Problem playing MKVs
nkhan
Post by nkhan »
I have just recenlt been having a problem playing most if not all my MKVs thru WD media player.
When you play a file, it seems to be Fast Forwarding and no audio, i change the audio from the menu and its ok for a few seconds and go back to like it is being fast forwarded.
Thank you in advance.
nkhan
Re: Problem playing MKVs
Post by nkhan »
Anybody else experience this
crowfax
Post by crowfax »
Yes, there is currently a problem with some MKV files that are created.
nkhan
Post by nkhan »
I tho it might be cos i am selecting lossless audio.
Is there a fix for this or do i need to make another MKV out of the disc.
crowfax
Post by crowfax »
You will have to wait until the next version and try again. Or you can roll back to 1.6.8 which should work fine:
http://www.makemkv.com/download/old/
nkhan
Post by nkhan »
Crowfax,
Has my above been fixed now or is a new version of MKV not out yet.
Sorry havent been keeping up to date.
crowfax
Post by crowfax »
Should all be fixed. I've not had any problems with 1.6.12.
You can download it here: http://www.makemkv.com/download/
