Libre Drive firmware for Product: BDDVDRW UH12LS29
nordstrom3025
Post by nordstrom3025 » Sun Nov 05, 2023 5:41 pm
is there a firmware available for this drive? Drive Information
Revision: 1.00
Serial number: [redacted]
Firmware date: 2011-08-09 12:34:56
Bus encryption flags: 1F
Highest AACS version: 76
Status: Possible, might be supported in future, but not likely soon
Drive platform: RS1013
Firmware version: 1.00-G0
If so can u link the post or the firmware itself in the is post I am new to makemkv so i just need a little help and also if u cant link it here or it does not exist who would i email to ask?
Re: Libre Drive firmware for Product: BDDVDRW UH12LS29
Post by Woodstock » Sun Nov 05, 2023 6:13 pm
Doubtful it would be of interest to update it. A drive that old is 5 years before UHD, so it would not gain any functionality over reading Blurays. Yours is actually 2 years newer than my drive in this computer.
But, like mine, you can use a USB drive to do newer disks, if you intend to. I've got newer drives I could put in this if I needed to, but I do ripping with a different computer, so I haven't bothered.
nordstrom3025
Post by nordstrom3025 » Mon Nov 06, 2023 5:45 am
I thought it would make the ripping faster becuase typically my drive does about 2-6x which i thoguht my was a 16x drive shouldnt it rip around 16x?
Post by Billycar11 » Mon Nov 06, 2023 6:19 am
nordstrom3025 wrote: Mon Nov 06, 2023 5:45 am I thought it would make the ripping faster becuase typically my drive does about 2-6x which i thoguht my was a 16x drive shouldnt it rip around 16x?
no it wont make it faster.
on lg/asus can go above the rated speeds
phoenixs4r
Post by phoenixs4r » Thu Nov 09, 2023 4:09 am
Woodstock wrote: Sun Nov 05, 2023 6:13 pm
Apparently nordstrom3025 and I both cleaned our garages this weekend. I found this drive in a bunch of stuff I'm throwing out.
Can I take from your comment this drive won't work for UHD? Toss it and buy a pre flashed drive? Apologies if noon question. I got out of the physical media game when Netflix came 'round. Would like to get back into it.
Post by Billycar11 » Thu Nov 09, 2023 1:01 pm
phoenixs4r wrote: Thu Nov 09, 2023 4:09 am
No pioneers that do UHD start on platform 8301 you have 1013 way to old
Post by dcoke22 » Thu Nov 09, 2023 2:13 pm
phoenixs4r wrote: Thu Nov 09, 2023 4:09 am Can I take from your comment this drive won't work for UHD? Toss it and buy a pre flashed drive? Apologies if noon question. I got out of the physical media game when Netflix came 'round. Would like to get back into it.
The drive will probably work for DVDs and regular blu-rays, even thought it won't work for UHDs. MakeMKV is pretty good and working with a wide range of optical drives. MakeMKV can work with multiple drives, even at the same time (turn on 'ask for single drive mode' in preferences).
