Debug Errors
Elephen
Debug Errors
Post by Elephen » Mon Nov 06, 2023 9:12 pm
When attempting to rip "The Private War of Major Benson" from a new DVD to my server, I immediately received debug errors. Please see attachment.
I am using MakeMKV v1.17.5 darwin(arm64-release) and a new BD drive that I purchased about 3 weeks ago. Until now, MakeMKV and the BD drive have been working perfectly. I hope someone can help. Thanks.
MakeMKV_log.txt
(1.6 KiB) Downloaded 425 times
Re: Debug Errors
Post by dcoke22 » Tue Nov 07, 2023 1:30 am
Debug log started at Mon Nov  6 20:36:17 2023 , written by MakeMKV v1.17.5 darwin(arm64-release)
001005:0000 MakeMKV v1.17.5 darwin(arm64-release) started
001004:0000 Debug logging enabled, log will be saved as file:///Users/leonolan/MakeMKV_log.txt
Network access is ENABLED, CURL version 8.1.2/(SecureTransport) LibreSSL/3.3.6/1.55.1 (x86_64-apple-darwin23.0) , proxy server not set.
002010:0000 Optical drive "BD-RE PIONEER BD-RW   BDR-212U 1.01 ALDL016790WLd" opened in OS access mode.
SDF  v098: PIONEER_BD-RW___BDR-212U_1.01_ALDL016790WL
001012:0000 udf: udf_get_node: bad allocation extension size in udf_node
001003:0020 DEBUG: Code 0 at "DC$ZPPUj'4(Pk$|':213130283
001011:0000 Using LibreDrive mode (v01.0 id=DFAA920B9011)
003002:0000 Calculated BUP offset for VTS #0 does not match one in IFO header.
001003:0020 DEBUG: Code 32 at `F^O<l5YjlchkV:121273020
DEBUG: Code 0 at 9N]oitg)8:s[oV!Bh%r:121261704
001003:0020 DEBUG: Code 1 at ~ruUUA@I.dZOR+]yS:213131318
001001:0020 DBG ASSERT: *5[}%M;Wycg_u@\n~!4{W-pH>T]{_w(b{Oo at `F^O<l5YjlchkV:29402003
003002:0000 Calculated BUP offset for VTS #1 does not match one in IFO header.
001003:0020 DEBUG: Code 1 at `F^O<l5YjlchkV:213131755
Launching /Applications/MakeMKV.app/Contents/MacOS/mmgplsrv
001003:0020 DEBUG: Code 118095996 at 0X>|~W9\=nk_\FhYUKqH%,):29394183
001003:0020 DEBUG: Code 0 at 0X>|~W9\=nk_\FhYUKqH%,):121263590
001003:0020 DEBUG: Code 0 at F]9%:jD><kw%;hBY]9(%:29394689
What actually happens? Does MakeMKV not recognize the disc?
Elephen
Re: Debug Errors
Post by Elephen » Tue Nov 07, 2023 2:40 am
MakeMKV never opens the disk. The "time remaining" counter just keeps increasing. Thanks for responding.
I just put the disk into my Oppo 203. The movie starts immediately (that is, no need to hit "Play"). The disk seems to be fine.
Re: Debug Errors
Post by dcoke22 » Tue Nov 07, 2023 3:31 am
There are different opening modes for DVDs. DVD opening modes - CellWalk, CellTrim, CellFull
Sometimes using a different opening mode can help MakeMKV figure out a DVD.
Elephen
Re: Debug Errors
Post by Elephen » Tue Nov 07, 2023 11:27 am
I had success using CellTrim. Thanks for the advice.
