Help flashing new WH16NS40 why is 4K playback possible with mine?
novice121
Re: Help flashing new WH16NS40 why is 4K playback possible with mine?
Post by novice121 » Mon Nov 06, 2023 9:00 pm
Hey, really quick question, call me stubborn, and dumb, but after many many many attempts over the weekend, it feels like this drive may be recoverable, but I don't remember exactly what I did, only that it did read Bluray disc again at one point, but no 4K, so I reflashed, and forgot how I got it to read BR :oops: .
By pure luck I think I did not delete my original dump (have lots of dumps, not sure if my earliest dump is the original), my question is, do I have to use Datamover with my ORIGINAL dump that I did on my first try, or can I simply re-read the drive, make a new dump, and use data mover again to create another firmware to flash?
All I do now is use my 64 bit system with SDFTool to flash DE_LG WH16NS60_1.00.bin from that "Downgrade" folder with LG flasher I got from here, turn it off, back on, and use LG flasher to reflash DE_LG WH16NS60_1.00 again. This allows me to re-use the drive on my 32 bit system with IDE mode to use DOSFlasher and Datamover again, but I don't remember what combination of files I used to make it work again. I definitely know that the firmwares inside the "Clean_NS50_compatible_firmwares" do not work. I think I may have used a possible original dump plus a firmware called "DE_LG_WH16NS40_1.01" I found in this forum somewhere, or a firmware with an MK in its name... will keep on trying tonight. I know how annoying this is, I don't care about losing the money I paid for this drive, but I really wanna give it a good try before trashing this drive.
PS: Saw new WH16NS40 on Amazon this past Saturday for only $60, bought it, it came as WH16NS40 NS50 Manufactured July 2023 ROM: 1.05, all I did was simply use my 64 bit system with SDFTool, and flashed "HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936" from the "All you need firmware pack", and it reads 4K discs fine now, already ripped 2 4K UHD disks past Sunday. It doesn't work on my copy of DVDFab, but it works perfect on Make MKV. I still want to try, and recover my original drive that also used to work with that fabulous software :(
DAVID83
Post by DAVID83 » Tue Nov 07, 2023 4:20 am
I've bought the same "WH16NS40 NS50 Manufactured July 2023 ROM: 1.05".
The only problem left is to get that magical "HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936" from the "All you need firmware pack"
Can you help me with the link to it?
DAVID83
Post by DAVID83 » Tue Nov 07, 2023 4:48 am
I'm sorry, - must update my previous replay: I've already found that "All you need pack" and had done this:
C:\Program Files (x86)\MakeMKV>sdftool64 -d F: rawflash main enc --in HL-DT-ST-
BD-RE_WH16NS60-1.02-NM00100-211810291936.bin
Reading input file HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin
Current Drive ID: HL-DT-ST_BD-RE__WH16NS40_1.05_xxxxxxxxxxxxxxxxxxxxxxx
yes
100% Operation finished
Done successfully
(Drive manufactured August 2023 SVC CODE NS50)
After this drive ripping ordinary blue-rays fine, BUT STILL UNABLE TO RECOGNIZE 4k UHD.
Drive connected to laptop with Windows 8.1 x64 by USB2 to SATA adapter. Could it be the reason?
Message from MakeMKV ver. 1.17.5 beta AFTER SUCCESSFUL (??!!) FLASH also looks pretty strange:
OS device name: F:
Product: BD-RE WH16NS40
Revision: 1.05
Serial number: xxxxxxxxxxxxx
Highest AACS version: 78
Harware support: Yes
Firmware support: No
Firmware version: 1.05
What is wrong? Help me, please.
Post by Coopervid » Tue Nov 07, 2023 11:01 am
Concerning your P.S.:
You can try to use BH16NS60 1.00 DE firmware for Fab. Or flash a friendly firmware like ASUS BW-16D1HT 3.10 MK to it. Your drive should then work with both Makemkv and Fab. And other software.
DAVID83
Post by DAVID83 » Tue Nov 07, 2023 7:28 pm
Thanks everybody for good intentions: the problem SOLVED!
All I need to do was to connect that drive to workstations with Windows 10 by internal SATA connection without any adapters.
novice121
Post by novice121 » Tue Nov 07, 2023 11:48 pm
DAVID83 wrote: Tue Nov 07, 2023 7:28 pm Thanks everybody for good intentions: the problem SOLVED!
I am sorry brother, I am not qualified to give you advise, remember I bricked a perfectly working drive by flashing something I shouldn't. I am glad you got it sorted out though.
novice121
Post by novice121 » Tue Nov 07, 2023 11:53 pm
Coopervid wrote: Tue Nov 07, 2023 11:01 am Concerning your P.S.:
I am afraid to do this seeing how I bricked a good drive; I would try this if you could give me more dummy proof instructions, and link me to the files in question. Can I just use my 64 bit system, use SDFTool flasher with GUI from here, and just flash away? Where can I get those firmwares exactly?
Post by Billycar11 » Wed Nov 08, 2023 1:18 am
novice121 wrote: Tue Nov 07, 2023 11:53 pm
See guide below
Or get an automated flasher from me or Marty
novice121
Post by novice121 » Thu Nov 09, 2023 10:23 pm
Holy shit dude, it worked! My new drive worked; I simply used my 64 bit system, with my 5.25 enclosure with USB, and used SDFTool 1.3.5 GUI to flash "ASUS-BW-16D1HT-3.10-WM01601-211901041014" from that MK folder from here: viewtopic.php?f=19&t=19113
I am ripping 4K using DVDFab right now! Thanks so much!
