billbillw
#121
Post
by billbillw » Mon Oct 30, 2023 6:52 pm
Billycar11 wrote: ↑Mon Oct 30, 2023 6:34 pm
billbillw wrote: ↑Mon Oct 30, 2023 5:09 pm
Just making sure, a Pioneer BDR-212 built in 2019 with original 1.0 firmware should be a workable unit for UHD discs? Is there any advantage of upgrading it to one of the pre-12/2022 firmwares?
No major advantage long as it's a UHD model it should work and if it's not you can email me for a cross flash kit if it's before 12-22
I might need to do that. I think I was confused on the model numbers thinking all the 212 models were basically the same, but this one appears to be a DBK model and not the UBK model. It was fairly cheap though, and the seller confirmed it is the 1.0 firmware which is well before 12/22.
EDIT: The more I am reading, the more I'm afraid this was a bad purchase if I want to read UHD...SMH.
#122
Post
by Billycar11 » Mon Oct 30, 2023 7:25 pm
billbillw wrote: ↑Mon Oct 30, 2023 6:52 pm
Yeah the dbk does not do UHD but I can make it read them email me when you get it
#123
Post
by MartyMcNuts » Mon Oct 30, 2023 9:14 pm
Billycar11 wrote: ↑Mon Oct 30, 2023 7:25 pm
I have a 212DBK and as they are not a BDXL drive, even when flashed, the DBK won't read triple layer discs.
EDIT: I had mine CF with BDR-S12UHT firmware and would not rip any TL UHD discs. I have since CF to BDR-212JBK firmware and have successfully completed 2 x TL UHD rips. Not sure why the S12UHT firmware wasn't working well but any-who, all good now.
For UHD enabled drives (AU/NZ/SG + Others) & DIY Single Drive Flasher (WW):
https://uhdenableddrives.com
billbillw
#124
Post
by billbillw » Fri Nov 03, 2023 1:29 am
MartyMcNuts wrote: ↑Mon Oct 30, 2023 9:14 pm
Billy's cross flash package worked like a charm. This inexpensive 212DBK is now showing as an S12JX and it ripped the first TL disk I threw at it with no issues.
JackFlack
#125
Post
by JackFlack » Fri Nov 03, 2023 1:04 pm
One of the early posts in this thread said that the FW for a BDR-XS07S / BDR-XS07UHD could be downgraded. However, some other posts in the thread leads me do believe that this isn't true. Can someone clarify?
Trying to sort out how to get a Pioneer drive (preferably a slim/external) that can be used to rip UHD content. I've traditionally stuck to bluray, but want to start getting into the UHD content.
#126
Post
by Billycar11 » Fri Nov 03, 2023 1:36 pm
JackFlack wrote: ↑Fri Nov 03, 2023 1:04 pm
no they cant be downgraded
the xs07s if it has old fw can be crossflashed to the uhd version but those are pretty rare now i haven't been able to source them since august.
#127
Post
by Coopervid » Fri Nov 03, 2023 4:43 pm
If you are in Europe you can buy a Verbatim 43888 which contains a Pioneer UD04. No flashing needed. If you are in the US and buy the right Verbatim it contains a Pioneer UD03 that can be cross-flashed to UD04.
#128
Post
by Coopervid » Fri Nov 03, 2023 5:15 pm
The 212DBK and all other "12" drives can be flashed to either 212JBK or S12JBK and are then fully UHD and BDXL capable.
billbillw
#129
Post
by billbillw » Sat Nov 04, 2023 3:30 pm
Coopervid wrote: ↑Fri Nov 03, 2023 5:15 pm
This is good info to have posted. The key (at this time) is finding a 212DBK that has pre-12/2022 firmware.
#130
Post
by Coopervid » Sat Nov 04, 2023 9:52 pm
billbillw wrote: ↑Sat Nov 04, 2023 3:30 pm
Drives from 208 and upwards can be made UHD compatible.
chooch
#131
Post
by chooch » Sat Nov 04, 2023 11:31 pm
Coopervid wrote: ↑Sat Nov 04, 2023 9:52 pm
Even if the firmware is after 12/2022? I thought that was the criteria when looking for a drive however didn't know if that recently changed since I'm currently in the market for one myself.
#132
Post
by MartyMcNuts » Sun Nov 05, 2023 12:24 am
chooch wrote: ↑Sat Nov 04, 2023 11:31 pm
Best to get one already UHD enabled and tested from a seller in your region.
#133
Post
by Coopervid » Sun Nov 05, 2023 10:45 am
The statement about 208 or higher is only applicable if the firmware on these drives is older than Dec. 2022.
chooch
#134
Post
by chooch » Sun Nov 05, 2023 1:02 pm
MartyMcNuts wrote: ↑Sun Nov 05, 2023 12:24 am
I plan on doing that and reaching out to billbillw once I get more storage added to my server.
chooch on Sun Nov 05, 2023 1:04 pm, edited 1 time in total.
chooch
#135
Post
by chooch » Sun Nov 05, 2023 1:03 pm
Coopervid wrote: ↑Sun Nov 05, 2023 10:45 am
Ok, thanks. I wasn't sure if something changed and someone found a way to get it to work on drives post Dec 2022 because I thought that might be a possibility down the road.
