Disc reading issues - Disc issue?
NGS428
Post by NGS428 »
Based on the errors post, I think this is a disc issue... Some discs will copy, I have a couple Harry Potter ones that don't. Thoughts?
WH16NS60 1.02, Libre Drive enabled, running the drive via an external USB adapter.
Here is the debugging log:
Debug log started at Fri Oct 27 21:43:24 2023 , written by MakeMKV v1.17.5 win(x64-release)
001005:0000 MakeMKV v1.17.5 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file://C:\Users\nicsc/MakeMKV_log.txt
DEBUG: Code 3 at p#THBi/ll*BA2gQ6"dN^+C5W:29395310
SDF  v098: HL-DT-ST_BD-RE__WH16NS60_1.02_211810291936_KLZKAMF3241
001011:0000 Using LibreDrive mode (v06.3 id=7FA2657C7667)
DEBUG: Code 2147483648 at ]K}<{g 5\^[xCzt/:121265499
DISCID=27424E2D95AC800E2E92C0C9DD7FB7D078701E11
003025:0000 Title #00008.mpls has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00101.mpls was added as title #0
003307:0000 File 00100.mpls was added as title #1
003307:0000 File 00007.mpls was added as title #2
003025:0000 Title #00010.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00009.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00999.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00007.m2ts has length of 34 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00004.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00008.m2ts was added as title #3
003025:0000 Title #00901.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00017.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00016.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00900.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00003.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00002.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00000.m2ts was added as title #4
003025:0000 Title #00005.m2ts has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00012.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00006.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
005014:0000 Saving 1 titles into directory file://D:/Temporary/MakeMKV
001003:0020 DEBUG: Code 3221225628 at p#THBi/ll*BA2gQ6"dN^+C5W:121262371
001003:0020 DEBUG: Code 3221225628 at e0)""ua'FL?Ifeb9:213130559
001003:0020 DEBUG: Code 3221225653 at e0)""ua'FL?Ifeb9:213130559
001003:0020 DEBUG: Code 3221225653 at p#THBi/ll*BA2gQ6"dN^+C5W:121262371
002003:0000 Error 'OS error - {Device Timeout} The specified I/O operation on hs was not completed before the time-out period expired' occurred while reading '/BDMV/STREAM/00008.m2ts' at offset '4020695040'
002003:0000 Error 'OS error - {Device Timeout} The specified I/O operation on hs was not completed before the time-out period expired' occurred while reading '\Device\CdRom1' at offset '4020695040'
DEBUG: Code 3221225653 at T*66mI"9R%2H!-6CI':29394896
001003:0020 DEBUG: Code 3221225653 at T*66mI"9R%2H!-6CI':213131502
001003:0020 DEBUG: Code 100864261 at 6XX(~WMlif ;_K(I:121271617
001003:0020 DEBUG: Code 100864261 at e0)""ua'FL?Ifeb9:213130559
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00008.m2ts' at offset '4021813248'
002003:0000 Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom1' at offset '4021813248'
DEBUG: Code 3221225628 at T*66mI"9R%2H!-6CI':29394896
001003:0020 DEBUG: Code 3221225628 at T*66mI"9R%2H!-6CI':213131502
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00008.m2ts' at offset '4022206464'
002003:0000 Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom1' at offset '4022206464'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00008.m2ts' at offset '4022403072'
002003:0000 Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom1' at offset '4022403072'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00008.m2ts' at offset '4022599680'
002003:0000 Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom1' at offset '4022599680'
