I'm trying to flash my LG WH16NS40 v 1.05 using the latest SDFtool Flasher. The dropdown doesn't recognize my drive. It shows as installed in the device manager.
Not sure what to do.
Re: SDFtool Flasher
Is MakeMKV installed? The tool is a front-end for MakeMKV's native flash tool.jt5298 wrote: Fri Nov 10, 2023 8:34 pm Hello,
viewtopic.php?p=143084#p143084
jt5298
Re: SDFtool Flasher
Just installed it, sorry.
Thanks.
Thanks.
djs1394xd
Re: SDFtool Flasher
Hello, I have been trying to figure out what I did wrong here. I have the Lg BP50NB40 and I thought I followed the steps correctly by using the SDFtool Flasher to write the BP50NB40 (NB50) 1.03-MK. file from the customer firmware pack then to use recovery to the same file. Then to write the BP60NB10 1.00-MK file. Did I miss something? Thank you in Advanced
Current profile: DVD-ROM
Product: BD-RE BP50NB40
Revision: 1.03
Serial number: SIK07N7MJ0259
Highest AACS version: 68
Firmware version: 1.03
Revision: 1.03
Re: SDFtool Flasher
Yes, you didn't do the recovery process correctly. Also I recommend you use the BU40N 1.00 firmware as it is better than the BP60NB10 firmware.djs1394xd wrote: Tue Nov 14, 2023 5:53 pm Hello, I have been trying to figure out what I did wrong here. I have the Lg BP50NB40 and I thought I followed the steps correctly by using the SDFtool Flasher to write the BP50NB40 (NB50) 1.03-MK. file from the customer firmware pack then to use recovery to the same file. Then to write the BP60NB10 1.00-MK file. Did I miss something? Thank you in Advanced
Revision: 1.03
Select your drive. When you select recovery, in the popup window, select the BP50NB40 firmware you have currently on the drive. Now in the normal firmware dropdown box, select the BU40N 1.00 firmware and press START.
djs1394xd
Re: SDFtool Flasher
Great thank you so much, I completely overlooked that. Appreciate the help it works now!MartyMcNuts wrote: Tue Nov 14, 2023 9:43 pm
edo@usa.com
Re: SDFtool Flasher
Hi Marty,
I'm trying the flasher on a Win10 Enterprise and it's crashing. Is there any update?
Here's the info:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
Here's the info:
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
at SDFtool_Flasher_Updated.Form1.Check_MakeMKV_Installation()
at SDFtool_Flasher_Updated.Form1.Form1_Load(Object sender, EventArgs e)
at System.Windows.Forms.Form.OnLoad(EventArgs e)
at System.Windows.Forms.Form.OnCreateControl()
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.Control.CreateControl()
at System.Windows.Forms.Control.WmShowWindow(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.ContainerControl.WndProc(Message& m)
at System.Windows.Forms.Form.WmShowWindow(Message& m)
at System.Windows.Forms.Form.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, WM msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
System.Private.CoreLib
Assembly Version: 6.0.0.0
Win32 Version: n/a
CodeBase:
Assembly Version: 1.3.5.0
Win32 Version: n/a
CodeBase:
System.Runtime
Win32 Version: n/a
CodeBase:
Assembly Version: 6.0.2.0
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Drawing.Primitives
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Drawing.Common
Win32 Version: n/a
CodeBase:
System.Threading
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Collections
Win32 Version: n/a
CodeBase:
System.Diagnostics.Process
Win32 Version: n/a
CodeBase:
Microsoft.Win32.Primitives
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Threading.Thread
Win32 Version: n/a
CodeBase:
Accessibility
Assembly Version: 4.0.0.0
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Numerics.Vectors
Win32 Version: n/a
CodeBase:
System.Memory
Win32 Version: n/a
CodeBase:
System.ComponentModel
Win32 Version: n/a
CodeBase:
System.Resources.Extensions
Win32 Version: n/a
CodeBase:
System.Drawing
Win32 Version: n/a
CodeBase:
System.ObjectModel
Win32 Version: n/a
CodeBase:
System.Linq
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Collections.Concurrent
Win32 Version: n/a
CodeBase:
mscorlib
Win32 Version: n/a
CodeBase:
Microsoft.Win32.SystemEvents
Win32 Version: n/a
CodeBase:
System.Collections.NonGeneric
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Private.Uri
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Xml.ReaderWriter
Win32 Version: n/a
CodeBase:
System.Private.Xml
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Net.WebClient
Win32 Version: n/a
CodeBase:
Win32 Version: n/a
CodeBase:
System.Xml.XmlSerializer
Win32 Version: n/a
CodeBase:
Microsoft.Win32.Registry
Win32 Version: n/a
CodeBase:
System.Runtime.Loader
Win32 Version: n/a
CodeBase:
System.Diagnostics.StackTrace
Win32 Version: n/a
CodeBase:
System.Reflection.Metadata
Win32 Version: n/a
CodeBase:
System.Collections.Immutable
Win32 Version: n/a
CodeBase:
************** JIT Debugging **************-
edo@usa.com
Re: SDFtool Flasher
Marty,
Naver mind, my fault. I didn't installed MKV first as I just saw it on one of the latest messages.. Sorry It's running now No issues.
Buzzlite1926
Re: SDFtool Flasher
Still error code 0x82052603......sooo nothing is working
Buzzlite1926
Re: SDFtool Flasher
Still not working!!!!
Re: SDFtool Flasher
try following the guide and use cli to flash see if its any different what does that output say?
Re: SDFtool Flasher
Before you begin, ensure you have MakeMKV v1.15.2 or greater installed and that the drive is empty and tray closed.Buzzlite1926 wrote: Wed Nov 29, 2023 2:11 am Still error code 0x82052603......sooo nothing is working
To flash the BP50NB40 SVC:NB52, using the latest SDFtool Flasher, follow the steps below:
1. Flash the drive to BP50NB40 (NB50) 1.03-MK.
Now for the cross-flash:
2. Select the RECOVERY option and in the pop up window, select the BP50NB40 (NB50) 1.03-MK firmware that you just flashed.
3. Select the BU40N 1.00 firmware in the normal drop box.
4. Click START
If you follow these steps exactly it should work.
Re: SDFtool Flasher
So what was your problem? Cause those steps are exactly what is written in the first post of this thread, which is what I have been telling you to follow.
Buzzlite1926
Re: SDFtool Flasher
It was installing the DG firmware directly instead of putting the LG 1.03 THEN DG firmware.
Thank u!
Thank u!
