ImgBurn Error - "Power On, Reset, or Bus Device Reset Occurred"
Apollo11
Re: ImgBurn Error - "Power On, Reset, or Bus Device Reset Occurred"
#16 Post by Apollo11 » Tue Nov 07, 2023 8:39 pm
Coopervid wrote:
Tue Nov 07, 2023 8:36 pm
Sure you can.
Ok, wasn't sure.
PC:
- Desktop: i7-9700K with RTX 2080 8GB w/ Windows 10 Home 64-bit.
- Laptop 1: i7-12700H with RTX 3060 w/ Debian 12 Bookworm + GNOME.
- Laptop 2: i5-7300HQ with GTX 1050 4GB w/ Windows 10 Home 64-bit.
Blu-Ray drive: Pioneer BDR-UD04 v1.14 Firmware.
Apollo11
#17 Post by Apollo11 » Tue Nov 07, 2023 9:13 pm
I followed the "IMGBURN setting" section of the first post; when I started the burn one info prompt was this:
I 21:39:57 Hardware Defect Management Active: No
Does this just mean that "Hardware Defect Management" was not needed when I initialized the burn?
PC:
#18 Post by Coopervid » Tue Nov 07, 2023 9:30 pm
No hardware management is default. Since the disc quality is going south recently you should use it. Be aware that it reduces the amount of space that can be burned to a disc. My advice: Store on hard disc and not on optical media in the future.
EDIT: I think you didn't follow the guide correctly. You should have the guide open and follow the guide in parallel.
Apollo11
#19 Post by Apollo11 » Tue Nov 07, 2023 9:40 pm
Ok, will try again.
PC:
Apollo11
#20 Post by Apollo11 » Tue Nov 07, 2023 11:32 pm
I found out what I did wrong; I did not jump to the "Creation of the Spare Area"-section of the guide. Now I got the right message:
I 00:20:36 Hardware Defect Management Active: Yes
In review (for Pioneer BDR-UD04):
  1. Follow "IMGBURN setting"-section.
  2. Skip "Special drive settings" and "2. LITE-ON"-section.
  3. Follow "Creation of the Spare Area" and "Burn the media"-section.
PC:
#21 Post by Coopervid » Tue Nov 07, 2023 11:35 pm
It takes a long time, yes. Did it work now?
Apollo11
#22 Post by Apollo11 » Tue Nov 07, 2023 11:41 pm
Still running the write and it's about 2023-11-08 00:41 CET for me as of writing this.
PC:
#23 Post by Coopervid » Tue Nov 07, 2023 11:45 pm
Be patient. If it works you have a perfect copy.
Apollo11
#24 Post by Apollo11 » Wed Nov 08, 2023 1:23 am
Qapla':
I 23:20:20 ImgBurn Version 2.5.8.0 started!
I 23:20:20 Microsoft Windows 8 Core x64 Edition (6.2, Build 9200)
I 23:20:20 Total Physical Memory: 16 710 120 KiB  -  Available: 10 640 728 KiB
I 23:20:20 Initialising SPTI...
I 23:20:20 Searching for SCSI / ATAPI devices...
I 23:20:21 -> Drive 1 - Info: PIONEER BD-RW   BDR-UD04 1.14-GENERAL (J:) (USB 2.0)
I 23:20:21 Found 1 BD-RE XL!
I 23:31:07 Operation Started!
I 23:31:07 Device: [0:0:0] PIONEER BD-RW   BDR-UD04 1.14 (J:) (USB)
I 23:31:07 Media Type: BD-R (Disc ID: VERBAT-IMf-000)
I 23:31:07 Media Supported Write Speeds: 2x; 4x; 6x
I 23:31:07 Quick Erase: No
I 23:31:07 Format Properly: Yes
I 23:31:07 Format Size: Preferred
I 23:31:07 Format Without Spare Areas: No
I 23:31:08 Erasing Disc...
I 23:31:31 Operation Successfully Completed! - Duration: 00:00:23
I 23:34:35 Operation Started!
I 23:34:35 Building Image Tree...
I 23:34:35 Calculating Totals...
I 23:34:35 Preparing Image...
I 23:34:35 Contents: 33 Files, 5 Folders
I 23:34:35 Content Type: Data
I 23:34:35 Data Type: MODE1/2048
I 23:34:36 File System(s): UDF (2.50)
I 23:34:36 Volume Label: The_Sixties_The_Seventies_Miniseries
I 23:34:36 Size: 43 595 952 718 bytes
I 23:34:36 Sectors: 21 287 104
I 23:34:36 Image Size: 43 597 037 568 bytes
I 23:34:36 Image Sectors: 21 287 616
I 23:34:44 Operation Successfully Completed! - Duration: 00:00:09
I 23:34:44 Operation Started!
I 23:34:44 Image Contents: 33 Files, 5 Folders
I 23:34:44 Image Sectors: 21 287 616 (MODE1/2048)
I 23:34:44 Image Size: 43 597 037 568 bytes
I 23:34:44 Image Volume Identifier: The_Sixties_The_Seventies_Miniseries
I 23:34:44 Image Volume Set Identifier: 5767BC510144D240
I 23:34:44 Image Application Identifier: ImgBurn v2.5.8.0
I 23:34:44 Image Implementation Identifier: ImgBurn
I 23:34:44 Image File System(s): UDF (2.50)
I 23:34:44 Destination File: I:\The_Sixties_The_Seventies_Miniseries.iso
I 23:34:44 Destination Free Space: 1 970 463 571 968 Bytes (1 924 280 832,00 KiB) (1 879 180,50 MiB) (1 835,14 GiB)
I 23:34:44 Destination File System: EXFAT
I 23:34:44 File Splitting: Auto
I 23:34:45 Writing Image...
