BTW, if you want more info from 'info', you have to add the robot switch (-r) for some reason... is this an oversight?
Seems like segments are in there listed as "TINFO", I doubt they're subject to ellipsis. I'm attaching a link to the full file so you can look the rest of the repeating info. See if you find any other patterns or correlating info. Good luck!
:~# ./makemkvcon -r info disc:0
MSG:1005,0,1,"MakeMKV v1.17.5 linux(x64-release) started","%1 started","MakeMKV v1.17.5 linux(x64-release)"
MSG:1009,0,1,"Profile parsing error: default profile missing, using builtin default","Profile parsing error: %1","default profile missing, using builtin default"
DRV:0,2,999,12,"BD-RE ASUS BW-16D1HT 3.02 KL2J5FB2412","GLADIATOR_2000","/dev/sr0"
DRV:1,256,999,0,"","",""
DRV:2,256,999,0,"","",""
DRV:3,256,999,0,"","",""
DRV:4,256,999,0,"","",""
DRV:5,256,999,0,"","",""
DRV:6,256,999,0,"","",""
DRV:7,256,999,0,"","",""
DRV:8,256,999,0,"","",""
DRV:9,256,999,0,"","",""
DRV:10,256,999,0,"","",""
DRV:11,256,999,0,"","",""
DRV:12,256,999,0,"","",""
DRV:13,256,999,0,"","",""
DRV:14,256,999,0,"","",""
DRV:15,256,999,0,"","",""
MSG:1011,0,1,"Using LibreDrive mode (v06.3 id=96929CF53B04)","%1","Using LibreDrive mode (v06.3 id=96929CF53B04)"
MSG:3007,0,0,"Using direct disc access mode","Using direct disc access mode"
MSG:5085,0,0,"Loaded content hash table, will verify integrity of M2TS files.","Loaded content hash table, will verify integrity of M2TS files."
MSG:3307,0,2,"File 00105.mpls was added as title #0","File %1 was added as title #%2","00105.mpls","0"
MSG:3307,16777216,2,"File 00219.mpls was added as title #1","File %1 was added as title #%2","00219.mpls","1"
MSG:3309,16777216,2,"Title 00006.mpls is equal to title 00105.mpls and was skipped","Title %1 is equal to title %2 and was skipped","00006.mpls","00105.mpls"
MSG:3309,16777216,2,"Title 00005.mpls is equal to title 00105.mpls and was skipped","Title %1 is equal to title %2 and was skipped","00005.mpls","00105.mpls"
MSG:3309,16777216,2,"Title 00238.mpls is equal to title 00105.mpls and was skipped","Title %1 is equal to title %2 and was skipped","00238.mpls","00105.mpls"
MSG:3309,0,2,"Title 00239.mpls is equal to title 00105.mpls and was skipped","Title %1 is equal to title %2 and was skipped","00239.mpls","00105.mpls"
MSG:3307,0,2,"File 00241.mpls was added as title #2","File %1 was added as title #%2","00241.mpls","2"
MSG:3307,16777216,2,"File 00242.mpls was added as title #3","File %1 was added as title #%2","00242.mpls","3"
MSG:3309,0,2,"Title 00319.mpls is equal to title 00242.mpls and was skipped","Title %1 is equal to title %2 and was skipped","00319.mpls","00242.mpls"
MSG:3307,16777216,2,"File 00389.mpls was added as title #4","File %1 was added as title #%2","00389.mpls","4"
MSG:3309,0,2,"Title 00390.mpls is equal to title 00241.mpls and was skipped","Title %1 is equal to title %2 and was skipped","00390.mpls","00241.mpls"
MSG:3307,16777216,2,"File 00391.mpls was added as title #5","File %1 was added as title #%2","00391.mpls","5"
MSG:3309,16777216,2,"Title 00415.mpls is equal to title 00389.mpls and was skipped","Title %1 is equal to title %2 and was skipped","00415.mpls","00389.mpls"
MSG:3309,0,2,"Title 00416.mpls is equal to title 00391.mpls and was skipped","Title %1 is equal to title %2 and was skipped","00416.mpls","00391.mpls"
MSG:3307,16777216,2,"File 00254.m2ts was added as title #6","File %1 was added as title #%2","00254.m2ts","6"
