Problems with disc extras Marie Antoinette (2006)
#1 Post by dcoke22 » Sun Oct 29, 2023 5:10 pm
This is from a successfully made decrypted backup (made with MakeMKV 1.17.4). I got this same behavior with 1.17.4 as well.
MakeMKV v1.17.5 darwin(x64-release) started
Debug logging enabled, log will be saved as /Users/****/MakeMKV_log.txt
Optical drive "BD-RE HL-DT-ST BD-RE WH16NS60 1.02 " opened in OS access mode.
Optical drive "BD-RE PIONEER BD-RW BDR-212U 1.01 " opened in OS access mode.
Optical drive "BD-RE ASUS BW-16D1HT 3.10 " opened in OS access mode.
DEBUG: Code 0 at 7N4m|hG$B.606"Wtpq.<{27Fi:29395149
Opening files on harddrive at /Volumes/Super Scratch/backups/MARIE_ANTOINETTE
File 00102.mpls was added as title #0
File 00207.mpls was added as title #1
Title #00196.mpls has length of 12 seconds which is less than minimum title length of 15 seconds and was therefore skipped
File 00210.mpls was added as title #2
File 00206.mpls was added as title #3
File 00186.mpls was added as title #4
Title #00217.mpls has length of 10 seconds which is less than minimum title length of 15 seconds and was therefore skipped
File 00216.mpls was added as title #5
File 00095.mpls was added as title #6
File 00001.mpls was added as title #7
Title #00219.mpls has length of 10 seconds which is less than minimum title length of 15 seconds and was therefore skipped
Title #00171.mpls has length of 12 seconds which is less than minimum title length of 15 seconds and was therefore skipped
File 00096.mpls was added as title #8
Title #00193.mpls has length of 12 seconds which is less than minimum title length of 15 seconds and was therefore skipped
File 00218.mpls was added as title #9
Title #00213.mpls has length of 12 seconds which is less than minimum title length of 15 seconds and was therefore skipped
File 00194.mpls was added as title #10
File 00195.mpls was added as title #11
Title #00103.m2ts has length of 0 seconds which is less than minimum title length of 15 seconds and was therefore skipped
Title #00226.m2ts has length of 0 seconds which is less than minimum title length of 15 seconds and was therefore skipped
File 00334.m2ts was added as title #12
File 00335.m2ts was added as title #13
Title #00227.m2ts has length of 0 seconds which is less than minimum title length of 15 seconds and was therefore skipped
Title #00220.m2ts has length of 0 seconds which is less than minimum title length of 15 seconds and was therefore skipped
File 00099.m2ts was added as title #14
Title #00104.m2ts has length of 0 seconds which is less than minimum title length of 15 seconds and was therefore skipped
Title #00098.m2ts has length of 3 seconds which is less than minimum title length of 15 seconds and was therefore skipped
Title #00221.m2ts has length of 0 seconds which is less than minimum title length of 15 seconds and was therefore skipped
Title #00222.m2ts has length of 0 seconds which is less than minimum title length of 15 seconds and was therefore skipped
Title #00081.m2ts has length of 10 seconds which is less than minimum title length of 15 seconds and was therefore skipped
Title #00097.m2ts has length of 1 seconds which is less than minimum title length of 15 seconds and was therefore skipped
Title #00080.m2ts has length of 10 seconds which is less than minimum title length of 15 seconds and was therefore skipped
Title #00223.m2ts has length of 0 seconds which is less than minimum title length of 15 seconds and was therefore skipped
Title #00228.m2ts has length of 0 seconds which is less than minimum title length of 15 seconds and was therefore skipped
Title #00208.m2ts has length of 11 seconds which is less than minimum title length of 15 seconds and was therefore skipped
Title #00249.m2ts has length of 1 seconds which is less than minimum title length of 15 seconds and was therefore skipped
File 00336.m2ts was added as title #15
Title #00224.m2ts has length of 0 seconds which is less than minimum title length of 15 seconds and was therefore skipped
Title #00225.m2ts has length of 0 seconds which is less than minimum title length of 15 seconds and was therefore skipped
File 00337.m2ts was added as title #16
Title #00100.m2ts has length of 14 seconds which is less than minimum title length of 15 seconds and was therefore skipped
Title #00229.m2ts has length of 0 seconds which is less than minimum title length of 15 seconds and was therefore skipped
Title #00116.m2ts has length of 11 seconds which is less than minimum title length of 15 seconds and was therefore skipped
Title #00205.m2ts has length of 5 seconds which is less than minimum title length of 15 seconds and was therefore skipped
Saving 4 titles into directory /Volumes/Super Scratch
AV synchronization issues were found in file '/Volumes/Super Scratch/The Making of Marie Antoinette_t12.mkv' (title #13)
AV sync issue in stream 0 at 0:00:29.929 : video frame timecode differs by +33.366ms
AV sync issue in stream 0 at 0:00:29.963 : video frame timecode differs by -33.366ms
LIBMKV_TRACE: Exception: MKV_ASSERT: TimecodeDelay >= int16(0x8000) && TimecodeDelay <= int16(0x7FFF)
Failed to save title 12 to file /Volumes/Super Scratch/The Making of Marie Antoinette_t12.mkv
AV synchronization issues were found in file '/Volumes/Super Scratch/Deleted Scene- Second Opera_t13.mkv' (title #14)
Failed to save title 13 to file /Volumes/Super Scratch/Deleted Scene- Second Opera_t13.mkv
AV synchronization issues were found in file '/Volumes/Super Scratch/Deleted Scene- Turn from Petit Trianon_t15.mkv' (title #16)
AV sync issue in stream 0 at 0:00:14.948 : video frame timecode differs by +66.733ms
AV sync issue in stream 0 at 0:00:14.981 : video frame timecode differs by -33.366ms
Failed to save title 15 to file /Volumes/Super Scratch/Deleted Scene- Turn from Petit Trianon_t15.mkv
Failed to save title 16 to file /Volumes/Super Scratch/Cribs with Louis XVI_t16.mkv
0 titles saved, 4 failed
Re: Problems with disc extras Marie Antoinette (2006)
#2 Post by dcoke22 » Sun Oct 29, 2023 5:27 pm
I made another decrypted backup of the disc and payed closer attention this time.
Using LibreDrive mode (v01.0 id=CD721A59C477)
Backing up disc into folder "/Volumes/Super Scratch/backups/MARIE_ANTOINETTE-2"
AACS directory not present, assuming unencrypted disc
Content hash table missing, unable to verify integrity of M2TS files.
Backup done
I got the same errors trying to create .mkv files from the second backup.
