ImgBurn Error - "Power On, Reset, or Bus Device Reset Occurred"
Apollo11
#1 Post by Apollo11 » Tue Nov 07, 2023 5:55 pm
Since my application to join the ImgBurn forums hasn't gone through yet I'll ask here as it concerns my Pioneer BDR-UD04 drive.
I'm having a lot of trouble writing an ISO file for archiving purposes to a BD-R DL M-Disc (50GB) using ImgBurn. The discs are all Verbatim discs.
I get a bunch of "Power On, Reset, or Bus Device Reset Occurred" messages. So far it has prevented me from writing the ISO file to two different M-Discs of the same capacity (the ISO file is less than 50GB).
I have checked that the USB cable for my Pioneer BDR-UD04 is not loose. Windows 10 has no problem detecting the drive or the disc in it. And yes; my disc drive can also burn to M-Disc, Blu-Ray and DVD.
Can someone assist me? I don't want to risk using up any more M-Discs before I have a better idea of what's wrong.
Below is the ImgBurn log file for the event in question:
I 09:35:20 ImgBurn Version 2.5.8.0 started!
I 09:35:20 Microsoft Windows 8 Core x64 Edition (6.2, Build 9200)
I 09:35:20 Total Physical Memory: 16 710 120 KiB  -  Available: 9 983 400 KiB
I 09:35:20 Initialising SPTI...
I 09:35:20 Searching for SCSI / ATAPI devices...
I 09:35:20 -> Drive 1 - Info: PIONEER BD-RW   BDR-UD04 1.14-GENERAL (J:) (USB 2.0)
I 09:35:20 Found 1 BD-RE XL!
I 09:37:07 Operation Started!
I 09:37:07 Source File: I:\The_Sixties_The_Seventies_The_Eighties_Miniseries.iso
I 09:37:07 Source File Sectors: 23 771 872 (MODE1/2048)
I 09:37:07 Source File Size: 48 684 793 856 bytes
I 09:37:07 Source File Volume Identifier: The_Sixties_The_Seventies_The_Eighties_Miniseries
I 09:37:07 Source File Volume Set Identifier: 57670649016ABA6D
I 09:37:07 Source File Application Identifier: ImgBurn v2.5.8.0
I 09:37:07 Source File Implementation Identifier: ImgBurn
I 09:37:07 Source File File System(s): UDF (2.50)
I 09:37:07 Destination Device: [0:0:0] PIONEER BD-RW   BDR-UD04 1.14 (J:) (USB)
I 09:37:07 Destination Media Type: BD-R (Disc ID: VERBAT-IMf-000)
I 09:37:08 Destination Media Supported Write Speeds: 2x; 4x; 6x
I 09:37:08 Destination Media Sectors: 24 438 784
I 09:37:08 Write Mode: BD
I 09:37:08 Write Type: DAO
I 09:37:08 Write Speed: MAX
I 09:37:08 Hardware Defect Management Active: No
I 09:37:08 BD-R Verify Not Required: Yes
I 09:37:08 Link Size: Auto
I 09:37:08 Lock Volume: Yes
I 09:37:08 Test Mode: No
I 09:37:08 OPC: No
I 09:37:08 BURN-Proof: Enabled
I 09:37:08 Write Speed Successfully Set! - Effective: 26 970 KB/s (6x)
I 09:37:08 Advanced Settings - Optimal Writing Speed: No
I 09:37:08 Filling Buffer... (80 MiB)
I 09:37:10 Writing LeadIn...
I 09:37:38 Writing Session 1 of 1... (1 Track, LBA: 0 - 23771871)
I 09:37:38 Writing Track 1 of 1... (MODE1/2048, LBA: 0 - 23771871)
I 09:37:38 Writing Layer 0... (LBA: 0 - 12219391)
W 09:39:30 Failed to Write Sectors 655104 - 655135 - Reason: Power On, Reset, or Bus Device Reset Occurred
W 09:39:30 Retrying (1 of 20)...
W 09:39:45 Retry Failed - Reason: Not Ready To Ready Change - Medium May Have Changed
W 09:39:45 Retrying (2 of 20)...
W 09:39:47 Retry Failed - Reason: Invalid Address For Write
W 09:39:47 Retrying (3 of 20)...
W 09:39:47 Retrying (4 of 20)...
W 09:39:47 Retrying (5 of 20)...
W 09:39:47 Retrying (6 of 20)...
W 09:39:47 Retrying (7 of 20)...
W 09:39:47 Retrying (8 of 20)...
W 09:39:47 Retrying (9 of 20)...
W 09:39:47 Retrying (10 of 20)...
W 09:39:47 Retrying (11 of 20)...
W 09:39:47 Retrying (12 of 20)...