MSG:3307,16777216,2,"File 00292.m2ts was added as title #7","File %1 was added as title #%2","00292.m2ts","7"
MSG:3307,0,2,"File 00388.m2ts was added as title #8","File %1 was added as title #%2","00388.m2ts","8"
MSG:3307,0,2,"File 00389.m2ts was added as title #9","File %1 was added as title #%2","00389.m2ts","9"
MSG:3307,0,2,"File 00408.m2ts was added as title #10","File %1 was added as title #%2","00408.m2ts","10"
MSG:3307,0,2,"File 00376.m2ts was added as title #11","File %1 was added as title #%2","00376.m2ts","11"
MSG:3307,0,2,"File 00377.m2ts was added as title #12","File %1 was added as title #%2","00377.m2ts","12"
MSG:3307,0,2,"File 00419.m2ts was added as title #13","File %1 was added as title #%2","00419.m2ts","13"
MSG:3307,0,2,"File 00000.m2ts was added as title #14","File %1 was added as title #%2","00000.m2ts","14"
MSG:3307,0,2,"File 00006.m2ts was added as title #15","File %1 was added as title #%2","00006.m2ts","15"
MSG:3307,0,2,"File 00473.m2ts was added as title #16","File %1 was added as title #%2","00473.m2ts","16"
MSG:3307,0,2,"File 00474.m2ts was added as title #17","File %1 was added as title #%2","00474.m2ts","17"
MSG:3307,0,2,"File 00498.m2ts was added as title #18","File %1 was added as title #%2","00498.m2ts","18"
MSG:3307,0,2,"File 00499.m2ts was added as title #19","File %1 was added as title #%2","00499.m2ts","19"
MSG:3307,0,2,"File 00500.m2ts was added as title #20","File %1 was added as title #%2","00500.m2ts","20"
MSG:3307,16777216,2,"File 00501.m2ts was added as title #21","File %1 was added as title #%2","00501.m2ts","21"
MSG:3307,0,2,"File 00502.m2ts was added as title #22","File %1 was added as title #%2","00502.m2ts","22"
MSG:3307,0,2,"File 00503.m2ts was added as title #23","File %1 was added as title #%2","00503.m2ts","23"
MSG:3307,0,2,"File 00504.m2ts was added as title #24","File %1 was added as title #%2","00504.m2ts","24"
MSG:3307,0,2,"File 00505.m2ts was added as title #25","File %1 was added as title #%2","00505.m2ts","25"
MSG:3307,0,2,"File 00506.m2ts was added as title #26","File %1 was added as title #%2","00506.m2ts","26"
MSG:3307,0,2,"File 00507.m2ts was added as title #27","File %1 was added as title #%2","00507.m2ts","27"
MSG:3307,0,2,"File 00508.m2ts was added as title #28","File %1 was added as title #%2","00508.m2ts","28"
MSG:3307,0,2,"File 00509.m2ts was added as title #29","File %1 was added as title #%2","00509.m2ts","29"
MSG:3307,0,2,"File 00510.m2ts was added as title #30","File %1 was added as title #%2","00510.m2ts","30"
MSG:3307,0,2,"File 00511.m2ts was added as title #31","File %1 was added as title #%2","00511.m2ts","31"
MSG:3307,0,2,"File 00512.m2ts was added as title #32","File %1 was added as title #%2","00512.m2ts","32"
MSG:3307,0,2,"File 00513.m2ts was added as title #33","File %1 was added as title #%2","00513.m2ts","33"
MSG:3307,0,2,"File 00514.m2ts was added as title #34","File %1 was added as title #%2","00514.m2ts","34"
MSG:3307,0,2,"File 00515.m2ts was added as title #35","File %1 was added as title #%2","00515.m2ts","35"
MSG:3307,0,2,"File 00516.m2ts was added as title #36","File %1 was added as title #%2","00516.m2ts","36"
MSG:3307,0,2,"File 00517.m2ts was added as title #37","File %1 was added as title #%2","00517.m2ts","37"
MSG:3307,0,2,"File 00518.m2ts was added as title #38","File %1 was added as title #%2","00518.m2ts","38"
MSG:3307,0,2,"File 00519.m2ts was added as title #39","File %1 was added as title #%2","00519.m2ts","39"
