ImgBurn Error - "Power On, Reset, or Bus Device Reset Occurred"
Apollo11
Post by Apollo11 »
Since my application to join the ImgBurn forums hasn't gone through yet I'll ask here as it concerns my Pioneer BDR-UD04 drive.
I'm having a lot of trouble writing an ISO file for archiving purposes to a BD-R DL M-Disc (50GB) using ImgBurn. The discs are all Verbatim discs.
I get a bunch of "Power On, Reset, or Bus Device Reset Occurred" messages. So far it has prevented me from writing the ISO file to two different M-Discs of the same capacity (the ISO file is less than 50GB).
I have checked that the USB cable for my Pioneer BDR-UD04 is not loose. Windows 10 has no problem detecting the drive or the disc in it. And yes; my disc drive can also burn to M-Disc, Blu-Ray and DVD.
Can someone assist me? I don't want to risk using up any more M-Discs before I have a better idea of what's wrong.
Below is the ImgBurn log file for the event in question:
I 09:35:20 ImgBurn Version 2.5.8.0 started!
I 09:35:20 Microsoft Windows 8 Core x64 Edition (6.2, Build 9200)
I 09:35:20 Total Physical Memory: 16 710 120 KiB  -  Available: 9 983 400 KiB
I 09:35:20 Initialising SPTI...
I 09:35:20 Searching for SCSI / ATAPI devices...
I 09:35:20 -> Drive 1 - Info: PIONEER BD-RW   BDR-UD04 1.14-GENERAL (J:) (USB 2.0)
I 09:35:20 Found 1 BD-RE XL!
I 09:37:07 Operation Started!
I 09:37:07 Source File: I:\The_Sixties_The_Seventies_The_Eighties_Miniseries.iso
I 09:37:07 Source File Sectors: 23 771 872 (MODE1/2048)
I 09:37:07 Source File Size: 48 684 793 856 bytes
I 09:37:07 Source File Volume Identifier: The_Sixties_The_Seventies_The_Eighties_Miniseries
I 09:37:07 Source File Volume Set Identifier: 57670649016ABA6D
I 09:37:07 Source File Application Identifier: ImgBurn v2.5.8.0
I 09:37:07 Source File Implementation Identifier: ImgBurn
I 09:37:07 Source File File System(s): UDF (2.50)
I 09:37:07 Destination Device: [0:0:0] PIONEER BD-RW   BDR-UD04 1.14 (J:) (USB)
I 09:37:07 Destination Media Type: BD-R (Disc ID: VERBAT-IMf-000)
I 09:37:08 Destination Media Supported Write Speeds: 2x; 4x; 6x
I 09:37:08 Destination Media Sectors: 24 438 784
I 09:37:08 Write Mode: BD
I 09:37:08 Write Type: DAO
I 09:37:08 Write Speed: MAX
I 09:37:08 Hardware Defect Management Active: No
I 09:37:08 BD-R Verify Not Required: Yes
I 09:37:08 Link Size: Auto
I 09:37:08 Lock Volume: Yes
I 09:37:08 Test Mode: No
I 09:37:08 OPC: No
I 09:37:08 BURN-Proof: Enabled
I 09:37:08 Write Speed Successfully Set! - Effective: 26 970 KB/s (6x)
I 09:37:08 Advanced Settings - Optimal Writing Speed: No
I 09:37:08 Filling Buffer... (80 MiB)
I 09:37:10 Writing LeadIn...
I 09:37:38 Writing Session 1 of 1... (1 Track, LBA: 0 - 23771871)
I 09:37:38 Writing Track 1 of 1... (MODE1/2048, LBA: 0 - 23771871)
I 09:37:38 Writing Layer 0... (LBA: 0 - 12219391)
W 09:39:30 Failed to Write Sectors 655104 - 655135 - Reason: Power On, Reset, or Bus Device Reset Occurred
W 09:39:30 Retrying (1 of 20)...
W 09:39:45 Retry Failed - Reason: Not Ready To Ready Change - Medium May Have Changed
W 09:39:45 Retrying (2 of 20)...
W 09:39:47 Retry Failed - Reason: Invalid Address For Write
W 09:39:47 Retrying (3 of 20)...
W 09:39:47 Retrying (4 of 20)...
W 09:39:47 Retrying (5 of 20)...
W 09:39:47 Retrying (6 of 20)...
W 09:39:47 Retrying (7 of 20)...
