Pioneer BDR-209 Support
MadMopar
Post by MadMopar »
I'm new here and haven't been able to find info or update these drives (I have 2) that I pulled out of ASUS enclosures. I am using eSata enclosures from NextStar.
I am attaching info from MakeMKV.
Thanks for any help. Tried to search and got no results.
Pioneer BDR-209 Info.jpg (61.03 KiB) Viewed 38703 times
Re: Pioneer BDR-209 Support
What reason do you need to "update" this drive? It already supports everything MakeMKV can get out it, and the latest Pioneer updates are killing the drives for ripping.
This actually can be flashed to do 4K it's just not available yet your going to just have to wait for a bit
MadMopar
Post by MadMopar »
Woodstock wrote: Sat Mar 11, 2023 11:01 pm What reason do you need to "update" this drive? It already supports everything MakeMKV can get out it, and the latest Pioneer updates are killing the drives for ripping.
Because it doesn't handle 4K. I've already tried.
Billycar11 wrote: Sat Mar 11, 2023 11:15 pm This actually can be flashed to do 4K it's just not available yet your going to just have to wait for a bit
Thanks. I'll be a waiitn'. Is there some way that I could put myself on a list to be notified or where would I find the update?
Jman9980
Re: ASUS BW-16D1X-U Pioneer BDR-209 Support
Post by Jman9980 »
Hello, Has there been an update for this drive support that I missed? It will not handle UHD at the moment.
And yes, I have been searching the form for this. And also, sorry if I come off as rude. Its just me. I get teased about it at work. they call me Data and keep me on 3rd level support, far away from the customer.
If possible, I would like to open this drive. Wish I knew how to alter the BIN files.
Either way, the drive info in question is :
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E111
Firmware date: 2017-12-21
Highest AACS version: 68
Drive platform: RS8601
Firmware version: E111/ID76
Jman9980 wrote: Sat Apr 29, 2023 9:15 pm Hello, Has there been an update for this drive support that I missed? It will not handle UHD at the moment.
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E111
Email me about my $25 pioneer flasher I maybe able to help
There is no public way of doing this
wotdefcuk
Post by wotdefcuk »
I am new to ripping 4k disks too.
Here the info for my drive.
Manufacturer: PIONEER
Product: BD-RW BDR-209D
Revision: 1.51
Firmware date: 2018-05-08
Bus encryption flags: 13
Drive platform: RS8600
Firmware version: 1.51/ID61
When I put in a 4k disk the drive just tries to read the disk and quits after a minute.
Can someone please point me to tutorial I can follow to rip my 4k movies?
wotdefcuk wrote: Fri Nov 03, 2023 7:11 pm I am new to ripping 4k disks too.
Revision: 1.51
the pioneer stuff is not public as its not mine to share i do have a paid for flasher to make that drive work though see below and email me about it
keineahnung314
Post by keineahnung314 »
I bought a Pioneer 209D. It states that libredrive is enabled but it does not detect 4Ks. When I insert one it makes some noises but switches to "no disk inserted" after one minute. how can i flash it? Here is the Device Info:
Revision: 1.34
Serial number:
Firmware date: 2016-04-25
Highest AACS version: 12
Firmware version: 1.34/ID61
keineahnung314 wrote: Fri Dec 05, 2025 6:16 pm Hello,
Revision: 1.34
Serial number:
PM sent.
keineahnung314
Coopervid wrote: Fri Dec 05, 2025 8:45 pm
Revision: 1.34
Serial number:
PM sent.
Thanks for your PM. I started to backup an UHD. The Read rate is sticking constantly at 17.1M/s [4.0]. is this the maximum the drive can do or are there settings i have to tweak. the Source size is about 86G, which implies a triple layer Blu Ray.
All Pioneers are limited to 4x for UHDs.
AsianAttack
Post by AsianAttack »
I'm interested a ls well
Coopervid wrote: Fri Dec 05, 2025 8:45 pm PM sent.
AsianAttack wrote: Sat Feb 07, 2026 3:20 pm I'm interested a ls well
Post your Makemkv info.
Baronbuzby
Post by Baronbuzby »
OS device name: E:
Product: BD-RW BDR-209MIO
Revision: 1.30
Serial number: xxxxxxxxxxxx
Firmware date: 2015-10-30
Highest AACS version: 77
Drive platform: Pioneer RS8600
Firmware version: ID13
will this flash?