I 00:19:25 Operation Successfully Completed! - Duration: 00:44:41
I 00:19:25 Average Write Rate: 15 880 KiB/s (3.6x) - Maximum Write Rate: 33 054 KiB/s (7.5x)
I 00:20:35 Operation Started!
I 00:20:35 Source File: I:\The_Sixties_The_Seventies_Miniseries.iso
I 00:20:35 Source File Sectors: 21 287 616 (MODE1/2048)
I 00:20:35 Source File Size: 43 597 037 568 bytes
I 00:20:36 Source File Volume Identifier: The_Sixties_The_Seventies_Miniseries
I 00:20:36 Source File Volume Set Identifier: 5767BC510144D240
I 00:20:36 Source File Application Identifier: ImgBurn v2.5.8.0
I 00:20:36 Source File Implementation Identifier: ImgBurn
I 00:20:36 Source File File System(s): UDF (2.50)
I 00:20:36 Destination Device: [0:0:0] PIONEER BD-RW   BDR-UD04 1.14 (J:) (USB)
I 00:20:36 Destination Media Type: BD-R (Disc ID: VERBAT-IMf-000)
I 00:20:36 Destination Media Supported Write Speeds: 2x; 4x; 6x
I 00:20:36 Destination Media Sectors: 23 652 352
I 00:20:36 Write Mode: BD
I 00:20:36 Write Type: DAO
I 00:20:36 Write Speed: MAX
I 00:20:36 BD-R Verify Not Required: No
I 00:20:36 Link Size: Auto
I 00:20:36 Lock Volume: Yes
I 00:20:36 Test Mode: No
I 00:20:36 OPC: Yes
I 00:20:36 BURN-Proof: Enabled
I 00:20:36 Write Speed Successfully Set! - Effective: 26 970 KB/s (6x)
I 00:20:36 Advanced Settings - Optimal Writing Speed: No
I 00:20:56 Filling Buffer... (80 MiB)
I 00:20:59 Writing LeadIn...
I 00:21:02 Writing Session 1 of 1... (1 Track, LBA: 0 - 21287615)
I 00:21:02 Writing Track 1 of 1... (MODE1/2048, LBA: 0 - 21287615)
I 00:21:02 Writing Layer 0... (LBA: 0 - 12219391)
I 01:10:18 Writing Layer 1... (LBA: 12219392 - 21287615)
I 01:43:13 Synchronising Cache...
I 01:43:14 Closing Track...
I 01:43:15 Finalising Disc...
I 01:43:31 Exporting Graph Data...
I 01:43:31 Graph Data File: C:\Users\alexl\AppData\Roaming\ImgBurn\Graph Data Files\PIONEER_BD-RW_BDR-UD04_1.14_DEN-8-NOVEMBER-2023_00-20_VERBAT-IMf-000_MAX.ibg
I 01:43:31 Export Successfully Completed!
I 01:43:31 Operation Successfully Completed! - Duration: 01:22:55
I 01:43:31 Average Write Rate: 8 635 KiB/s (2.0x) - Maximum Write Rate: 11 604 KiB/s (2.6x)
I 01:43:31 Cycling Tray before Verify...
W 01:43:50 Waiting for device to become ready...
I 01:43:57 Device Ready!
I 01:43:59 Operation Started!
I 01:43:59 Source Device: [0:0:0] PIONEER BD-RW   BDR-UD04 1.14 (J:) (USB)
I 01:43:59 Source Media Type: BD-R (Disc ID: VERBAT-IMf-000)
I 01:43:59 Source Media Supported Read Speeds: 6x
I 01:43:59 Source Media Supported Write Speeds: 2x; 4x; 6x
I 01:43:59 Source Media Sectors: 21 287 616
I 01:43:59 Source Media Size: 43 597 037 568 bytes
I 01:43:59 Image File: I:\The_Sixties_The_Seventies_Miniseries.iso
I 01:43:59 Image File Sectors: 21 287 616 (MODE1/2048)
I 01:43:59 Image File Size: 43 597 037 568 bytes
I 01:43:59 Image File Volume Identifier: The_Sixties_The_Seventies_Miniseries
I 01:43:59 Image File Volume Set Identifier: 5767BC510144D240
I 01:43:59 Image File Application Identifier: ImgBurn v2.5.8.0
I 01:43:59 Image File Implementation Identifier: ImgBurn
I 01:43:59 Image File File System(s): UDF (2.50)
I 01:43:59 Read Speed (Data/Audio): MAX / MAX
I 01:44:00 Read Speed - Effective: 2,5x - 6x
I 01:44:00 Verifying Session 1 of 1... (1 Track, LBA: 0 - 21287615)
I 01:44:00 Verifying Track 1 of 1... (MODE1/2048, LBA: 0 - 21287615)
I 01:44:00 Verifying Layer 0... (LBA: 0 - 12219391)
I 02:04:40 Verifying Layer 1... (LBA: 12219392 - 21287615)
I 02:18:34 Exporting Graph Data...
I 02:18:35 Graph Data File: C:\Users\alexl\AppData\Roaming\ImgBurn\Graph Data Files\PIONEER_BD-RW_BDR-UD04_1.14_DEN-8-NOVEMBER-2023_00-20_VERBAT-IMf-000_MAX.ibg
I 02:18:35 Export Successfully Completed!
I 02:18:35 Operation Successfully Completed! - Duration: 00:34:34
I 02:18:35 Average Verify Rate: 20 537 KiB/s (4.7x) - Maximum Verify Rate: 27 538 KiB/s (6.3x)
PC:
