Blu Ray Rip Error - Arrgh!
Moorthy88
#1 Post by Moorthy88 » Sat Jul 02, 2011 3:38 pm
I've been trying to rip a BD that I made, into a MKV. It's a two disk set, and the first disk worked perfectly.
The second disk gives me this error: "Copy complete. 0 titles saved, 1 failed"
Debug log file attached.
Thanks in advance.
MakeMKV v1.6.10 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\Daddy O/MakeMKV_log.txt
DEBUG: Code 0 at Lly(Z]j_nE\>-jYV5:121262164
AACS directory not present, assuming unencrypted disc
File 00000.mpls was added as title #0
Saving 1 titles into directory E:/Sports - Grey Cups
DEBUG: Code 0 at aS[Evv*sH[\,qF!3Wgr:213133848
DEBUG: Code 0 at aS[Evv*sH[\,qF!3Wgr:213130536
DEBUG: Code 0 at aS[Evv*sH[\,qF!3Wgr:29393723
DEBUG: Code 0 at BJ$Hw?`+UT>+&z?0AwN&{:29397587
DEBUG: Code 0 at 8RVP'QCU]Q1|p~mR3pd:29394160
DEBUG: Code 0 at 8RVP'QCU]Q1|p~mR3pd:29395471
Failed to save title 0 to file E:/Sports - Grey Cups/title00.mkv
setarip_old
Re: Blu Ray Rip Error - Arrgh!
#2 Post by setarip_old » Sun Jul 03, 2011 9:38 pm
Hi!
Have you confirmed that your second Homebrewn Blu-ray disc plays properly?
What software and procedures did you use to create it?
Moorthy88
#3 Post by Moorthy88 » Mon Jul 04, 2011 2:25 am
Yep, the disk plays fine with VLC.
I ripped the disk to my hard drive with no problems, and MakeMKV still failed to convert it from there.
#4 Post by mike admin » Tue Jul 05, 2011 2:32 pm
Looks like invalid video stream (at least from MakeMKV point of view). Did you encode video yourself? What encoder and blu-ray creation software did you use?
Moorthy88
#5 Post by Moorthy88 » Fri Jul 08, 2011 2:49 pm
The HD video was captured to a .ts file using a Hauppauge HD-PVR and Total Media Extreme software.
I then used TSMuxer to create the BD folders (Mode 1 / 2048, UDF 2.50), and Imgburn for burning.
The two disks (1 and 2) were created the same way, yet Makemkv only craps out on the second one.
Wondering if the disk was faulty, I ripped the suspect BD back to my hard drive, and pointed MakeMKV to that folder. I received the same error message.
Moorthy88
#6 Post by Moorthy88 » Fri Jul 08, 2011 9:52 pm
I've downloaded two trial versions of other software programs. Pavtube Blu-ray Ripper, and Tipard Blu-ray to MKV Converter.
Both programs work on the disk.
I had to cancel both conversions because of their trial version limitations.
