problem to start the programm
after the installtion of the latest version i tried to start the programm but i received a windows fault message:
"MakeMKV found a problem and will be closed"
Any ideas? .. i am using Win XP .. do i need some extra software to start the programm?
- Contact:
Re: problem to start the programm
No, it should just work without any additional software or drivers. And it should work on XP.
the programm woks fine on my laptop but on my desktop pc i receive the windows fault message ... maybe there is a programm in the background which blocks "makemkv" but i dont find it
i found the programm which blocked "makemkv" .. it was the driver from my wacom tablet;
C:\WINDOWS\system32\Tablet.exe
i closed the programm and "makemkv" started
I have a Wacom Bamboo A6, and I can confirm this problem.
When the memory resident tablet software is running MakeMKV crashes on startup. Closing the Pen_Tablet.exe process solves the problem.
This is with MakeMKV version 1.46 on Windows XP SP3, and Wacom drivers version 5.11-1 RC.
Thanks for this solution! I have the same problem. I have to close my wacom software before i can run MakeMKV. Otherwise it crashes at startup.
- Contact:
Thanks for reporting. Is this software publically available? Where can we get a copy to reproduce the problem and do we really need a tablet for this? Also, what happens if you run "makemkvcon info disc:0" from a command line - does it crash?
Hi Mike!
You can download the software at:
http://www.wacom.eu/index2.asp?pid=29&l ... uct=MTE450
I'm not sure it can be installed without a Tablet present, but I think so.
Running the command line gives me:
I didn't have any disc in the drive - but it didn't crash like the GUI does.
001014:000000:0000 MakeMKV v1.4.6 beta win(x86-release) started
Current action: Scanning CD-ROM devices
Current progress - 0% , Total progress - 0%
Current progress - 100% , Total progress - 0%
Current progress - 100% , Total progress - 100%
Current progress - 0% , Total progress - 100%
005010:000000:0000 Failed to open disc
Total 0 titles
This problem still exists with MakeMKV 1.47 and the new Wacom 5.20-6a drivers. Are you devs able to reproduce it?
- Contact:
Please try attached version and post the result here. In order to try it:adrian wrote:This problem still exists with MakeMKV 1.47 and the new Wacom 5.20-6a drivers. Are you devs able to reproduce it?
- * locate MakeMKV installation directory
* rename makemkv.exe to makemkv.old
* extract makemkv.exe from attached archive and put into installation directory
* launch MakeMKV and see if it works
I signed up just to say thank you. This solved the problem. Works fine now.
I can confirm that this private build works fine.
Thanks Mike!
Thanks Mike!