MSG:3307,0,2,"File 00520.m2ts was added as title #40","File %1 was added as title #%2","00520.m2ts","40"
MSG:3307,0,2,"File 00521.m2ts was added as title #41","File %1 was added as title #%2","00521.m2ts","41"
MSG:3307,0,2,"File 00522.m2ts was added as title #42","File %1 was added as title #%2","00522.m2ts","42"
MSG:3307,0,2,"File 00523.m2ts was added as title #43","File %1 was added as title #%2","00523.m2ts","43"
MSG:3307,0,2,"File 00524.m2ts was added as title #44","File %1 was added as title #%2","00524.m2ts","44"
MSG:3307,0,2,"File 00525.m2ts was added as title #45","File %1 was added as title #%2","00525.m2ts","45"
MSG:3307,0,2,"File 00526.m2ts was added as title #46","File %1 was added as title #%2","00526.m2ts","46"
MSG:3307,0,2,"File 00527.m2ts was added as title #47","File %1 was added as title #%2","00527.m2ts","47"
MSG:3307,0,2,"File 00528.m2ts was added as title #48","File %1 was added as title #%2","00528.m2ts","48"
MSG:3307,0,2,"File 00529.m2ts was added as title #49","File %1 was added as title #%2","00529.m2ts","49"
MSG:3307,0,2,"File 00530.m2ts was added as title #50","File %1 was added as title #%2","00530.m2ts","50"
MSG:3307,16777216,2,"File 00531.m2ts was added as title #51","File %1 was added as title #%2","00531.m2ts","51"
MSG:3307,0,2,"File 00532.m2ts was added as title #52","File %1 was added as title #%2","00532.m2ts","52"
MSG:3307,0,2,"File 00533.m2ts was added as title #53","File %1 was added as title #%2","00533.m2ts","53"
MSG:3307,0,2,"File 00534.m2ts was added as title #54","File %1 was added as title #%2","00534.m2ts","54"
MSG:3307,0,2,"File 00535.m2ts was added as title #55","File %1 was added as title #%2","00535.m2ts","55"
MSG:3307,0,2,"File 00536.m2ts was added as title #56","File %1 was added as title #%2","00536.m2ts","56"
MSG:3307,0,2,"File 00537.m2ts was added as title #57","File %1 was added as title #%2","00537.m2ts","57"
MSG:3307,0,2,"File 00538.m2ts was added as title #58","File %1 was added as title #%2","00538.m2ts","58"
MSG:3307,0,2,"File 00539.m2ts was added as title #59","File %1 was added as title #%2","00539.m2ts","59"
MSG:3307,0,2,"File 00540.m2ts was added as title #60","File %1 was added as title #%2","00540.m2ts","60"
MSG:3307,0,2,"File 00541.m2ts was added as title #61","File %1 was added as title #%2","00541.m2ts","61"
MSG:3307,0,2,"File 00542.m2ts was added as title #62","File %1 was added as title #%2","00542.m2ts","62"
MSG:5011,0,0,"Operation successfully completed","Operation successfully completed"
TCOUNT:63
CINFO:1,6209,"Blu-ray disc"
CINFO:2,0,"Gladiator"
CINFO:28,0,"eng"
CINFO:29,0,"English"
CINFO:30,0,"Gladiator"
CINFO:31,6119,"<b>Source information</b><br>"
CINFO:32,0,"GLADIATOR_2000"
CINFO:33,0,"0"
TINFO:0,2,0,"Gladiator"
TINFO:0,8,0,"2"
TINFO:0,9,0,"0:01:00"
TINFO:0,10,0,"102.2 MB"
TINFO:0,11,0,"107218944"
TINFO:0,16,0,"00105.mpls"
TINFO:0,25,0,"1"
TINFO:0,26,0,"292"
TINFO:0,27,0,"Gladiator_t00.mkv"
TINFO:0,28,0,"eng"
TINFO:0,29,0,"English"
TINFO:0,30,0,"Gladiator - 2 chapter(s) , 102.2 MB"
TINFO:0,31,6120,"<b>Title information</b><br>"
TINFO:0,33,0,"0"
SINFO:0,0,1,6201,"Video"
SINFO:0,0,5,0,"V_MPEGH/ISO/HEVC"
SINFO:0,0,6,0,"MpegH"
SINFO:0,0,7,0,"MpegH HEVC Main10@L5.1 (dvhe.07.06 BL+FEL+RPU)"
SINFO:0,0,19,0,"3840x2160"
SINFO:0,0,20,0,"16:9"
SINFO:0,0,21,0,"23.976 (480000/20020)"
SINFO:0,0,22,0,"65536"
SINFO:0,0,28,0,"eng"
SINFO:0,0,29,0,"English"
