VLC with LibMMD integration only plays region-free discs.
TheAlmightyCurd
Post by TheAlmightyCurd »
VLC gives region error when playing region A or B bluray discs but plays region free discs fine, even those with copy protection. I don't have region C discs but I think there is an issue with the decoding, as I bought the drive from a Best Buy.
Re: VLC with LibMMD integration only plays region-free discs.
change the region in vlc not the drive
TheAlmightyCurd
Thanks. If anyone else is having this issue I found VLC's region setting in Tools -> Preferences -> Input/Codecs -> Show all -> Access Modules -> BluRay -> Region Code
