sofakng
#9136 Post by sofakng » Wed Nov 08, 2023 6:59 pm
Is there a current best player?
I've looked at RESET_9999's spreadsheet and it seems like all of them have several problems?
#9137 Post by RESET_9999 » Wed Nov 08, 2023 7:21 pm
For DV rip, the x800m2 is the best player with fewer issues.
Amused
#9138 Post by Amused » Wed Nov 08, 2023 7:49 pm
RESET_9999 wrote:
Wed Nov 08, 2023 12:03 pm
this doesnt need to be scripted. Use workflow 8-3 to find out the correct playlist and then remux it directly with DoVi_Scripts\tools\tsMuxerGUI.exe
Wow, it’s as simple as that! Thanks, I thought it had to go through some processing before txMuxer!
Sony x800m2 handles DT-DL m2ts files beautifully, but struggles with many ST-DL files for some reason.
UHD players: Sony X700, Zidoo Z1000 Pro
Audio system: Sony HT-A9
TV: Sony 77A80J
Mattl0
#9139 Post by Mattl0 » Wed Nov 08, 2023 9:37 pm
RESET_9999 wrote:
Mon Nov 06, 2023 7:09 pm
simonhazel00 wrote:
Mon Nov 06, 2023 6:47 pm
yes the text appeared correctly.
Im actually really unsure what it's doing to be honest. the tests would indicate so, and the manufactures page says it supports fel, however the word it in a way that makes it sound like they are discarding fel and doing bl+rpu.
are your test sample definitive proof of proper fel support?
Im willing to do any testing you can think of, if you want me to dig deeper.
slightly off topic - getting dolby vision and truehd atmos working at the same time has been a pain. then there's earc flakeyness that really drives a middle finger home XD.
oh I see whats going on. My 2nd version of the fel test is misleading and i took the wrong EL.
please try this one instead and look for the 2nd video in the background like this:
https://drive.google.com/file/d/1rk-quC ... drive_link
Thanks for this. Fel is discarded on my a95k via app of default media player .Even if it is in dolby vision mode. I have tried every container (DL-ST) exept mp4.
DjObama
Re: Flac in mp4 workflows
#9140 Post by DjObama » Fri Nov 10, 2023 5:15 pm
RESET_9999 wrote:
Sun Nov 05, 2023 12:37 am
DjObama wrote:
Sat Nov 04, 2023 1:10 pm
LG B8. Flac works
Ok, try the next version.
line 69 set encode_LL=NO
choices are NO or FLAC or LPCM (default=NO)
I set line 69 to FLAC as you instructed but the worflow 4-3-1 failed with:
[flac @ 0000023f44d84300] encoding as 24 bits-per-sample
[mp4 @ 0000023f44daf880] flac in MP4 support is experimental, add '-strict -2' if you want to use it.
Could not write header for output file #0 (incorrect codec parameters ?): Experimental feature
Error initializing output stream 0:0 --
Conversion failed!
skull88
#9141 Post by skull88 » Fri Nov 10, 2023 5:22 pm
LG B8. Flac works
Conversion failed!
Don't forget you can now make official bug reports on the github page: https://github.com/R3S3t9999/DoVi_Scripts/issues
#9142 Post by RESET_9999 » Fri Nov 10, 2023 5:31 pm
Working fine on my end. Are you using your own ffmpeg ? if yes try with the version that comes with my tool pack.
