I might need to do that. I think I was confused on the model numbers thinking all the 212 models were basically the same, but this one appears to be a DBK model and not the UBK model. It was fairly cheap though, and the seller confirmed it is the 1.0 firmware which is well before 12/22.Billycar11 wrote: Mon Oct 30, 2023 6:34 pmNo major advantage long as it's a UHD model it should work and if it's not you can email me for a cross flash kit if it's before 12-22billbillw wrote: Mon Oct 30, 2023 5:09 pm Just making sure, a Pioneer BDR-212 built in 2019 with original 1.0 firmware should be a workable unit for UHD discs? Is there any advantage of upgrading it to one of the pre-12/2022 firmwares?
EDIT: The more I am reading, the more I'm afraid this was a bad purchase if I want to read UHD...SMH.