002003:0000 Error 'OS error - {Device Timeout} The specified I/O operation on hs was not completed before the time-out period expired' occurred while reading '/BDMV/STREAM/00008.m2ts' at offset '4024627200'
002003:0000 Error 'OS error - {Device Timeout} The specified I/O operation on hs was not completed before the time-out period expired' occurred while reading '\Device\CdRom1' at offset '4024627200'
001003:0020 DEBUG: Code 117637198 at p#THBi/ll*BA2gQ6"dN^+C5W:121262371
001003:0020 DEBUG: Code 117637198 at e0)""ua'FL?Ifeb9:213130559
002003:0000 Error 'Internal error - Operation result is incorrect (78)' occurred while reading '\Device\CdRom1' at offset '4024627200'
DEBUG: Code 117637198 at T*66mI"9R%2H!-6CI':29394896
001003:0020 DEBUG: Code 117637198 at T*66mI"9R%2H!-6CI':213131502
002003:0000 Error 'Internal error - Operation was cancelled (140)' occurred while reading '/BDMV/STREAM/00008.m2ts' at offset '4024627200'
001003:0020 DEBUG: Code 0 at %K{3+D<I-p.W2g)K$P73:29395471
001003:0020 DEBUG: Code 0 at >u+x)D9+i6!-r0Fh7!4O:29394068
001003:0020 DEBUG: Code 0 at %K{3+D<I-p.W2g)K$P73:213131157
001003:0020 DEBUG: Code 0 at %K{3+D<I-p.W2g)K$P73:121262647
001003:0020 DEBUG: Code 1965150 at %K{3+D<I-p.W2g)K$P73:121261773
001003:0020 DEBUG: Code 0 at 5#w%HEc@g}P<=`%X^J>Av:213137068
---- Failed D:/Temporary/MakeMKV/Harry Potter and the Goblet of Fire_t03.mkv
ch_0        1349458110000 0
ch_1        1350088740000 0
ch_2        1350719370000 0
ch_3        1351350000000 0
ch_4        1351980630000 0
ch_5        1352611260000 0
ch_6        1353241890000 0
ch_7        1353872520000 1
mt=000002B5BE49D7F0 n=6
s=0 n=15 o=4022587392
    0 165112 000001  1353241890000       45045000 151BAA54 0000010FDBFE3BF21B8A3BF886F1804A02020309AF270727040000010E1ADFFCEFC86C400000010DC07200FFEFFFEFFEFDFEFFFF7AFD73F7FFFFEFD70615AFB73A7455E62BEDFBC9407D9E010B7CBB1CB3DC7B5D50FFFAD3397F0074AFC63907DC0EC4F1E7C18C3FEF05789284FDECEDD6DB3D38A8D5E74B8666000078C33BFC
    0  23792 000008  1353286935000       45045000 77457D67 0000010D892120100000030201017040502805020801000AC0EB1FBE7DE8911C4399ED0004075C04400074A6C44888200474000207BF8000001E0F0014E0004022000007958000000B4B8043D083003000000303C9F0404000DFC02124728900480001F2D5600001FBF87390395C2300000301F1A8002000FF6FF1CDAB677480
    0  50884 000008  1353331980000       45045000 618E4D7F 0000010D821920100080010020021000020C240000800B560E05EBE908931C47739F10101CFF4004020022004189300C081000035F80400020030410C10A4140000003021F842000000303822B20238270D0480145C800000301C301601012C1060036018264008000DC6CA090A850011008011F370080005FBE99C200205000
    0 130101 000000  1353377025000       45045000 B973C774 0000010D110012FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF160356137509D8356EA1DB35E1AEE1AA1CE1AB0D09CBFD0BFFF9FFF817FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFDFFFFFFF2FFA7FFFFFDC0FFFCD6FFFFFFFD3FFFFFFFFDFFFFFFFFFFDBFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCFFAFDFFFFFFFFC8381F3D57B7FFF
    0  67384 000008  1353422070000       45045000 16856B91 0000010D81147FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5EBBF7B61DBBBABEDEDD2918209429800AAC64000E307440111C1038A710C006A78C222A81C5410C345967803158527042504570B168C6E61138640E1812A609E10360A1619AEA2A88C2C89C0AD0D20A185B0220943509412800808143A13D2A304134559920B24C2484
    0  66711 000008  1353467115000       45045000 50B0A8F6 0000010D8A142010000003010020021000020C20000003000908438102E464220325D8830470183E8028060003307898C480403410131A440851B3831697C40209600990040F00495810E2A0701401A02090E01423C084A04020A81905B010000010004FC40E088B4AB26E060C810102010003600150F4F0BEA8004049902540
    0 115647 000000  1353512160000       45045000 7599179C 0000010D010012FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF09DD7750EFBABB3AFFE5FFFFFF3FFFBFFFFFFFFFF7FFFFFFFFFD7CFEFFBFFFFFFFFF0605D3FFFFFFFFEFFFFFCBE55FFF2FFFFFDBFFFEBFFFFFFFFF0DFFFFFFA7FFFFFFFFDB3FFFFFFFFF00FFFFFFFFFF6FF5FFFFFFB37FFB7FFFFFC3858A575FAFFFFEE5DC4E0C07E5
