Release 1.17.5 starts having hash errors on UHD
beandog
Post by beandog » Sun Nov 05, 2023 11:32 pm
I installed 1.17.5 and tried ripping a few discs, and I've had three UHD discs that now have hash errors when ripping them. Specifically, Sonic 1, Sonic 2, and Spider-Verse 1.
I've tested this version and can duplicate it both on Windows and Linux.
Here's the output:
Product: BDDVDRW UH12NS40
Revision: 1.01
Serial number: K95I22H1711
Firmware date: 2117-11-23 15:50
Bus encryption flags: 16
Highest AACS version: 76
Firmware version: 1.01
Disc Information
Label: SONIC_THE_HEDGEHOG_2
Timestamp: 2022-06-10 11:43:15
Protection: AACS2.0/C v76
Data capacity: 60.3 Gb
Disc type: BD-ROM UHD
Number of layers: 2
Bus encryption flags: 80
Output:
MakeMKV v1.17.5 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\Steve/MakeMKV_log.txt
Using LibreDrive mode (v06.3 id=D45A94E46B24)
Backing up disc into folder "C:/Users/Steve/Videos/backup/SONIC_THE_HEDGEHOG"
Downloading latest HK to C:\Users\Steve/.MakeMKV ...
Hash check failed for file 00003.m2ts at offset 27210541056, file is corrupt.
Hash check failed for file 00003.m2ts at offset 27280533504, file is corrupt.
Hash check failed for file 00003.m2ts at offset 27567384576, file is corrupt.
Hash check failed for file 00003.m2ts at offset 27872323584, file is corrupt.
Hash check failed for file 00003.m2ts at offset 28120049664, file is corrupt.
Too many hash check errors in file 00003.m2ts.
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00003.m2ts' at offset '34313207808'
Failed to save title /BDMV/STREAM/00003.m2ts to file C:/Users/Steve/Videos/backup/SONIC_THE_HEDGEHOG/BDMV/STREAM/00003.m2ts
Encountered 7 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
Encountered 2996 errors of type 'HashCheck Error' - see http://www.makemkv.com/errors/hashcheck/...
Backup done but 1 files failed hash check
There aren't any problems on 1.17.4 though, so it's just this release.
Re: Release 1.17.5 starts having hash errors on UHD
Post by dcoke22 » Tue Nov 07, 2023 3:39 am
That error suggests the optical drive was unable to correctly read the disc.
I think I've only ripped two UHDs on 1.17.5, but both ripped without errors. One was a dual layer UHD, the other was a triple-layer disc.
beandog
Post by beandog » Tue Nov 07, 2023 10:46 pm
I would agree with you, but 1.17.4 works just fine.
Post by dcoke22 » Tue Nov 07, 2023 11:30 pm
beandog wrote: Tue Nov 07, 2023 10:46 pm I would agree with you, but 1.17.4 works just fine.
What does that imply? Does that mean a month or two ago, using 1.17.4, you were able to rip one or more of the discs that now fail? Or does that mean today (or yesterday, or sometime after the failures started) you have uninstalled 1.17.5, reinstalled 1.17.4, and successfully completed a rip?
If the former, I encourage you to do the later. If the later, then I would hope Mike (the program's author) would be interested in more details.
I'm a bit skeptical since the release of 1.17.5 hasn't created a noticeable spike in 'MakeMKV can't read my disc' forum posts. That is not to say, however, that there isn't something particular about your system that 1.17.5 tickles in the wrong way.
beandog
Post by beandog » Wed Nov 08, 2023 12:05 am
The second one. I tried 1.17.5, and some had hash issues (not all, just a few). I switched back to 1.17.4 same day, tried them, and they worked there.
I can provide more details if needed, I'd love to help out if I can.
Locutos
Post by Locutos » Sun Nov 12, 2023 5:20 pm
Unfortunately I have the same problem. I have 2 LG drives and always open 2 instances. In one instance this works perfectly, in the second I get read errors. This was not the case in 1.17.4.
Mouse
Post by Mouse » Wed Nov 15, 2023 1:25 am
Is Release 1.17.4 still available for download?
I'm on 1.17.5 and just had two discs with hash errors and I'd love to try the .4
Post by d00zah » Wed Nov 15, 2023 1:28 am
Mouse wrote: Wed Nov 15, 2023 1:25 am Is Release 1.17.4 still available for download?
https://www.makemkv.com/download/old/
Mouse
Post by Mouse » Wed Nov 15, 2023 6:01 am
So I tried 1.17.4 on a couple of discs that were having hash errors and still got the hash errors so I don't think 1.17.5 is the problem.
