Im Looking for a 12.7mm Internal drive
spl147
#1 Post by spl147 » Sat Oct 21, 2023 8:37 pm
looking for a 12.7mm optical drive for my dell poweredge 530, all i can find is panasonic but unsure it they will work with libredrive
Re: Im Looking for a 12.7mm Internal drive
#2 Post by Billycar11 » Sat Oct 21, 2023 9:25 pm
Panasonic will not do libredrive
I can't find it now but I think a long time ago I saw a spacer using a 9.5mm drive in a 12.7 slot.
If you can go for a pioneer they are way better
#3 Post by MartyMcNuts » Sat Oct 21, 2023 9:26 pm
Nope. Get yourself a 12.7 to 9.5mm adapter and either a LG BU40N or a Pioneer BDR-UD04 (firmware dated before Dec 2022). Both drives can enable Libre drive and also allow you to rip UHD discs.
spl147
#4 Post by spl147 » Sat Oct 21, 2023 9:29 pm
I have a BU40N on hand but i cannot find any kind of adapter
#5 Post by MartyMcNuts » Sat Oct 21, 2023 10:38 pm
I have seen them before somewhere. Quite hard to find though... You might just be better of getting an external slim drive.
#6 Post by dcoke22 » Mon Oct 23, 2023 6:58 am
Some internet searching brought me back around to a thread I commented in here on this forum. :D
viewtopic.php?f=16&t=24910
A 9.5mm optical drive should line up and fit, electrically, in a 12.7mm bay. The screw holes might not line up. And the front plate on a 9.5mm optical drive is not going to cover the 12.7mm hole, but supposedly a 12.7mm front plate can be installed on the drive.
spl147
#7 Post by spl147 » Fri Nov 10, 2023 5:37 pm
i got a Pioneer BDR-TD05, fits perfectly, but it has a odd firmware.
see: viewtopic.php?f=19&t=32332
#8 Post by Billycar11 » Fri Nov 10, 2023 8:40 pm
That drive will never do UHD needs to be 8301 or higher.
LibreDrive and reading UHD are not the same thing
spl147
#9 Post by spl147 » Fri Nov 10, 2023 8:46 pm
That would of been nice to know! I thought libreDrives purpose was for UHD.
#10 Post by Billycar11 » Fri Nov 10, 2023 9:13 pm
No it's to remove buss encryption and get around aacs revocation
#11 Post by d00zah » Fri Nov 10, 2023 9:49 pm
Do any up-front research?
OS device name: /dev/sr0
Manufacturer: PIONEER
Product: BD-RW BDR-TD05
Revision: 2.00
Serial number:
Firmware date: 2012-08-10
Drive platform: Pioneer RS8211
Firmware version: ID72
Ultimate UHD Drives Flashing Guide Updated 2023 states:
1. Make sure your Drive was built after 2016 on label or late 2015...
What is LibreDrive?
#12 Post by Billycar11 » Fri Nov 10, 2023 9:57 pm
Revision: 2.00
Serial number:
What is LibreDrive?
That's not exactly true for pioneers the guide is LG focused pioneers can do UHD going back to 2013 bdr 208 and newer is kinda a good way to look at it but remember guys there is no public flasher for these you would have to spoof the pioneers flasher if you want to diy
#13 Post by d00zah » Fri Nov 10, 2023 10:05 pm
Ya live, ya learn. :oops: Thanks for the intel!