    0  63294 000008  1353557205000       45045000 0E486B27 0000010D89142010000003010020021000020C20000003000A8D0BA530C940DA923C8970A26029AF0A8802143480A8A2D000800008480288C018A28310050012808040040D73443200B1C78860892A000AC000029680009482A2CC01000448E08400004079400456D08D0100002041240800A3660115222442B220000049E010
    0  63441 000008  1353602250000       45045000 B6317CC8 0000010D8214200C44420030250AA591458D8038C0032E20040400278159580A41470C0010479280201031501420002002801C0703CA00060001058E84100804042001129010052081129704C01020000003010164424A093BA04B082D00408000010924020C00307C7440090200206000121C0B401428E0A88017B240030610
    0 147652 000001  1353647295000       45045000 290890D7 0000010DC04200FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF09273FCD4521D04800000044C022DFB013B6FE37BCECE4000009019011A780C1CE7F1BCBE37280001457000467E920E53D8DA5FFA90000003008005037F20073FFE752BAF30000100898403DF10039C7632958728180004CDC005CFD000CF7B9BD9ED8E7604027770B4
    0  71725 000008  1353692340000       45045000 C7A5DE15 0000010D89147FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFEBFFFFFEEFDFFFFFFF2FFFFFFFFFFFFFFFFF5FFFFFE033FFFFFD7FFFD7FFFFF3FFFFFFFFFFFFFFDFFFFFFFFFFFFFFFFFFFFDBFFFFFFFFEE19FFFAFFFFFFFFFE19FFFFFF4FFF9FFFFFFFFFFFFFFC27FFFFFFFFFFFFFFFFFFFFFFFFFFFFFD3FFFFEDFFFFFFFFFFFFFFFFFFF
    0  81700 000008  1353737385000       45045000 9CE90034 0000010D82147FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4FFFFFFEFFFFFFFFFEC9FFFFFFFFFFFFF7FFFFFFFFFFFFFFFF7FFFFFFFFFF5FFFFFF9FFFFFFFFFFFFFFFFFFFFFFFF40AFFFC27FFFFFFFFFFFFFFFD3FFE7FFFFFF7FFFD7FF97DBAFFFFC4EFFFFAFFFFFFFFFFB7FFFFFFFFE92FFFFEBFFFFFFFFFCBFFFFFFF
    0  76609 000000  1353782430000       45045000 321A2593 0000010D110012FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE5F0179940A05FFFFC08472FFFFAFFFFFFFF814FFFFFFFFFFF42FFFFFA7FE5FFFFFFFFFD3EDFFF7FF5FFFFFDFF74FEA9FFFFFFFFF401967FFFFE5FFF44FFFB7F8292FFFE95E7FFF96025FEDFDA5EBFE9FB7FFA6ABF9FFE01CFFFF3DD3FFDB0CE997FA45852E
    0  42294 000008  1353827475000       45045000 34CEEF30 0000010D8014200808254DF5048C06EE673819702594040001B50040C2803A4429080010CC020400FB048651801840144000801181A800288204748000000302000003009108D00039A7C71C1001000003008840000060000A47C18600002000000301880288200081F9C02A00000300000302000003004010800510C0620008
    0 147546 000003  1353872520000       45045000 99F0EB22 0000010FDBFE3BF21B8A3BF886F1804A02020309AF270727040000010E1ADFFCEFC86C400000010DC04200FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE010729C94560D8460000003002C031F7B6139CEE37946CE4000006148050FF8001CE5B5BCB6352000012619008FFE900E7A98DE5EFA901000020201069EA4072DEC6F299F32
s=1 n=1 o=4019644416
    1   2884 000001  1353242880000       11520000 7C532622 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF440000400400000004000020060000000404000003B5A3DC88706507F0D1974CF98341CC5A94A5294A529294A508398A3208410CA2F6B16B52D6B5AD6A5294A4A506318A41CA2F7318B5AD6A5AD4B4A52A4A4E631884
s=2 n=1 o=4021506048
    2     30 000011  1354908555000       22522500 469531A4 16000B078004381002090000000017000A01000244036C02F70089800000
s=3 n=0 o=4024627200
s=4 n=1 o=4024627200
    4     30 000011  1354953600000       22522500 20B58C9F 16000B078004381002950000000017000A01000244036C02F70089800000
s=5 n=0 o=4024627200
mt=000002B5BE5D3490 n=6
s=0 n=1 o=4022587392
    0  41687 000008  1353917565000       45045000 DA382353 0000010D8914200DF5357BFE5ACE17FF07A066BFBB53C60801FE6935460138000003000041150320017F743EFB00980000030008A1E5018002728F0F9900040000030108111300D00055E003E0402700000300000302080040001563899C400300000300005276C0600018DA8105000003000003000003010560180802CA08A5
s=1 n=22 o=4019644416
    1   2872 002001  1353254400000       11520000 736520CF 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000400400000004000040060000000406000005114F34C650492E6AD48550450541EF7358B5B5AC52D4A4A507314C2108410CA0E6318B52D4A5A96B525294A526310A31CA0E6B16B5AD6A5294B525294A4C631483
