debug file - kung fu panda
greg.o
Post by greg.o » Tue May 28, 2013 2:00 am
any thoughts?
thanks
greg.o
Re: debug file - kung fu panda
Post by greg.o » Tue May 28, 2013 2:27 am
the correct debug file might help
my guess is a bad disk?
Post by mike admin » Tue May 28, 2013 5:00 am
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00004.m2ts' at offset '8894939136'
A bad disc. /faq/item/7/catid/6
Millmaster
Post by Millmaster » Fri Nov 10, 2023 7:17 pm
Same disk - gest about halfway through and I get this error set:
Error 'OS error - {Device Timeout} The specified I/O operation on hs was not completed before the time-out period expired' occurred while reading '/BDMV/STREAM/00372.m2ts' at offset '13494122496'
Error 'OS error - {Device Timeout} The specified I/O operation on hs was not completed before the time-out period expired' occurred while reading '\Device\CdRom1' at offset '13494122496'
DEBUG: Code 3221225653 at XLZy#@p!6m/^{4B`f):213131502
Post by Billycar11 » Fri Nov 10, 2023 8:43 pm
Millmaster wrote: Fri Nov 10, 2023 7:17 pm Same disk - gest about halfway through and I get this error set:
Looks more like the drive is disconnecting because not enough power if you ask me is this a USB drive?
