makemkv failure with Californication
mikebolt22
Post by mikebolt22 »
hello
for some reason the makemkv for linux latest version is identifying the fake files as legit for season 1 of Calilfornication, and ignoring the other files entirely. is their any other way other than manual advanced commands to correct? Also anyone else come across this problem, and if so how did you solve it.
thanks in advance
mikebolt22 :shock:
Re: makemkv failure with Californication
Are you trying to rip a blu-ray or a DVD?
There are different DVD opening modes: viewtopic.php?f=7&t=28541
mikebolt22
it is a dvd season 1 imported from i think down under. all the other seasons are easy as can be. so i found that season somewhere else. i just do not like to leave a problem unsolved. i will check out the link.
thanks again dcoke22
mikebolt22
mikebolt22
thanks for the advice. it worked like a charm. celltrim all the way.
thanks
mikebolt22