    1   2884 002001  1353265920000       11520000 74FFAF4A 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF40000020040000000400406006000000040200000678CC3CFC112D0550470673CF10269C6306B58C73DAE6318D4A94939862108210CA0E6316B52D4A52D4A525294A4E62946214A0E6B16B52D4A5A54A5252849CC620
    1   2848 002001  1353277440000       11520000 5276CE96 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4020000004000000040000200600000000040000058ECC04D85083EE729D19CE72941AD73DEF7B58C5B16A4A4A3084210C9EE62D6A5A94A5292A4A1273A0C6210830C60E62D6A52D4A5A9294A5283A0C421062139894
    1   2944 002001  1353288960000       11520000 1ED04A1E 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000400000004000040060000000400000004D7CDD26EC8DF3CA9D5A718C18D635B0731AC5A94A524A2108210CA0D6314A5294A5A9494A10849CE521062145EE62D6A52D4A5A94949D29498E6294620B98941CE
    1   2928 002001  1353300480000       11520000 64A2EE11 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF460011800400000004000000060000000002000006B418F032D902338284CFF1D6B4D09565093DAE5B9D0735CC5292A528C2104210CA0E62D6A52D49529494A5274A0E5308621460E6B14A52D4A529494A5074A4E628
    1   2932 002001  1353312000000       11520000 56AF28D8 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF44084000000000000400000002040000000600000571DC3D98CC61976B25262B2DA708C18D5B5F0735CC52D2A528E4188210CA0E6B14A52D6A5294A4A52939CE52948214A0E6AD6B5A94A529494A5273A4E529062139
    1   2928 002001  1353323520000       11520000 2240B2FD 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF46008240000000000400000006020000040400000571EFB1898C97EB01A715723A64C80D36D6508C5AE635F1735AC4AD4A52504108410CA0E6316A52D4A5A94A49CE93A0E528C820CA0E6B56A529495294A4A5284A4E
    1   2932 002001  1353335040000       11520000 A9BC927B 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF460000000000000004000020060400000602000006B52754C537C13A6AD38E130099502D6518C18D635F0735AD5AD4A5A925108210CE0D6314A5294A529294A4E83A0C6290A214A0E6B56A52D495294A4A528420E628
    1   2904 002001  1353346560000       11520000 EC5AD143 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF460188000402000004000000060000000600000006B562DEA46306E80272B8828480FC612D09FD2508C18D6B5EF6B9AD5AD4A5A925108410C60E6314B5294A5292949D2949CE628C63149EE6B56A52D4A5294A4A5094
    1   2908 002001  1353358080000       11520000 62824849 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF460080000400000000020040060000000400000006B52745C4CE02709C370FF3C4D856517BD8D631D06B9AC62929528E6108210CA0E6316B5294952929421084A0E518C630D1ED6316B52D49525293A4E949CE621063
    1   2912 002001  1353369600000       11520000 3AA09A69 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4708D8200400000004000000060400000600000006B76EF4B71919846EB830B8624DF074CDFE6EB4ED0F106AD56517398E6ADCF735CC5A9294A083108210C9EE6316B52D49525294A4E739CE62906214A0E6316A52D4
    1   2880 002001  1353381120000       11520000 35059001 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4508C0000400000004020000060000000402000006BCF77F4999BE36CC8CD7508CC26CB430389D671735AE6B1AF735ED5A92931C63108210C60E6316B5AD4A525294A52931CE620C6314A0E62D6A5294A52529420E93
    1   2904 002001  1353392640000       11520000 F596A66E 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF450808000400000004000000060000000600000006AB48B9D840CCC3708CFA982F0308356907358D6B1AF639CC6AD47394A2108210CA0D6316B5294A529494A5294A0E628C6214A0E6316B52D4A529294A5083A4C528
    1   2904 002001  1353404160000       11520000 68057C5F 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF472900000400000004410000060000000600000006A5987828C97630B0CCCBCC32DE9CADAAF3CFE699BDA706B58D6AD8E635AE6AD49398A2104210CA0E6B58B5AD49525294A5294A0E52106314A0D6B16A5AD4952949
    1   2916 002001  1353415680000       11520000 01AB6B4E 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF460020000401000004000000060200000602000006B2FCB564CC2C0FCC2F01997398DA9899E2ED6907318D6AD8E5B18E6AD4931883184410C60E6356B5AD49525295252849CE628C8314A0E6B56B5296A5A5294A5284