SINFO:0,0,30,0,"MpegH HEVC Main10@L5.1 (dvhe.07.06 BL+FEL+RPU)"
SINFO:0,0,31,6121,"<b>Track information</b><br>"
SINFO:0,0,33,0,"0"
SINFO:0,0,38,0,""
SINFO:0,0,42,5088,"( Lossless conversion )"
TINFO:1,2,0,"Gladiator"
TINFO:1,8,0,"2"
TINFO:1,9,0,"0:00:21"
TINFO:1,10,0,"14.3 MB"
TINFO:1,11,0,"15003648"
TINFO:1,16,0,"00219.mpls"
TINFO:1,25,0,"1"
TINFO:1,26,0,"418"
TINFO:1,27,0,"Gladiator_t01.mkv"
TINFO:1,28,0,"eng"
TINFO:1,29,0,"English"
TINFO:1,30,0,"Gladiator - 2 chapter(s) , 14.3 MB"
TINFO:1,31,6120,"<b>Title information</b><br>"
TINFO:1,33,0,"0"
SINFO:1,0,1,6201,"Video"
SINFO:1,0,5,0,"V_MPEGH/ISO/HEVC"
SINFO:1,0,6,0,"MpegH"
SINFO:1,0,7,0,"MpegH HEVC Main10@L5.1"
SINFO:1,0,19,0,"3840x2160"
SINFO:1,0,20,0,"16:9"
SINFO:1,0,21,0,"23.976 (480000/20020)"
SINFO:1,0,22,0,"0"
SINFO:1,0,28,0,"eng"
SINFO:1,0,29,0,"English"
SINFO:1,0,30,0,"MpegH HEVC Main10@L5.1"
SINFO:1,0,31,6121,"<b>Track information</b><br>"
SINFO:1,0,33,0,"0"
SINFO:1,0,38,0,""
SINFO:1,0,42,5088,"( Lossless conversion )"
TINFO:2,2,0,"Gladiator"
TINFO:2,8,0,"2"
TINFO:2,9,0,"0:00:14"
TINFO:2,10,0,"2.6 MB"
TINFO:2,11,0,"2813952"
TINFO:2,16,0,"00241.mpls"
TINFO:2,25,0,"2"
TINFO:2,26,0,"388,542"
TINFO:2,27,0,"Gladiator_t02.mkv"
TINFO:2,28,0,"eng"
TINFO:2,29,0,"English"
TINFO:2,30,0,"Gladiator - 2 chapter(s) , 2.6 MB"
TINFO:2,31,6120,"<b>Title information</b><br>"
TINFO:2,33,0,"0"
SINFO:2,0,1,6201,"Video"
SINFO:2,0,5,0,"V_MPEGH/ISO/HEVC"
SINFO:2,0,6,0,"MpegH"
SINFO:2,0,7,0,"MpegH HEVC Main10@L5.1 (dvhe.07.06 BL+FEL+RPU)"
SINFO:2,0,19,0,"3840x2160"
SINFO:2,0,20,0,"16:9"
SINFO:2,0,21,0,"23.976 (480000/20020)"
SINFO:2,0,22,0,"65536"
SINFO:2,0,28,0,"eng"
SINFO:2,0,29,0,"English"
SINFO:2,0,30,0,"MpegH HEVC Main10@L5.1 (dvhe.07.06 BL+FEL+RPU)"
SINFO:2,0,31,6121,"<b>Track information</b><br>"
SINFO:2,0,33,0,"0"
SINFO:2,0,38,0,""
SINFO:2,0,42,5088,"( Lossless conversion )"
TINFO:3,2,0,"Gladiator"
TINFO:3,8,0,"2"
TINFO:3,9,0,"0:00:14"
TINFO:3,10,0,"2.8 MB"
TINFO:3,11,0,"2936832"
TINFO:3,16,0,"00242.mpls"
TINFO:3,25,0,"2"
TINFO:3,26,0,"389,532"
TINFO:3,27,0,"Gladiator_t03.mkv"
TINFO:3,28,0,"eng"
TINFO:3,29,0,"English"
TINFO:3,30,0,"Gladiator - 2 chapter(s) , 2.8 MB"
TINFO:3,31,6120,"<b>Title information</b><br>"
TINFO:3,33,0,"0"
SINFO:3,0,1,6201,"Video"
SINFO:3,0,5,0,"V_MPEGH/ISO/HEVC"
SINFO:3,0,6,0,"MpegH"
SINFO:3,0,7,0,"MpegH HEVC Main10@L5.1 (dvhe.07.06 BL+FEL+RPU)"
SINFO:3,0,19,0,"3840x2160"
SINFO:3,0,20,0,"16:9"
SINFO:3,0,21,0,"23.976 (480000/20020)"
SINFO:3,0,22,0,"65536"
SINFO:3,0,28,0,"eng"
SINFO:3,0,29,0,"English"
SINFO:3,0,30,0,"MpegH HEVC Main10@L5.1 (dvhe.07.06 BL+FEL+RPU)"
SINFO:3,0,31,6121,"<b>Track information</b><br>"
SINFO:3,0,33,0,"0"
SINFO:3,0,38,0,""
SINFO:3,0,42,5088,"( Lossless conversion )"
TINFO:4,2,0,"Gladiator"
TINFO:4,8,0,"28"
TINFO:4,9,0,"2:34:59"
TINFO:4,10,0,"69.3 GB"
TINFO:4,11,0,"74514948096"
TINFO:4,16,0,"00389.mpls"
TINFO:4,25,0,"22"
TINFO:4,26,0,"498,499,500,501,502,503,504,505,506,507,508,509,510,511,512,513,514,515,516,517,518,519"
TINFO:4,27,0,"Gladiator_t04.mkv"
TINFO:4,28,0,"eng"
TINFO:4,29,0,"English"
TINFO:4,30,0,"Gladiator - 28 chapter(s) , 69.3 GB"
TINFO:4,31,6120,"<b>Title information</b><br>"
TINFO:4,33,0,"0"
SINFO:4,0,1,6201,"Video"
SINFO:4,0,5,0,"V_MPEGH/ISO/HEVC"
SINFO:4,0,6,0,"MpegH"
SINFO:4,0,7,0,"MpegH HEVC Main10@L5.1 (dvhe.07.06 BL+FEL+RPU)"
SINFO:4,0,19,0,"3840x2160"
SINFO:4,0,20,0,"16:9"
SINFO:4,0,21,0,"23.976 (480000/20020)"
SINFO:4,0,22,0,"65536"
SINFO:4,0,28,0,"eng"
SINFO:4,0,29,0,"English"
