Transformers Rise of the beasts 4K not decoding
scott1971
Post by scott1971 »
Hello All.
I've been using makeMKV successfully without fail for years now. This is the first 4K title I have had fail on me.
I've tried all the usual, clean the drive, reinstall software, restart ect but to no avail. So after around 10 attempts I am posting here to see if anyone else has had the same error:
MakeMKV produced a dump file of which this is the log file below: The title is my own purchase. Any help would be most appreciated. Many thanks in advance.
Scott
Debug log started at Tue Nov 07 11:04:56 2023 , written by MakeMKV v1.17.5 win(x64-release)
001005:0000 MakeMKV v1.17.5 win(x64-release) started
DEBUG: Code 0 at ]K}<{g 5\^[xCzt/:213144750
DEBUG: Code 3 at p#THBi/ll*BA2gQ6"dN^+C5W:29395310
SDF  v098: ASUS_BW-16D1HT_3.10_211901041014_SIK9QH6KB093
001011:0000 Using LibreDrive mode (v06.3 id=0FA242DD4D0B)
DEBUG: Code 2147483648 at ]K}<{g 5\^[xCzt/:121265499
scott1971
Re: Transformers Rise of the beasts 4K not decoding
Post by scott1971 »
OK so for those who might have a similar issue, after some searching through the forums and removing my bitdefender I discovered that it was an ISP issue.
I disconnected from my home internet connection and hooked up to my mobile hotspot.
Hey presto new hkdata was downloaded when I booted makeMKV, and the title has decrypted successfully.
lfoust
Post by lfoust »
Here is how this disc layed out for me: https://thediscdb.com/movie/transformer ... es/2023-4k
Buzzlite1926
Post by Buzzlite1926 »
I keep getting this
MKB20 76 The Transformers- The_ Movie_B43B.taz
Radiocomms237
Post by Radiocomms237 »
"Transformers: The Movie" is a different title altogether to "Transformers: Rise Of The Beasts" (which is the subject of this thread).
However, I see you created another thread just after this here so I assume the question has been answered?
rogar50
Post by rogar50 »
any one have a fix for this. bought amazon copy of this and its not decoding. just keep running to around 20 minutes till done and then shoots up to 2 hours and keeps climbing