    1   2880 002001  1353427200000       11520000 AE03FD8C 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4611200004000000040000000620000004000000072E749A7E54933A4F9CC313F6B58AAF0756906B56C62D8E5B18E7294A394A2108210C60F6356B5AD4A529294A529424E6214431CA0E6B16B5AD6A5A94A4A527424E
    1   2888 002001  1353438720000       11520000 8422108E 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF460021000400000004000000060200000600000006B274A10C10DA0ECCEF010895084898AED66F6B18D62D8E5B18E62949398C3108210C60E6B16B52D6B525494A4E94A4E628C63149ED6B16B5AD6A5A94A4A52949CE
    1   2856 002001  1353450240000       11520000 CD3792BF 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF462110400000002004000000060400000600000006ACF495B43195D9502D12CD9DB509FF2D707189566F6B58C6AD6C6318C62D4A310A3188410CA0F6B16B5A94B52929525294A0E72906314A0E6B16B5AD6A5A94A4A5
    1   2864 002001  1353461760000       11520000 91F91FBF 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4608004004000000040000000606000006000000038BFD15CBA6ACCF7010038966BD50A4B609CD64F6318C62D6E5A98C6294A314E3108210CA0F6B18A5AD6B525294A4E84A5072146314E0E6316B62D6A5A949525294
    1   2904 002001  1353473280000       11520000 2F9A095B 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF46090020040000000400000006040000060000000725F4E18AB10517CF04F1F0373C733485997564F6B56D6296C5AD8C5A949398C3108410CA0F6B18A5AD6B529294A529425062908214A0E6B18B5AD6B5A94A4A5294
    1   2880 002001  1353484800000       11520000 102D7AA1 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF460000400400000004000000060000000202000006ACEEE2474C2CD9F01EB59971B6D66F6B56B6AD6D5AD8C5A54929483108410CA0E6B16B5A96A5254A4A529521262946314A0E6316B62D6B5294952529524E629483
    1   2904 002001  1353496320000       11520000 E3C536AA 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF468000000400004004000000060800000600000006B26EEF08CD9D00486F1D197376BEE997566E6B94B62D6C5AD8C5A94A318C3108410CA2E6B16B5AD6A5294A525294A0E72908314A0E6B16B62D6A5A94A4A5294A50
s=2 n=0 o=4021506048
s=4 n=0 o=4024627200
mt=000002B5BE4860A0 n=6
    0  43054 000008  1353962610000       45045000 2E496AE1 0000010D8214200802DC72B8FBA457FF0086256BF973440000DF4876840170000003008021E402000067191DF301B20000040010EF0100207F252DF90010000003008151BB0080003FF906BF00070000030000084C00C0400F63A708C008000003000011000060100BFDC9C410022000000300008540700002ECB0FEC0000003
    1   2896 002001  1353507840000       11520000 002FDB88 7FFE8001FC3C7DB277000D3A0009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF460205400400002004000000060800000402000006A599AC347005BC9B74D82344F44EF09626DBF2B7C5A6E7356C62D8D52D8C62529314E5108420CA0E6AD6B5A96A5A5494A5294A4A6294A314A0D6AD6B5AD6A5A929
005003:0000 Failed to save title 3 to file D:/Temporary/MakeMKV/Harry Potter and the Goblet of Fire_t03.mkv
002023:0000 Encountered 4 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
error=0x06031105 count=4 name=Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR
Encountered 81 unclassified errors
error=0x0703004E count=5 name=Internal error - Operation result is incorrect (78)
error=0xC000009C count=18 name=OS error - STATUS_DEVICE_DATA_ERROR
error=0xC00000B5 count=58 name=OS error - {Device Timeout} The specified I/O operation on hs was not completed before the time-out period expired
005004:0080 0 titles saved, 1 failed
Re: Disc reading issues - Disc issue?
Have you tried gently cleaning the disc?
That first error seems like the drive was having trouble reading a spot on the disc.
NGS428
Post by NGS428 »
dcoke22 wrote:
Sun Oct 29, 2023 4:36 pm
Thanks for the reply. I did try cleaning the disk. I have 2 discs that are doing this to me. I’ve cleaned them with no change. The get to about 2.75 gig each and then stop and have similar issues to the log I posted. Both are Harry Potter Blu ray discs.
adambomber
Post by adambomber »
Having a similar issue reading a brand new UHD copy of Solo - a Star Wars Story
