I have just recenlt been having a problem playing most if not all my MKVs thru WD media player.
When you play a file, it seems to be Fast Forwarding and no audio, i change the audio from the menu and its ok for a few seconds and go back to like it is being fast forwarded.
Thank you in advance.
Problem playing MKVs
Re: Problem playing MKVs
Anybody else experience this
Yes, there is currently a problem with some MKV files that are created.
I tho it might be cos i am selecting lossless audio.
Is there a fix for this or do i need to make another MKV out of the disc.
You will have to wait until the next version and try again. Or you can roll back to 1.6.8 which should work fine:
http://www.makemkv.com/download/old/
Crowfax,
Has my above been fixed now or is a new version of MKV not out yet.
Sorry havent been keeping up to date.
Should all be fixed. I've not had any problems with 1.6.12.
You can download it here: http://www.makemkv.com/download/