SINFO:4,0,30,0,"MpegH HEVC Main10@L5.1 (dvhe.07.06 BL+FEL+RPU)"
SINFO:4,0,31,6121,"<b>Track information</b><br>"
SINFO:4,0,33,0,"0"
SINFO:4,0,38,0,""
SINFO:4,0,42,5088,"( Lossless conversion )"
SINFO:4,1,1,6202,"Audio"
SINFO:4,1,2,0,"Surround 7.1"
SINFO:4,1,3,0,"eng"
SINFO:4,1,4,0,"English"
SINFO:4,1,5,0,"A_DTS"
SINFO:4,1,6,0,"DTS-HD MA"
SINFO:4,1,7,0,"DTS-HD Master Audio"
SINFO:4,1,14,0,"8"
SINFO:4,1,17,0,"48000"
SINFO:4,1,18,0,"24"
SINFO:4,1,22,0,"1024"
SINFO:4,1,28,0,"eng"
SINFO:4,1,29,0,"English"
SINFO:4,1,30,0,"DTS-HD MA Surround 7.1 English"
SINFO:4,1,31,6121,"<b>Track information</b><br>"
SINFO:4,1,33,0,"0"
SINFO:4,1,38,0,"d"
SINFO:4,1,39,0,"Default"
SINFO:4,1,40,0,"7.1"
SINFO:4,1,42,5088,"( Lossless conversion )"
SINFO:4,2,1,6202,"Audio"
SINFO:4,2,2,0,"Surround 5.1"
SINFO:4,2,3,0,"eng"
SINFO:4,2,4,0,"English"
SINFO:4,2,5,0,"A_DTS"
SINFO:4,2,6,0,"DTS"
SINFO:4,2,7,0,"DTS"
SINFO:4,2,13,0,"1.5 Mb/s"
SINFO:4,2,14,0,"6"
SINFO:4,2,17,0,"48000"
SINFO:4,2,22,0,"2304"
SINFO:4,2,28,0,"eng"
SINFO:4,2,29,0,"English"
SINFO:4,2,30,0,"DTS Surround 5.1 English"
SINFO:4,2,31,6121,"<b>Track information</b><br>"
SINFO:4,2,33,0,"0"
SINFO:4,2,38,0,""
SINFO:4,2,40,0,"5.1(side)"
SINFO:4,2,42,5088,"( Lossless conversion )"
SINFO:4,3,1,6202,"Audio"
SINFO:4,3,2,0,"Surround 5.1"
SINFO:4,3,3,0,"fra"
SINFO:4,3,4,0,"French"
SINFO:4,3,5,0,"A_AC3"
SINFO:4,3,6,0,"DD"
SINFO:4,3,7,0,"Dolby Digital"
SINFO:4,3,13,0,"640 Kb/s"
SINFO:4,3,14,0,"6"
SINFO:4,3,17,0,"48000"
SINFO:4,3,22,0,"0"
SINFO:4,3,28,0,"eng"
SINFO:4,3,29,0,"English"
SINFO:4,3,30,0,"DD Surround 5.1 French"
SINFO:4,3,31,6121,"<b>Track information</b><br>"
SINFO:4,3,33,0,"0"
SINFO:4,3,38,0,""
SINFO:4,3,40,0,"5.1(side)"
SINFO:4,3,42,5088,"( Lossless conversion )"
SINFO:4,4,1,6202,"Audio"
SINFO:4,4,2,0,"Surround 5.1"
SINFO:4,4,3,0,"spa"
SINFO:4,4,4,0,"Spanish"
SINFO:4,4,5,0,"A_AC3"
SINFO:4,4,6,0,"DD"
SINFO:4,4,7,0,"Dolby Digital"
SINFO:4,4,13,0,"640 Kb/s"
SINFO:4,4,14,0,"6"
SINFO:4,4,17,0,"48000"
SINFO:4,4,22,0,"0"
SINFO:4,4,28,0,"eng"
SINFO:4,4,29,0,"English"
SINFO:4,4,30,0,"DD Surround 5.1 Spanish"
SINFO:4,4,31,6121,"<b>Track information</b><br>"
SINFO:4,4,33,0,"0"
SINFO:4,4,38,0,""
SINFO:4,4,40,0,"5.1(side)"
SINFO:4,4,42,5088,"( Lossless conversion )"
SINFO:4,5,1,6202,"Audio"
SINFO:4,5,2,5091,"Stereo"
SINFO:4,5,3,0,"eng"
SINFO:4,5,4,0,"English"
SINFO:4,5,5,0,"A_DTS"
SINFO:4,5,6,0,"DTS-HD MA"
SINFO:4,5,7,0,"DTS-HD Master Audio"
SINFO:4,5,14,0,"2"
SINFO:4,5,17,0,"48000"
SINFO:4,5,18,0,"24"
SINFO:4,5,22,0,"1024"
SINFO:4,5,28,0,"eng"
SINFO:4,5,29,0,"English"
SINFO:4,5,30,0,"DTS-HD MA Stereo English"
SINFO:4,5,31,6121,"<b>Track information</b><br>"
SINFO:4,5,33,0,"0"
SINFO:4,5,38,0,""
SINFO:4,5,40,0,"stereo"
SINFO:4,5,42,5088,"( Lossless conversion )"
SINFO:4,6,1,6202,"Audio"
SINFO:4,6,2,5091,"Stereo"
SINFO:4,6,3,0,"eng"
SINFO:4,6,4,0,"English"
SINFO:4,6,5,0,"A_DTS"
SINFO:4,6,6,0,"DTS"
SINFO:4,6,7,0,"DTS"
SINFO:4,6,13,0,"1.5 Mb/s"
SINFO:4,6,14,0,"2"
SINFO:4,6,17,0,"48000"
SINFO:4,6,22,0,"2304"
SINFO:4,6,28,0,"eng"
SINFO:4,6,29,0,"English"
SINFO:4,6,30,0,"DTS Stereo English"
SINFO:4,6,31,6121,"<b>Track information</b><br>"
SINFO:4,6,33,0,"0"
SINFO:4,6,38,0,""
SINFO:4,6,40,0,"stereo"
SINFO:4,6,42,5088,"( Lossless conversion )"
SINFO:4,7,1,6202,"Audio"
SINFO:4,7,2,0,"Surround 5.1"
SINFO:4,7,3,0,"eng"
SINFO:4,7,4,0,"English"
SINFO:4,7,5,0,"A_AC3"
SINFO:4,7,6,0,"DD"
SINFO:4,7,7,0,"Dolby Digital"
SINFO:4,7,13,0,"640 Kb/s"
SINFO:4,7,14,0,"6"
SINFO:4,7,17,0,"48000"
