Pioneer BDRS12UHT - Does it work out of the box
aeroboy86
Post by aeroboy86 »
Hello all,
Trying to determine whether the Pioneer BDRS12UHT will work out of the box for UHD ripping or does it still require flashing?
Thanks for any help you can provide.
James
Re: Pioneer BDRS12UHT - Does it work out of the box
Depends on when it was built/boxed. Before November 2022 operates (works) differently than after (doesn't work).
