SDFtool flasher
All topics related to functioning of this forum or MakeMKV website
hamishmcn
SDFtool flasher
Post by hamishmcn »
Hello I'm trying to flash my LG WH16NS40 which on makemkv it says libre is
possible with patched firmware. I'm trying to flash the firmware
DE_LG_WH16NS40-NS50_1.02.bin and I keep getting a pop up saying
ERROR:
command produced error code 0x82052603
any help would be nice
Re: SDFtool flasher
There's a whole thread for the SDFtool Flasher: viewtopic.php?f=16&t=22896
Also, the Ultimate UHD Drives Flashing Guide in the section titled Recommended Firmware to flash for MakeMKV says:
WH16NS40 on any Firmware directly to > WH16NS60 1.02MK
Hopefully you have MakeMKV installed in the standard location. No disc inserted in your drive and the tray closed.
tharris242
Re: SDFtool flasher
Post by tharris242 »
Did you ever find a solution?
I am getting the same error.
Fingers crossed,
T
tharris242
Re: SDFtool flasher
Well, I'm sorted...
I forgot, with encrypted firmware you have to flash NS60 first... that worked, no problem.
Hope this helps someone.
T