SINFO:4,7,22,0,"0"
SINFO:4,7,28,0,"eng"
SINFO:4,7,29,0,"English"
SINFO:4,7,30,0,"DD Surround 5.1 English"
SINFO:4,7,31,6121,"<b>Track information</b><br>"
SINFO:4,7,33,0,"0"
SINFO:4,7,38,0,""
SINFO:4,7,40,0,"5.1(side)"
SINFO:4,7,42,5088,"( Lossless conversion )"
SINFO:4,8,1,6202,"Audio"
SINFO:4,8,2,5091,"Stereo"
SINFO:4,8,3,0,"eng"
SINFO:4,8,4,0,"English"
SINFO:4,8,5,0,"A_AC3"
SINFO:4,8,6,0,"DD"
SINFO:4,8,7,0,"Dolby Digital"
SINFO:4,8,13,0,"224 Kb/s"
SINFO:4,8,14,0,"2"
SINFO:4,8,17,0,"48000"
SINFO:4,8,22,0,"0"
SINFO:4,8,28,0,"eng"
SINFO:4,8,29,0,"English"
SINFO:4,8,30,0,"DD Stereo English"
SINFO:4,8,31,6121,"<b>Track information</b><br>"
SINFO:4,8,33,0,"0"
SINFO:4,8,38,0,""
SINFO:4,8,40,0,"stereo"
SINFO:4,8,42,5088,"( Lossless conversion )"
SINFO:4,9,1,6203,"Subtitles"
SINFO:4,9,3,0,"eng"
SINFO:4,9,4,0,"English"
SINFO:4,9,5,0,"S_HDMV/PGS"
SINFO:4,9,6,0,"PGS"
SINFO:4,9,7,0,"HDMV PGS Subtitles"
SINFO:4,9,22,0,"0"
SINFO:4,9,28,0,"eng"
SINFO:4,9,29,0,"English"
SINFO:4,9,30,0,"PGS English"
SINFO:4,9,31,6121,"<b>Track information</b><br>"
SINFO:4,9,33,0,"0"
SINFO:4,9,38,0,""
SINFO:4,9,42,5088,"( Lossless conversion )"
SINFO:4,10,1,6203,"Subtitles"
SINFO:4,10,3,0,"eng"
SINFO:4,10,4,0,"English"
SINFO:4,10,5,0,"S_HDMV/PGS"
SINFO:4,10,6,0,"PGS"
SINFO:4,10,7,0,"HDMV PGS Subtitles"
SINFO:4,10,22,0,"6144"
SINFO:4,10,28,0,"eng"
SINFO:4,10,29,0,"English"
SINFO:4,10,30,0,"PGS English (forced only)"
SINFO:4,10,31,6121,"<b>Track information</b><br>"
SINFO:4,10,33,0,"0"
SINFO:4,10,38,0,"d"
SINFO:4,10,39,0,"Default"
SINFO:4,10,42,5088,"( Lossless conversion )"
SINFO:4,11,1,6203,"Subtitles"
SINFO:4,11,3,0,"eng"
SINFO:4,11,4,0,"English"
SINFO:4,11,5,0,"S_HDMV/PGS"
SINFO:4,11,6,0,"PGS"
SINFO:4,11,7,0,"HDMV PGS Subtitles"
SINFO:4,11,22,0,"0"
SINFO:4,11,28,0,"eng"
SINFO:4,11,29,0,"English"
SINFO:4,11,30,0,"PGS English"
SINFO:4,11,31,6121,"<b>Track information</b><br>"
SINFO:4,11,33,0,"0"
SINFO:4,11,38,0,""
SINFO:4,11,42,5088,"( Lossless conversion )"
SINFO:4,12,1,6203,"Subtitles"
SINFO:4,12,3,0,"eng"
SINFO:4,12,4,0,"English"
SINFO:4,12,5,0,"S_HDMV/PGS"
SINFO:4,12,6,0,"PGS"
SINFO:4,12,7,0,"HDMV PGS Subtitles"
SINFO:4,12,22,0,"6144"
SINFO:4,12,28,0,"eng"
SINFO:4,12,29,0,"English"
SINFO:4,12,30,0,"PGS English (forced only)"
SINFO:4,12,31,6121,"<b>Track information</b><br>"
SINFO:4,12,33,0,"0"
SINFO:4,12,38,0,""
SINFO:4,12,42,5088,"( Lossless conversion )"
SINFO:4,13,1,6203,"Subtitles"
SINFO:4,13,3,0,"fra"
SINFO:4,13,4,0,"French"
SINFO:4,13,5,0,"S_HDMV/PGS"
SINFO:4,13,6,0,"PGS"
SINFO:4,13,7,0,"HDMV PGS Subtitles"
SINFO:4,13,22,0,"0"
SINFO:4,13,28,0,"eng"
SINFO:4,13,29,0,"English"
SINFO:4,13,30,0,"PGS French"
SINFO:4,13,31,6121,"<b>Track information</b><br>"
SINFO:4,13,33,0,"0"
SINFO:4,13,38,0,""
SINFO:4,13,42,5088,"( Lossless conversion )"
SINFO:4,14,1,6203,"Subtitles"
SINFO:4,14,3,0,"fra"
SINFO:4,14,4,0,"French"
SINFO:4,14,5,0,"S_HDMV/PGS"
SINFO:4,14,6,0,"PGS"
SINFO:4,14,7,0,"HDMV PGS Subtitles"
SINFO:4,14,22,0,"6144"
SINFO:4,14,28,0,"eng"
SINFO:4,14,29,0,"English"
SINFO:4,14,30,0,"PGS French (forced only)"
SINFO:4,14,31,6121,"<b>Track information</b><br>"
SINFO:4,14,33,0,"0"
SINFO:4,14,38,0,""
SINFO:4,14,42,5088,"( Lossless conversion )"
SINFO:4,15,1,6203,"Subtitles"
SINFO:4,15,3,0,"spa"
SINFO:4,15,4,0,"Spanish"
SINFO:4,15,5,0,"S_HDMV/PGS"
SINFO:4,15,6,0,"PGS"
SINFO:4,15,7,0,"HDMV PGS Subtitles"
SINFO:4,15,22,0,"0"
SINFO:4,15,28,0,"eng"
SINFO:4,15,29,0,"English"
SINFO:4,15,30,0,"PGS Spanish"
