WigPhil
Post by WigPhil »
What Firmware pack or link should I be using as a source? I seem to have found different packs (All You Need Firmware Pack (MartyMcNuts), mk-firmware-pack-20200720, and The all you need firmware pack) on different posts throughout the forums which have different firmware varieties available in each. I am trying to make sure that I have the right firmware version for my drive.
Thanks in advance!
Post by d00zah »
WigPhil wrote: Fri Nov 03, 2023 8:15 pm Hi,
Thanks in advance!
A good start would be sharing (copy/paste from MakeMKV) your drive info so we can provide an informed answer. :D
All You Need Firmware Pack (MartyMcNuts) REALLY should have all you need.
wyzxvnv
Post by wyzxvnv »
Hi guys
I have an 'interesting' firmware version in LG BU40N drive. Can I safely flash it with MK firmware to enable LibreDrive support? I recently bought this drive in Japan, sold as an external drive I-O Data BRP-UC6K. Eternal enclosure is similar (basically identical) as Verbatim 43888 (Pioneer BDR-UD4 drive).
OS device name: O:
Product: BD-RE BU40N
Revision: DN15
Serial number: XXXXXXXXXX
Firmware date: 2121-05-31 10:19
Bus encryption flags: 1F
Highest AACS version: 19
wyzxvnv wrote: Tue Nov 07, 2023 7:59 pm Hi guys
OS device name: O:
Revision: DN15
Yeah, you should be able to flash it. Start with BU40N 1.03-MK firmware. Once flashed, you can then flash BU40N 1.00 if you use software other than MakeMKV and AnyDVD.
Darkk
Post by Darkk »
Tyler94 wrote: Thu Sep 28, 2023 1:25 am I don't get this. Where is the firmware for WH16NS60 1.02MK. I have a WH16NS40-NS50 on version 1.05 and I'm under the impression that I can not use SDF tool to flash it. Tried it and it didn't work. I'm so lost and a lot of this info in not up to date and scattered about. What do I do?
I have two LG WH16NS40 with the 1.05 MK firmware and then I decided to flash both to WH16NS60 1.02 MK from "The all you need firmware pack". Both firmware 1.05 MK and 1.02 MK work fine but not sure of the differences between the two or even worth changing it if it still works?
I purchased a new LG WH16NS40 last week with the stock 1.05 firmware August 2023 build date from Amazon. It took the WH16NS60 1.02 MK firmware just fine. Had to use the ENC command in the sdftool on my Debian 12 workstation to flash it as an encrypted firmware. After this point you don't need the ENC command to flash it with other MK firmwares.
Also, I can't find WH16NS60 anywhere on Amazon so went with the WH16NS40 as it's the same hardware between the two models with exception in different firmwares. WH16NS40 been a tank for me that I now own three as I am concerned about stores phasing out media discs like Best Buy is doing. Other retailers will follow the same path. So I am concerned that manufactures will stop making these drives just like they did with VCR years ago. So may pick up a couple more as spares / backups.
Darkk wrote: Tue Nov 07, 2023 8:20 pm Also, I can't find WH16NS60 anywhere on Amazon so went with the WH16NS40 as it's the same hardware between the two models with exception in different firmwares. WH16NS40 been a tank for me that I now own three as I am concerned about stores phasing out media discs like Best Buy is doing. Other retailers will follow the same path. So I am concerned that manufactures will stop making these drives just like they did with VCR years ago. So may pick up a couple more as spares / backups.
I encourage you to broaden your fleet of optical drives beyond just LG WH16NS60/WH16NS40 drives. The LG BU40N is well regarded. Also, Pioneer drives have an excellent reputation, although at the moment, your best bet is to get a Pioneer from a seller here on the forum who can ensure the drive has the correct firmware. The newest firmware on Pioneer drives is incompatible with MakeMKV.
Different drives (with different hardware) increase your chances of getting a good rip with troublesome discs.
Andrea61
Post by Andrea61 »
Greetings!
Due to my limited knowledge of the English language, I am not sure whether I can modify this player. (see photo)
Can you give me some advice, thanks.
zittrig
Post by zittrig »
Cause of massive problems with ripping
- The Hobbit UAJ
- Lord Of The Rings TTT
- Lord Of The Rings TFOTR (only disc 2)
(all discs looks fine, no scratches etc)
(the other discs of the Middlearth 4k 6-Film-Collection ripped without problems, no other of my over 120 4K movies makes trouble (only the craig bond collection))
... I flashed my WH16NS60 from MK 1.02 to MK 1.03, cause I've read in the WWW, that the M 1.03 have less problems with discs greater 66 GB. Without success. (I bought an ASUS drive too for testing, should arrive at Tuesday). So I tried zu flash back to MK 1.02 or to BH16NS60 MK 1.02 with the SDF, but the MK 1.03 keeps alive. How can I make a back flash?
JoshMKV
Post by JoshMKV »
I picked up one of the LG WH16NS40 on sale on Amazon. I'm trying to flash the firmware (currently 1.05) and I can't seem to get it to accept the location of the binary. I have the latest sdf.bin, I've renamed the firmware disk.bin for easier parsing but it fails even with the full name.
Any advice would be appreciated. Here is the command line and output:
makemkvcon f -d/dev/sr0 -f /tmp/sdf.bin rawflash enc -i /tmp/disk.bin
Input file not found -- /tmp/disk.bin
Internal error 0x83000001
*Edit, running Ubuntu without access to a Windows machine
Darkk
Post by Darkk »
JoshMKV wrote: Sun Nov 19, 2023 7:43 am I picked up one of the LG WH16NS40 on sale on Amazon. I'm trying to flash the firmware (currently 1.05) and I can't seem to get it to accept the location of the binary. I have the latest sdf.bin, I've renamed the firmware disk.bin for easier parsing but it fails even with the full name.
Have you tried running that command in the same folder as the binary? I usually extract them in my download folder so I always have a copy to reference to later.
You didn't follow the guide on page 1 of this thread.
JoshMKV
Post by JoshMKV »
What did I miss? I should have added, I am running on Ubuntu with no access to a Windows system to run the gui tool.
JoshMKV
Post by JoshMKV »
Darkk wrote: Sun Nov 19, 2023 4:10 pm
Thank you for the suggestion, I tried moving both the SDF bin and the firmware bin to /snap/bin and received the same error code
Input file not found -- /snap/bin/disk.bin
temmi
Post by temmi »
I bumped into an used Asus bw-16d1ht, manufacture June 2014. Do you guys think this could be flashed with the firmware?
No reason too - it won't grant you any additional features. 2014 is too old for UHD.
