01, 2023 1:44 am
It was installing the DG firmware directly instead of putting the LG 1.03 THEN DG firmware.
Thank u!
