Re: Flac in mp4 workflows
DjObama wrote:
Fri Nov 03, 2023 8:13 pm
Flac will be much smaller in size than LPCM, so less bandwidth used when plaing. Sometimes DV UHD movies stutter (nothing major, like 1-2 times per viewing) for me when played from external HDD, I suppose with flac it would be happening less. Especially if you'd add the option to convert to 16 bit flac instead of 24 bit. I think 16 is plenty enough. Dts-hd ma converted to 16 bit flac often take 1/4th of its original size, often less than DD+ @1,5mbps. And compared to eac3 flac is still a lossless file format = piece of mind for us audio- and vision nerds :)
Which playback device do you use? I just tried on my C2 and there's no direct play for FLAC/PCM, all I got was PLEX converting to DDP7.1 which is identical to my script.
DjObama
Post by DjObama »
RESET_9999 wrote:
Sat Nov 04, 2023 12:08 pm
LG B8. Flac works in mp4/mkv files in SDR. I don't know about DT-DL mp4s, for now I'm having troubles creating such files. Maybe you have a DV DT-DL sample with flac for testing?
ans40
Post by ans40 »
RESET_9999 wrote:
Sat Oct 14, 2023 1:35 pm
Trees wrote:
Sat Oct 14, 2023 8:41 am
Quick question; when generating CMv4.0 content (3-1), how does one determine what Mastering Display to use? I assuming higher isn't necessarily better?
2 options:
1- just use the static metadata from your source HDR10
2- check the brightness first with madvr. If 95% of the movie is under 1000nits, use 1000nits MDL else, 4000.
Option 2 is better because some movies have a static MDL of 4000nits but the actual brightness is under 1000nits.
A 4000nits RPU is a lot darker than a 1000nits one regardless of the content's actual brightness and in my opinion, 4000nits MDL + low nits content is wrong without L2 trim passes because if you look at the generated(or original) trims with a 4000nits analysis, they brighten/compensate a lot for the darkness a 4000 rpu brings.
https://slow.pics/c/uVX5iFOD
Hey @Reset_9999, I've hit a wall with a movie (Predators 2010) whose BL MDL is 1000nits, but measuring the BL shows most the MaxCLL over 1000 nits. I've tried fiddling with different settings (changing the DV Mastering Display and color space transforming mainly) in Resolve, but can't figure out how to generate a DV that doesn't cut off at 1000 nits. Any thoughts? https://slow.pics/c/BqRCdoHJ
Mattl0
Post by Mattl0 »
I believe here is a good place to ask.
What is the highest apl scene you have seen on a hdr movie? I mean with real data.
Mattl0
Post by Mattl0 »
I just bought a Sony a95k.
I only tested this on the vimu app.
The tv can read (and be set into ) dolby vision .mkv p7 dual layer single track p7.
The same does not work with .ts files.
Is there a short clip I can try to be know if the tv read the fel layer ? And also the rpu?
Thanks.
skull88
Post by skull88 »
ans40 wrote:
Sat Nov 04, 2023 7:35 pm
2 options:
Latest Dolby algo in Resolve with default tuning will not be identical to BL peaks, but slightly lower. Nothing wrong with your plot from what I can see.
use the old legacy mode if you want identical peaks to madvr measurements.. As @skull88 said, the new algo always produces lower values. it's less aggressive on the tone mapping(brighter).
Mattl0 wrote:
Sat Nov 04, 2023 7:37 pm
https://drive.google.com/drive/u/1/fold ... KFJwFxnDt-
DjObama wrote:
Sat Nov 04, 2023 1:10 pm
LG B8. Flac works
Ok, try the next version.
line 69 set encode_LL=NO
choices are NO or FLAC or LPCM (default=NO)
Mattl0
Post by Mattl0 »
I want to test an external streaming device on my tv for better fluidity.
For dv everything will be p5 , but it seems that no streamer can do tv led properly?
thirdmoon
Post by thirdmoon »
@RESET_9999
In the recent Black Hawk Down 4K, why are the brightness levels so high? As per my knowledge, no TV is capable of doing those levels. How does it impact viewing it in OLED with max brightness of 700-800nits?
Higher metadata brightness than your TV means more dimming and more tone mapping to preserve the highlights details.
While the shots peak brightness is very high, 86% of the shot's average brightness is under 25nits and 65% under 10nits.
thirdmoon
Post by thirdmoon »
My previous try for SDR to HDR was too dark. After a lot of trial and error, I have come up with this.
Children of Men 2006 - 1080p to 4K HDR (First 10mins)
simonhazel00
Post by simonhazel00 »
hello I've done some testing for dolby vision on devices for you reset.
toshiba 55UA3D63DB:
it supports profile 5, profile 8.1 in mp4 and mkv.
it playes the p7 fel st-dl and DT-Dl test clips and shows the text, brightness changes, but not the colours strobing and dolby vision isn't triggered either in ts or mp4.
the ts st-dl fel test track didn't show the brightness change, the strobing or the text and didn't show the dv logo
dune hd homatics box 4k plus:
unsure if this box has the fake TV led dolby vision issue however.
source led mode:
profile 7 fel
st-dl ts & mp4:
brightness change, strobing and text appeared correctly and triggered dv
DT-Dl ts:
brightness change, text appeared and dv triggered (no colour strobe)
DT-Dl mp4:
brightness change, colour strobing, text and dv logo
profile 8.1 works correctly in mp4 and mkv
profile 5 works correctly in mp4
player led mode:
profile 7 fel:
st-dl ts:
DT-Dl ts:
text and dv logo
st-dl and dt-dl mp4 :
profile 5 works in mp4 and 8.1 works correctly in mp4 and mkv.
unfortunately my TV doesn't have the hidden menu to look any further then that.
thirdmoon wrote:
Mon Nov 06, 2023 3:07 pm
Yes that's better than your sample from the other day. here's the original vs your conversion plot: https://slow.pics/c/81IGyAYq
I did this movie a while ago and IIRC, the BD SDR grade is not very good.
You'll notice that the SDR to HDR conversion works much better when the SDR grade is decent.
simonhazel00 wrote:
Mon Nov 06, 2023 3:15 pm
toshiba 55UA3D63DB:
source led mode:
profile 7 fel
st-dl ts & mp4:
DT-Dl ts:
DT-Dl mp4:
player led mode:
profile 7 fel:
st-dl ts:
DT-Dl ts:
text and dv logo
thanks for the tests. But wait the dune hd homatics box 4k plus supports FEL?
is that what you mean by: ''text appeared correctly''
