makemkv failure with Californication
mikebolt22
#1 Post by mikebolt22 » Thu Nov 02, 2023 4:52 pm
hello
for some reason the makemkv for linux latest version is identifying the fake files as legit for season 1 of Calilfornication, and ignoring the other files entirely. is their any other way other than manual advanced commands to correct? Also anyone else come across this problem, and if so how did you solve it.
thanks in advance
mikebolt22 :shock:
Re: makemkv failure with Californication
#2 Post by dcoke22 » Thu Nov 02, 2023 11:25 pm
Are you trying to rip a blu-ray or a DVD?
There are different DVD opening modes: viewtopic.php?f=7&t=28541
mikebolt22
#3 Post by mikebolt22 » Fri Nov 03, 2023 8:41 am
it is a dvd season 1 imported from i think down under. all the other seasons are easy as can be. so i found that season somewhere else. i just do not like to leave a problem unsolved. i will check out the link.
thanks again dcoke22
mikebolt22
mikebolt22
#4 Post by mikebolt22 » Sat Nov 04, 2023 3:34 am
thanks for the advice. it worked like a charm. celltrim all the way.
thanks
mikebolt22