W 09:39:47 Retrying (13 of 20)...
W 09:39:47 Retrying (14 of 20)...
W 09:39:47 Retrying (15 of 20)...
W 09:39:47 Retrying (16 of 20)...
W 09:39:47 Retrying (17 of 20)...
W 09:39:47 Retrying (18 of 20)...
W 09:39:47 Retrying (19 of 20)...
W 09:39:47 Retrying (20 of 20)...
W 09:40:02 Retrying (21)...
W 09:40:02 Retry Failed - Reason: Invalid Address For Write
E 09:40:13 Failed to Write Sectors 655104 - 655135 - Reason: Power On, Reset, or Bus Device Reset Occurred
E 09:40:13 Next Writable Address: 654272
I 09:40:13 Synchronising Cache...
W 09:40:20 User opted to skip the 'Close Track/Session/Disc' functions.
E 09:40:20 Failed to Write Image!
I 09:40:20 Exporting Graph Data...
I 09:40:20 Graph Data File: C:\Users\alexl\AppData\Roaming\ImgBurn\Graph Data Files\PIONEER_BD-RW_BDR-UD04_1.14_DEN-7-NOVEMBER-2023_09-37_VERBAT-IMf-000_MAX.ibg
I 09:40:20 Export Successfully Completed!
E 09:40:20 Operation Failed! - Duration: 00:03:13
I 09:40:20 Average Write Rate: 8 452 KiB/s (1.9x) - Maximum Write Rate: 12 887 KiB/s (2.9x)
PC:
- Desktop: i7-9700K with RTX 2080 8GB w/ Windows 10 Home 64-bit.
- Laptop 1: i7-12700H with RTX 3060 w/ Debian 12 Bookworm + GNOME.
- Laptop 2: i5-7300HQ with GTX 1050 4GB w/ Windows 10 Home 64-bit.
Blu-Ray drive: Pioneer BDR-UD04 v1.14 Firmware.
Re: ImgBurn Error - "Power On, Reset, or Bus Device Reset Occurred"
#2 Post by Coopervid » Tue Nov 07, 2023 6:10 pm
Make sure the drive gets enough power. Use the rear USB-C of a desktop PC or use a powered USB hub.
In addition check that. Disc quality has gone south recently:
https://forum.redfox.bz/threads/the-lon ... -tl.86133/
Apollo11
#3 Post by Apollo11 » Tue Nov 07, 2023 6:59 pm
I am using the rear USB-C port on my desktop. I will try the link you provided.
PC:
Apollo11
#4 Post by Apollo11 » Tue Nov 07, 2023 7:07 pm
Do I really need an account on the linked-to forum just to view the screenshots? I don't want to set up an account just to resolve one issue.
PC:
#5 Post by Coopervid » Tue Nov 07, 2023 7:14 pm
I don't think so. This should be possible as a guest.
EDIT: Yes, you need to be a member to see the pictures.
Apollo11
#6 Post by Apollo11 » Tue Nov 07, 2023 7:21 pm
There's no other guide without this requirement for this case?
PC:
#7 Post by Coopervid » Tue Nov 07, 2023 7:31 pm
It doesn't hurt to open an account even if you never come back.
Apollo11
#8 Post by Apollo11 » Tue Nov 07, 2023 7:59 pm
I'll try it.
PC:
Apollo11
#9 Post by Apollo11 » Tue Nov 07, 2023 8:17 pm
Under the "Special Drive Settings" in the linked-to guide I can't find the right "Drive Utility" software for my BDR-UD04 (I searched with Ctrl+F) and didn't find anything that seemed to match.
What should I do?
PC:
#10 Post by Coopervid » Tue Nov 07, 2023 8:27 pm
The UD04 doesn't have a utility. You are supposed to use the spare areas as outlined in the guide. Any of the utilities for the other drives wouldn't help either in your case.
Apollo11
#11 Post by Apollo11 » Tue Nov 07, 2023 8:29 pm
Ok, should I follow the "2. LITE-ON" section too? The "Drive" option under "Tools" in ImgBurn is grayed out for me.
PC:
#12 Post by Coopervid » Tue Nov 07, 2023 8:32 pm
Nah, you don't have a LiteON. Do the main steps and forget about the manufacturer options.
Apollo11
#13 Post by Apollo11 » Tue Nov 07, 2023 8:34 pm
Ok, thanks! Will return once results are in. I can afford new Verbatim M-Discs; I just don't wan't to buy them when not necessary.
PC:
Apollo11
#14 Post by Apollo11 » Tue Nov 07, 2023 8:35 pm
Can I still use the ISO file I created earlier that I intended to write (and still do)?
PC:
#15 Post by Coopervid » Tue Nov 07, 2023 8:36 pm
Sure you can.