General
Complete name                            : D:\P7 DTS SRT PGS 2021_DoVi.mp4
Format                                   : mp43
Codec ID                                 : mp43 (isom/mp43/dby1)
File size                                : 2.22 GiB
Duration                                 : 5 min 0 s
Overall bit rate                         : 63.5 Mb/s
Frame rate                               : 23.976 FPS
Encoded date                             : 2023-11-10 17:29:59 UTC
Tagged date                              : 2023-11-10 17:29:59 UTC
Writing application                      : GPAC-1.1.0-DEV-rev1027-g1daa0b5f-master
Video #1
HDR format                               : SMPTE ST 2086, HDR10 compatible
Codec ID                                 : hev1
Codec ID/Info                            : High Efficiency Video Coding
Bit rate                                 : 58.0 Mb/s
Maximum bit rate                         : 100 Mb/s
Bits/(Pixel*Frame)                       : 0.291
Stream size                              : 2.03 GiB (91%)
Encoded date                             : 2023-11-10 17:29:56 UTC
Tagged date                              : 2023-11-10 17:30:01 UTC
Maximum Content Light Level              : 9978 cd/m2
Maximum Frame-Average Light Level        : 5364 cd/m2
Codec configuration box                  : hvcC
Video #2
HDR format                               : Dolby Vision, Version 1.0, dvhe.07.06, EL+RPU / SMPTE ST 2086, HDR10 compatible
Bit rate                                 : 2 091 kb/s
Width                                    : 1 920 pixels
Height                                   : 1 080 pixels
Bits/(Pixel*Frame)                       : 0.042
Stream size                              : 74.8 MiB (3%)
Audio #1
Format                                   : E-AC-3
Format/Info                              : Enhanced AC-3
Commercial name                          : Dolby Digital Plus
Codec ID                                 : ac-3
Bit rate                                 : 1 536 kb/s
Maximum bit rate                         : 1 573 kb/s
Frame rate                               : 62.500 FPS (768 SPF)
Stream size                              : 55.0 MiB (2%)
Title                                    : DDP
Encoded date                             : 2023-11-10 17:30:01 UTC
Audio #2
Format                                   : FLAC
Format/Info                              : Free Lossless Audio Codec
Codec ID                                 : fLaC
Duration_LastFrame                       : -3 ms
Bit rate                                 : 1 923 kb/s
Maximum bit rate                         : 3 094 kb/s
Bit depth                                : 16 bits
Stream size                              : 68.8 MiB (3%)
Title                                    : FLAC
MD5 of the unencoded content             : C8311326E38529F50C19D1257BFE8D59
Text #1
Format                                   : Timed Text
Codec ID                                 : tx3g
Duration                                 : 4 min 55 s
Bit rate                                 : 35 b/s
Frame rate                               : 0.166 FPS
Stream size                              : 1.27 KiB (0%)
Title                                    : SRT
Count of events                          : 24
Text #2
Format                                   : Timed Text
Codec ID                                 : tx3g
Bit rate                                 : 39 b/s
Frame rate                               : 0.227 FPS
Stream size                              : 1.42 KiB (0%)
Title                                    : SRT
Count of events                          : 33
tjayz
#9143 Post by tjayz » Sat Nov 11, 2023 8:03 am
Use Emby, if still have problem, I assure you is not the media player. I cast to x800 which cannot process dv in mkv so I always use ts to preserve lossless audio as well. Some DL-ST will freeze black, just keep everything DL-DT.
UBP-X800M2 / LG OLED CX / NAD M17 V2i
DjObama
#9144 Post by DjObama » Sat Nov 11, 2023 5:44 pm
Thank you, YES! That was the case, I had old ffmpeg. I'm happy to report Flac audio works with p7 DT-DL in MP4 container :) (Edit. On my LG B8)
Compression level 0 you set for flac encode is a good choice, I compared with level 5 on 2,5h movie and the size difference was only 200 mb.
However, the dts-hd ma track got discarded upon conversion, am I missing a setting to keep the original audio track?
#9145 Post by RESET_9999 » Sat Nov 11, 2023 6:49 pm
yes, it's by design but I can remove that restriction in the next version.
for workflow 4-3-1, remove at lines 7331-7343: if not "%encode_LL%"=="YES"
replace:
for /L %%i in (1,1,%count%) do (
     if "%encode_LL%"=="YES" if exist "%TEMP%audio_%%i_!T%%i.Lang!.thd" "%ffmpeg_path%" -i "%TEMP%audio_%%i_!T%%i.Lang!.thd" -map 0:0 -c %llcodec% "%TEMP%pcm%%i.%mcont%"& set AL%%i=-add "%TEMP%pcm%%i.%mcont%"#audio:lang=!T%%i.Lang!:name=%mname%!FORCED%%i!
     if exist "%TEMP%audio_%%i_!T%%i.Lang!.thd"	if "%keep_lossless%"=="YES" if not "%encode_LL%"=="YES" "%ffmpeg_path%" -y -i "%TEMP%audio_%%i_!T%%i.Lang!.thd" -map 0:0 -c copy -strict -2 "%TEMP%lossless%%i.mp4" & set AL%%i=-add "%TEMP%lossless%%i.mp4"#audio:lang=!T%%i.Lang!:name=THD!FORCED%%i!
     if "%encode_LL%"=="YES" if exist "%TEMP%audio_%%i_!T%%i.Lang!.dts" "%ffmpeg_path%" -i "%TEMP%audio_%%i_!T%%i.Lang!.dts" -map 0:0 -c %llcodec% "%TEMP%pcm%%i.%mcont%"& set AL%%i=-add "%TEMP%pcm%%i.%mcont%"#audio:lang=!T%%i.Lang!:name=%mname%!FORCED%%i!
     if exist "%TEMP%audio_%%i_!T%%i.Lang!.dts"	if "%keep_lossless%"=="YES" if not "%encode_LL%"=="YES" "%ffmpeg_path%" -y -i "%TEMP%audio_%%i_!T%%i.Lang!.dts" -map 0:0 -c copy "%TEMP%lossless%%i.mp4" & set AL%%i=-add "%TEMP%lossless%%i.mp4"#audio:lang=!T%%i.Lang!:name=DTS!FORCED%%i!
ans40
#9146 Post by ans40 » Mon Nov 13, 2023 9:12 am
For injecting both HDR10+ and DV into the same BL, does it matter which you do first?
powdeau
#9147 Post by powdeau » Mon Nov 13, 2023 6:21 pm
@RESET_9999 Do i need to change something in your DaVinci preset for DV generation in 18.6 or is everything the same?
Now I have these settings:
#9148 Post by RESET_9999 » Mon Nov 13, 2023 8:09 pm
no
yes
DjObama
FLAC/LPCM lower volume FIX
#9149 Post by DjObama » Tue Nov 14, 2023 3:45 pm
I did some more testing with Flac audio. For some movies after converting trueHD/dts-hd to Flac (i think it applies to lpcm too) the resulting audio track is significantly lower volume. Probably because dts contains metadata that instructs the receiver by how much it should boost the signal and flac/lpcm is just raw audio information. For example Gladiator is a movie for which flac/lpcm is 4,5 dB lower than it could be.
I found a good way to safely increase the signal with ffmpeg. First you have to find by how many dB you can losslessly increase volume with this command:
ffmpeg -i video.avi -af "volumedetect" -vn -sn -dn -f null /dev/null
This outputs information about how much dB you can increse the volume without going into clipping. For example:
[Parsed_volumedetect_0 @ 0x7f8ba1c121a0] mean_volume: -16.0 dB
[Parsed_volumedetect_0 @ 0x7f8ba1c121a0] max_volume: -5.0 dB
[Parsed_volumedetect_0 @ 0x7f8ba1c121a0] histogram_0db: 87861
Important is only the max_volume
Then use the command to increase the volume by max_volume amount:
  ffmpeg -i input.wav -af "volume=5dB" output.wav
This command only boosts the overall signal, there is no normalization happening, so it's still a lossless process.
Is it possible to incorporate this process into dovi_scripts @RESET_9999
You can find more information about it under this link (Option 3)
https://superuser.com/questions/323119/ ... ing-ffmpeg
PhantomIceman
#9150 Post by PhantomIceman » Tue Nov 14, 2023 5:09 pm
This may have been answered somewhere within this thread but since makemkv is able to rip the dolby vision layer is it possible to create a dolby vision playable mkv file through mkv or do you have use scripts?
