NCIS Season 20 DVDs disks won't rip
peterhocking
Post by peterhocking » Sat Oct 28, 2023 7:13 am
I recently bought Season 20 of NCIS on DVD which is a 6 disk set. The first 4 disks just fine with Makemkv, but the last 2 disks can't be ripped. When I go to open the disks in Makemkv, i get a series of errors & then it only "sees" one of the 4 episodes. I have it set to ignore anything under 20 minutes in length.
Below is the log file output
MakeMKV v1.17.5 win(x64-release) started
Using LibreDrive mode (v06.3 id=7FA2657C7667)
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_04_1.VOB' at offset '0'
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading 'BD-RE HL-DT-ST BD-RE WH16NS60 1.02 KLIK9BI0143' at offset '0'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading 'BD-RE HL-DT-ST BD-RE WH16NS60 1.02 KLIK9BI0143' at offset '959352832'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading 'BD-RE HL-DT-ST BD-RE WH16NS60 1.02 KLIK9BI0143' at offset '941426688'
Title #1 was added (6 cell(s), 0:40:49)
Title #2 (0:43:02) was skipped due to navigation error
Cells 1-1 were removed from title start
Title #3 declared length is 0:34:58 while its real length is 0:00:00 - assuming fake title
Title #4 in broken titleset was skipped
I'm using MakeMKV v1.17.5 under Windows 11. Any ideas on what is causing this?
Re: NCIS Season 20 DVDs disks won't rip
Post by dcoke22 » Sun Oct 29, 2023 4:06 pm
That error often indicates the optical drive was unable to correctly the disc. The standard advice is to gently clean the disc and try again.
htpc_rookie
Post by htpc_rookie » Tue Oct 31, 2023 9:51 pm
I'm pretty sure that I had problems ripping this with my LG drive too. I did manage to recover more episodes after cleaning and repeated attempts. My external Pioneer-based drive didn't have a problem though.
