Moving?
unclebubbies
Moving?
Post by unclebubbies »
I have paid for my MakeMKV software and have used it frequently. In 3 weeks I'm going to be moving to a different state. I'll have a different IP address but the same computer. Is there anything I need to do to make sure I keep my subscription?
Re: Moving?
No, you'll be fine. Your license for MakeMKV doesn't care what your address is.
You'll likely end up with a different ISP who might have different policies. The 'keys' used to unlock UHDs are downloaded as necessary from the internet. If your new ISP blocks that connection, you might have to do a bit of work to get past that. But, there's no reason to worry about that until it is proven to be a problem.
unclebubbies
Re: Moving?
Well, that's good to know. I'll find out once I move. Thanks for letting know.
