Debug log started at Wed Jul 6 10:29:24 2011 , written by MakeMKV v1.6.10 darwin(x86-release)
001005:0000 MakeMKV v1.6.10 darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/MakeMKV_log.txt
002014:0000 Optical drive "BD-RE MATSHITA BD-MLT UJ230AS 1.11" opened in DASPI v1.3 mode.
001003:0020 DEBUG: Code 0 at /Vu6AYr{}1T@`E.oG:213131042
005050:0000 Evaluation version, 5 day(s) out of 30 remaining
DAFD=PAAAADAAAAEABDQUEAQEBAQIBDQAAAAAgAAAAAAAAAAA=
DCE=Ed1lDeTyajvvH9ECJd7Q9N0/0z8qid05o2yfAUF8LPoBq7DWXJ36IlSd6JNX2voCvgsVtaAaE1lCMLrzjjHQTyowBr2EVX43RN0RCa7RnkRRpjOMU1XNG0TVR20noeAKCHiKmSWaNVyebGcSL92sbiHq+nyjVOmHFA==
003317:0000 Loaded 17 SVQ file(s)
003326:0000 Processing BD+ code, please be patient - this may take up to few minutes
003324:0000 Processing BD+ code using generic SVQ from builtin/00002.svq
003332:0000 Saved BD+ dump file as /Volumes/500 GB/makemkvfiles/dump_SHINE_A_LIGHT_BD1C94AB49077965.tgz
003328:0000 BD+ code processed, got 1 FUT(s) for 1 clip(s)
DISCID=BD1C94AB4907796563B3F0603CC2ABBE656B6116
003025:0000 Title #00002.mpls has length of 79 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00001.mpls was added as title #0
003025:0000 Title #00025.mpls has length of 55 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003309:0000 Title 00020.mpls is equal to title 00001.mpls and was skipped
003307:0000 File 00019.m2ts was added as title #1
003025:0000 Title #00003.m2ts has length of 37 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00027.m2ts was added as title #2
003307:0000 File 00024.m2ts was added as title #3
003307:0000 File 00023.m2ts was added as title #4
003307:0000 File 00020.m2ts was added as title #5
003307:0000 File 00004.m2ts was added as title #6
003307:0000 File 00007.m2ts was added as title #7
003307:0000 File 00013.m2ts was added as title #8
003307:0000 File 00009.m2ts was added as title #9
003307:0000 File 00010.m2ts was added as title #10
003025:0000 Title #00030.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00029.m2ts was added as title #11
003307:0000 File 00017.m2ts was added as title #12
003307:0000 File 00014.m2ts was added as title #13
003307:0000 File 00026.m2ts was added as title #14
003307:0000 File 00025.m2ts was added as title #15
003307:0000 File 00018.m2ts was added as title #16
003025:0000 Title #00002.m2ts has length of 41 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00005.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00006.m2ts was added as title #17
003307:0000 File 00022.m2ts was added as title #18
003307:0000 File 00021.m2ts was added as title #19
003307:0000 File 00012.m2ts was added as title #20
003307:0000 File 00011.m2ts was added as title #21
003307:0000 File 00008.m2ts was added as title #22
003307:0000 File 00016.m2ts was added as title #23
003307:0000 File 00015.m2ts was added as title #24
003307:0000 File 00028.m2ts was added as title #25
003025:0000 Title #00031.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00032.m2ts has length of 27 seconds which is less than minimum title length of 120 seconds and was therefore skipped
005014:0000 Saving 1 titles into directory /Volumes/GoFlex Home Public/blu ray rips/Rolling Stones Shine a Light
001003:0020 DEBUG: Code 1073741829 at )Cb.?d~[?2i`@"#*:29393953
001003:0020 DEBUG: Code 2 at -N#YL4P(3f)A0CMS:121268719
002003:0000 Error 'Scsi error - HARDWARE ERROR:TRACK FOLLOWING ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '7857481728'
001003:0020 DEBUG: Code 0 at _y.Wha8OK(K)>ze|cZy3:29394298
001003:0020 DEBUG: Code 0 at [9oc2-g2Vj~;@2}X@%m_:121261681
001003:0020 DEBUG: Code 0 at _y.Wha8OK(K)>ze|cZy3:29394183
001003:0020 DEBUG: Code 3836661 at _y.Wha8OK(K)>ze|cZy3:29393309
005003:0000 Failed to save title 0 to file /Volumes/GoFlex Home Public/blu ray rips/Rolling Stones Shine a Light/title00.mkv
005004:0080 0 titles saved, 1 failed
Application exited at Wed Jul 6 11:00:38 2011
Rolling Stones, Shine a light errors...
hahafunny
AppleTV 2
Re: Rolling Stones, Shine a light errors...
This always means a physical disc error.hahafunny wrote:002003:0000 Error 'Scsi error - HARDWARE ERROR:TRACK FOLLOWING ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at