W 09:39:47 Retrying (8 of 20)...
W 09:39:47 Retrying (9 of 20)...
W 09:39:47 Retrying (10 of 20)...
W 09:39:47 Retrying (11 of 20)...
W 09:39:47 Retrying (12 of 20)...
W 09:39:47 Retrying (13 of 20)...
W 09:39:47 Retrying (14 of 20)...
W 09:39:47 Retrying (15 of 20)...
W 09:39:47 Retrying (16 of 20)...
W 09:39:47 Retrying (17 of 20)...
W 09:39:47 Retrying (18 of 20)...
W 09:39:47 Retrying (19 of 20)...
W 09:39:47 Retrying (20 of 20)...
W 09:40:02 Retrying (21)...
W 09:40:02 Retry Failed - Reason: Invalid Address For Write
E 09:40:13 Failed to Write Sectors 655104 - 655135 - Reason: Power On, Reset, or Bus Device Reset Occurred
E 09:40:13 Next Writable Address: 654272
I 09:40:13 Synchronising Cache...
W 09:40:20 User opted to skip the 'Close Track/Session/Disc' functions.
E 09:40:20 Failed to Write Image!
I 09:40:20 Exporting Graph Data...
I 09:40:20 Graph Data File: C:\Users\alexl\AppData\Roaming\ImgBurn\Graph Data Files\PIONEER_BD-RW_BDR-UD04_1.14_DEN-7-NOVEMBER-2023_09-37_VERBAT-IMf-000_MAX.ibg
I 09:40:20 Export Successfully Completed!
E 09:40:20 Operation Failed! - Duration: 00:03:13
I 09:40:20 Average Write Rate: 8 452 KiB/s (1.9x) - Maximum Write Rate: 12 887 KiB/s (2.9x)
PC:
- Desktop: i7-9700K with RTX 2080 8GB w/ Windows 10 Home 64-bit.
- Laptop 1: i7-12700H with RTX 3060 w/ Debian 12 Bookworm + GNOME.
- Laptop 2: i5-7300HQ with GTX 1050 4GB w/ Windows 10 Home 64-bit.
Blu-Ray drive: Pioneer BDR-UD04 v1.14 Firmware.
Re: ImgBurn Error - "Power On, Reset, or Bus Device Reset Occurred"
Make sure the drive gets enough power. Use the rear USB-C of a desktop PC or use a powered USB hub.
In addition check that. Disc quality has gone south recently:
https://forum.redfox.bz/threads/the-lon ... -tl.86133/
Apollo11
Post by Apollo11 »
Coopervid wrote:
Tue Nov 07, 2023 6:10 pm
I am using the rear USB-C port on my desktop. I will try the link you provided.
PC:
Apollo11
Post by Apollo11 »
Do I really need an account on the linked-to forum just to view the screenshots? I don't want to set up an account just to resolve one issue.
PC:
I don't think so. This should be possible as a guest.
EDIT: Yes, you need to be a member to see the pictures.
Apollo11
Post by Apollo11 »
There's no other guide without this requirement for this case?
PC:
It doesn't hurt to open an account even if you never come back.
Apollo11
Post by Apollo11 »
Coopervid wrote:
Tue Nov 07, 2023 7:31 pm
I'll try it.
PC:
Apollo11
Post by Apollo11 »
Under the "Special Drive Settings" in the linked-to guide I can't find the right "Drive Utility" software for my BDR-UD04 (I searched with Ctrl+F) and didn't find anything that seemed to match.
What should I do?
PC:
The UD04 doesn't have a utility. You are supposed to use the spare areas as outlined in the guide. Any of the utilities for the other drives wouldn't help either in your case.
Apollo11
Post by Apollo11 »
Coopervid wrote:
Tue Nov 07, 2023 8:27 pm
Ok, should I follow the "2. LITE-ON" section too? The "Drive" option under "Tools" in ImgBurn is grayed out for me.
PC:
Nah, you don't have a LiteON. Do the main steps and forget about the manufacturer options.
Apollo11
Post by Apollo11 »
Coopervid wrote:
Tue Nov 07, 2023 8:32 pm
Ok, thanks! Will return once results are in. I can afford new Verbatim M-Discs; I just don't wan't to buy them when not necessary.
PC:
Apollo11
Post by Apollo11 »
Can I still use the ISO file I created earlier that I intended to write (and still do)?
PC:
Sure you can.
