Im Looking for a 12.7mm Internal drive
spl147
Post by spl147 » Sat Oct 21, 2023 8:37 pm
looking for a 12.7mm optical drive for my dell poweredge 530, all i can find is panasonic but unsure it they will work with libredrive
Re: Im Looking for a 12.7mm Internal drive
Post by Billycar11 » Sat Oct 21, 2023 9:25 pm
Panasonic will not do libredrive
I can't find it now but I think a long time ago I saw a spacer using a 9.5mm drive in a 12.7 slot.
If you can go for a pioneer they are way better
Post by MartyMcNuts » Sat Oct 21, 2023 9:26 pm
Nope. Get yourself a 12.7 to 9.5mm adapter and either a LG BU40N or a Pioneer BDR-UD04 (firmware dated before Dec 2022). Both drives can enable Libre drive and also allow you to rip UHD discs.
spl147
Post by spl147 » Sat Oct 21, 2023 9:29 pm
I have a BU40N on hand but i cannot find any kind of adapter
Post by MartyMcNuts » Sat Oct 21, 2023 10:38 pm
I have seen them before somewhere. Quite hard to find though... You might just be better of getting an external slim drive.
Post by dcoke22 » Mon Oct 23, 2023 6:58 am
Some internet searching brought me back around to a thread I commented in here on this forum. :D
viewtopic.php?f=16&t=24910
A 9.5mm optical drive should line up and fit, electrically, in a 12.7mm bay. The screw holes might not line up. And the front plate on a 9.5mm optical drive is not going to cover the 12.7mm hole, but supposedly a 12.7mm front plate can be installed on the drive.
spl147
Post by spl147 » Fri Nov 10, 2023 5:37 pm
i got a Pioneer BDR-TD05, fits perfectly, but it has a odd firmware.
see: viewtopic.php?f=19&t=32332
Post by Billycar11 » Fri Nov 10, 2023 8:40 pm
That drive will never do UHD needs to be 8301 or higher.
LibreDrive and reading UHD are not the same thing
spl147
Post by spl147 » Fri Nov 10, 2023 8:46 pm
That would of been nice to know! I thought libreDrives purpose was for UHD.
Post by Billycar11 » Fri Nov 10, 2023 9:13 pm
No it's to remove buss encryption and get around aacs revocation
Post by d00zah » Fri Nov 10, 2023 9:49 pm
Do any up-front research?
OS device name: /dev/sr0
Manufacturer: PIONEER
Product: BD-RW BDR-TD05
Revision: 2.00
Serial number:
Firmware date: 2012-08-10
Drive platform: Pioneer RS8211
Firmware version: ID72
Ultimate UHD Drives Flashing Guide Updated 2023 states:
1. Make sure your Drive was built after 2016 on label or late 2015...
What is LibreDrive?
Post by Billycar11 » Fri Nov 10, 2023 9:57 pm
Revision: 2.00
Serial number:
What is LibreDrive?
That's not exactly true for pioneers the guide is LG focused pioneers can do UHD going back to 2013 bdr 208 and newer is kinda a good way to look at it but remember guys there is no public flasher for these you would have to spoof the pioneers flasher if you want to diy
Post by d00zah » Fri Nov 10, 2023 10:05 pm
Ya live, ya learn. :oops: Thanks for the intel!
