Hi all, curious which of these is the correct playlist for Nuclear (2019). Also, if someone can explain what the difference is between the two options, please. I don't completely understand how a segment map works and that seems to be the only significant difference.
Source file name: 00000.mpls
Duration: 1:32:46
Chapters count: 8
Segment count: 1
Segment map: 0
File name: title_t00.mkv
Source file name: 00001.mpls
Duration: 1:32:46
Chapters count: 8
Segment count: 1
Segment map: 1
File name: title_t01.mkv
Correct Playlist for Nuclear (2019) Blu-ray
awookieewarrior
Re: Correct Playlist for Nuclear (2019) Blu-ray
One of those is most likely a different region language. Usually the correct one out of those 2 would be 00000.mpls for English.awookieewarrior wrote: Wed Nov 08, 2023 11:58 pm Hi all, curious which of these is the correct playlist for Nuclear (2019). Also, if someone can explain what the difference is between the two options, please. I don't completely understand how a segment map works and that seems to be the only significant difference.
Duration: 1:32:46
Chapters count: 8
Segment count: 1
Segment map: 0
Duration: 1:32:46
Chapters count: 8
Segment count: 1
Segment map: 1
Try using GetMPLS to find the correct playlist. It should also show you both playlists and any difference between the two are highlighted in blue. It only works with decrypted folders though, so you need to rip the disc to folder first.
viewtopic.php?p=86399#p86399
