The first movie in the set decrypts correctly (it's a repackage of the previous 4K release), but the other 4 movies are new discs and can't be opened. Dumps have been submitted for each.
MKB20_v77_Twilight-_New_Moon_F726.tgz
MKB20_v77_Twilight-_Eclipse_FAE6.tgz
MKB20_v77_Twilight-_Breaking_Dawn_Part_1_CBBE.tgz
MKB20_v77_Twilight-_Breaking_Dawn_Part_2_2F82.tgz
Twilight UHD Boxed Set dumps submitted
kwelitysoul
Re: Twilight UHD Boxed Set dumps submitted
Thank you for posting this. After the dump, how long does it take to be available and allow for burning?
kwelitysoul
Submitted the same, thank you! Is it usually a 1-2 day turnaround to decrypt these?
enginerd
All discs have keys now
Cesarleeds
All these discs, while being able to rip them, they are all region locked.
Even after the makemkv treatment.
Any workaround?
Lionsgate strikes again.
Any workaround?
As far a I know regions are not a thing on UHD discs.Cesarleeds wrote: Sun Nov 19, 2023 6:13 pm All these discs, while being able to rip them, they are all region locked.
Any workaround?
Lionsgate strikes again.![]()
But definitely should not be a thing if you made it into a mkv.
If you did a folder backup just change your region in the software player it like VLC is set to region b by default.
R1pp3r
Perhaps an offtopic question, but where did you get Twilight in UHD?
I've only found the first movie on Amazon so far.
Is it maybe english only? I am looking on the german sites.
Pardon my curiosity
Pardon my curiosity
Cesarleeds
It´s 90 usd on bestbuy, google "The Twilight Saga [15th Anniversary] [SteelBook] [4K Ultra HD Blu-ray/Blu-ray]"R1pp3r wrote: Mon Nov 20, 2023 12:22 am Perhaps an offtopic question, but where did you get Twilight in UHD?
Pardon my curiosity![]()
As i said, i was able to rip all discs, but somehow the region lock remains.
I know it´s not a commong thing for UHDs, but there are quite a few region locked.
The Twilight Saga: 5-Movie Collection 4K Blu-ray
It seems like it is a Best Buy exclusive release at least at the moment.