SINFO:4,15,31,6121,"<b>Track information</b><br>"
SINFO:4,15,33,0,"0"
SINFO:4,15,38,0,""
SINFO:4,15,42,5088,"( Lossless conversion )"
SINFO:4,16,1,6203,"Subtitles"
SINFO:4,16,3,0,"spa"
SINFO:4,16,4,0,"Spanish"
SINFO:4,16,5,0,"S_HDMV/PGS"
SINFO:4,16,6,0,"PGS"
SINFO:4,16,7,0,"HDMV PGS Subtitles"
SINFO:4,16,22,0,"6144"
SINFO:4,16,28,0,"eng"
SINFO:4,16,29,0,"English"
SINFO:4,16,30,0,"PGS Spanish (forced only)"
SINFO:4,16,31,6121,"<b>Track information</b><br>"
SINFO:4,16,33,0,"0"
SINFO:4,16,38,0,""
SINFO:4,16,42,5088,"( Lossless conversion )"
SINFO:4,17,1,6203,"Subtitles"
SINFO:4,17,3,0,"kor"
SINFO:4,17,4,0,"Korean"
SINFO:4,17,5,0,"S_HDMV/PGS"
SINFO:4,17,6,0,"PGS"
SINFO:4,17,7,0,"HDMV PGS Subtitles"
SINFO:4,17,22,0,"0"
SINFO:4,17,28,0,"eng"
SINFO:4,17,29,0,"English"
SINFO:4,17,30,0,"PGS Korean"
SINFO:4,17,31,6121,"<b>Track information</b><br>"
SINFO:4,17,33,0,"0"
SINFO:4,17,38,0,""
SINFO:4,17,42,5088,"( Lossless conversion )"
SINFO:4,18,1,6203,"Subtitles"
SINFO:4,18,3,0,"kor"
SINFO:4,18,4,0,"Korean"
SINFO:4,18,5,0,"S_HDMV/PGS"
SINFO:4,18,6,0,"PGS"
SINFO:4,18,7,0,"HDMV PGS Subtitles"
SINFO:4,18,22,0,"6144"
SINFO:4,18,28,0,"eng"
SINFO:4,18,29,0,"English"
SINFO:4,18,30,0,"PGS Korean (forced only)"
SINFO:4,18,31,6121,"<b>Track information</b><br>"
SINFO:4,18,33,0,"0"
SINFO:4,18,38,0,""
SINFO:4,18,42,5088,"( Lossless conversion )"
SINFO:4,19,1,6203,"Subtitles"
SINFO:4,19,3,0,"fra"
SINFO:4,19,4,0,"French"
SINFO:4,19,5,0,"S_HDMV/PGS"
SINFO:4,19,6,0,"PGS"
SINFO:4,19,7,0,"HDMV PGS Subtitles"
SINFO:4,19,22,0,"0"
SINFO:4,19,28,0,"eng"
SINFO:4,19,29,0,"English"
SINFO:4,19,30,0,"PGS French"
SINFO:4,19,31,6121,"<b>Track information</b><br>"
SINFO:4,19,33,0,"0"
SINFO:4,19,38,0,""
SINFO:4,19,42,5088,"( Lossless conversion )"
SINFO:4,20,1,6203,"Subtitles"
SINFO:4,20,3,0,"fra"
SINFO:4,20,4,0,"French"
SINFO:4,20,5,0,"S_HDMV/PGS"
SINFO:4,20,6,0,"PGS"
SINFO:4,20,7,0,"HDMV PGS Subtitles"
SINFO:4,20,22,0,"6144"
SINFO:4,20,28,0,"eng"
SINFO:4,20,29,0,"English"
SINFO:4,20,30,0,"PGS French (forced only)"
SINFO:4,20,31,6121,"<b>Track information</b><br>"
SINFO:4,20,33,0,"0"
SINFO:4,20,38,0,""
SINFO:4,20,42,5088,"( Lossless conversion )"
SINFO:4,21,1,6203,"Subtitles"
SINFO:4,21,3,0,"eng"
SINFO:4,21,4,0,"English"
SINFO:4,21,5,0,"S_HDMV/PGS"
SINFO:4,21,6,0,"PGS"
SINFO:4,21,7,0,"HDMV PGS Subtitles"
SINFO:4,21,22,0,"0"
SINFO:4,21,28,0,"eng"
SINFO:4,21,29,0,"English"
SINFO:4,21,30,0,"PGS English"
SINFO:4,21,31,6121,"<b>Track information</b><br>"
SINFO:4,21,33,0,"0"
SINFO:4,21,38,0,""
SINFO:4,21,42,5088,"( Lossless conversion )"
SINFO:4,22,1,6203,"Subtitles"
SINFO:4,22,3,0,"eng"
SINFO:4,22,4,0,"English"
SINFO:4,22,5,0,"S_HDMV/PGS"
SINFO:4,22,6,0,"PGS"
SINFO:4,22,7,0,"HDMV PGS Subtitles"
SINFO:4,22,22,0,"6144"
SINFO:4,22,28,0,"eng"
SINFO:4,22,29,0,"English"
SINFO:4,22,30,0,"PGS English (forced only)"
SINFO:4,22,31,6121,"<b>Track information</b><br>"
SINFO:4,22,33,0,"0"
SINFO:4,22,38,0,""
SINFO:4,22,42,5088,"( Lossless conversion )"
SINFO:4,23,1,6203,"Subtitles"
SINFO:4,23,3,0,"fra"
SINFO:4,23,4,0,"French"
SINFO:4,23,5,0,"S_HDMV/PGS"
SINFO:4,23,6,0,"PGS"
SINFO:4,23,7,0,"HDMV PGS Subtitles"
SINFO:4,23,22,0,"0"
SINFO:4,23,28,0,"eng"
SINFO:4,23,29,0,"English"
SINFO:4,23,30,0,"PGS French"
SINFO:4,23,31,6121,"<b>Track information</b><br>"
SINFO:4,23,33,0,"0"
SINFO:4,23,38,0,""
SINFO:4,23,42,5088,"( Lossless conversion )"
SINFO:4,24,1,6203,"Subtitles"
SINFO:4,24,3,0,"fra"
SINFO:4,24,4,0,"French"
SINFO:4,24,5,0,"S_HDMV/PGS"
