Singin' in the Rain 4K UHD Key Unknown
moviesarecooliguess
Post by moviesarecooliguess »
Getting this error for the filename MKB20_v76_Singin'_in_the_Rain_2D11.tgz when trying to open the disc:
MakeMKV v1.17.5 win(x64-release) started
Automatic checking for updates is enabled, you may disable it in preferences if you don't want MakeMKV to contact web server.
Using LibreDrive mode (v06.3 id=4FBA32AEC678)
Saved AACS dump file as C:\Users\x/.MakeMKV/MKB20_v76_Singin'_in_the_Rain_2D11.tgz
Re: Singin' in the Rain 4K UHD Key Unknown
And did you submit that created file to svq@makemkv.com so that it can be processed?