SINFO:4,24,6,0,"PGS"
SINFO:4,24,7,0,"HDMV PGS Subtitles"
SINFO:4,24,22,0,"6144"
SINFO:4,24,28,0,"eng"
SINFO:4,24,29,0,"English"
SINFO:4,24,30,0,"PGS French (forced only)"
SINFO:4,24,31,6121,"<b>Track information</b><br>"
SINFO:4,24,33,0,"0"
SINFO:4,24,38,0,""
SINFO:4,24,42,5088,"( Lossless conversion )"
SINFO:4,25,1,6203,"Subtitles"
SINFO:4,25,3,0,"spa"
SINFO:4,25,4,0,"Spanish"
SINFO:4,25,5,0,"S_HDMV/PGS"
SINFO:4,25,6,0,"PGS"
SINFO:4,25,7,0,"HDMV PGS Subtitles"
SINFO:4,25,22,0,"0"
SINFO:4,25,28,0,"eng"
SINFO:4,25,29,0,"English"
SINFO:4,25,30,0,"PGS Spanish"
SINFO:4,25,31,6121,"<b>Track information</b><br>"
SINFO:4,25,33,0,"0"
SINFO:4,25,38,0,""
SINFO:4,25,42,5088,"( Lossless conversion )"
SINFO:4,26,1,6203,"Subtitles"
SINFO:4,26,3,0,"spa"
SINFO:4,26,4,0,"Spanish"
SINFO:4,26,5,0,"S_HDMV/PGS"
SINFO:4,26,6,0,"PGS"
SINFO:4,26,7,0,"HDMV PGS Subtitles"
SINFO:4,26,22,0,"6144"
SINFO:4,26,28,0,"eng"
SINFO:4,26,29,0,"English"
SINFO:4,26,30,0,"PGS Spanish (forced only)"
SINFO:4,26,31,6121,"<b>Track information</b><br>"
SINFO:4,26,33,0,"0"
SINFO:4,26,38,0,""
SINFO:4,26,42,5088,"( Lossless conversion )"
SINFO:4,27,1,6203,"Subtitles"
SINFO:4,27,3,0,"kor"
SINFO:4,27,4,0,"Korean"
SINFO:4,27,5,0,"S_HDMV/PGS"
SINFO:4,27,6,0,"PGS"
SINFO:4,27,7,0,"HDMV PGS Subtitles"
SINFO:4,27,22,0,"0"
SINFO:4,27,28,0,"eng"
SINFO:4,27,29,0,"English"
SINFO:4,27,30,0,"PGS Korean"
SINFO:4,27,31,6121,"<b>Track information</b><br>"
SINFO:4,27,33,0,"0"
SINFO:4,27,38,0,""
SINFO:4,27,42,5088,"( Lossless conversion )"
SINFO:4,28,1,6203,"Subtitles"
SINFO:4,28,3,0,"kor"
SINFO:4,28,4,0,"Korean"
SINFO:4,28,5,0,"S_HDMV/PGS"
SINFO:4,28,6,0,"PGS"
SINFO:4,28,7,0,"HDMV PGS Subtitles"
SINFO:4,28,22,0,"6144"
SINFO:4,28,28,0,"eng"
SINFO:4,28,29,0,"English"
SINFO:4,28,30,0,"PGS Korean (forced only)"
SINFO:4,28,31,6121,"<b>Track information</b><br>"
SINFO:4,28,33,0,"0"
SINFO:4,28,38,0,""
SINFO:4,28,42,5088,"( Lossless conversion )"
TINFO:5,2,0,"Gladiator"
TINFO:5,8,0,"28"
TINFO:5,9,0,"2:50:56"
TINFO:5,10,0,"76.5 GB"
TINFO:5,11,0,"82194462720"
TINFO:5,16,0,"00391.mpls"
TINFO:5,25,0,"22"
TINFO:5,26,0,"498,520,500,521,502,522,504,523,506,524,508,525,510,526,512,527,514,528,516,529,518,530"
TINFO:5,27,0,"Gladiator_t05.mkv"
TINFO:5,28,0,"eng"
TINFO:5,29,0,"English"
TINFO:5,30,0,"Gladiator - 28 chapter(s) , 76.5 GB"
TINFO:5,31,6120,"<b>Title information</b><br>"
TINFO:5,33,0,"0"
SINFO:5,0,1,6201,"Video"
SINFO:5,0,5,0,"V_MPEGH/ISO/HEVC"
SINFO:5,0,6,0,"MpegH"
SINFO:5,0,7,0,"MpegH HEVC Main10@L5.1 (dvhe.07.06 BL+FEL+RPU)"
SINFO:5,0,19,0,"3840x2160"
SINFO:5,0,20,0,"16:9"
SINFO:5,0,21,0,"23.976 (480000/20020)"
SINFO:5,0,22,0,"65536"
SINFO:5,0,28,0,"eng"
SINFO:5,0,29,0,"English"
SINFO:5,0,30,0,"MpegH HEVC Main10@L5.1 (dvhe.07.06 BL+FEL+RPU)"
SINFO:5,0,31,6121,"<b>Track information</b><br>"
SINFO:5,0,33,0,"0"
SINFO:5,0,38,0,""
SINFO:5,0,42,5088,"( Lossless conversion )"
SINFO:5,1,1,6202,"Audio"
SINFO:5,1,2,0,"Surround 7.1"
SINFO:5,1,3,0,"eng"
SINFO:5,1,4,0,"English"
SINFO:5,1,5,0,"A_DTS"
SINFO:5,1,6,0,"DTS-HD MA"
SINFO:5,1,7,0,"DTS-HD Master Audio"
SINFO:5,1,14,0,"8"
SINFO:5,1,17,0,"48000"
SINFO:5,1,18,0,"24"
SINFO:5,1,22,0,"1024"
SINFO:5,1,28,0,"eng"
SINFO:5,1,29,0,"English"
SINFO:5,1,30,0,"DTS-HD MA Surround 7.1 English"
SINFO:5,1,31,6121,"<b>Track information</b><br>"
SINFO:5,1,33,0,"0"
SINFO:5,1,38,0,"d"
SINFO:5,1,39,0,"Default"
SINFO:5,1,40,0,"7.1"
SINFO:5,1,42,5088,"( Lossless conversion )"
SINFO:5,2,1,6202,"Audio"
SINFO:5,2,2,0,"Surround 5.1"
