Av sync errors
RobTi
Av sync errors
#1 Post by RobTi » Sun Oct 29, 2023 12:20 pm
Hi just starting out and getting the above,any help on if this is okay before I rip all my discs. Using 1.12.0 on an old hd dvd player. https://imgur.com/a/JF7f8X7
Re: Av sync errors
#2 Post by dcoke22 » Sun Oct 29, 2023 4:31 pm
See the MakeMKV FAQ.
Also, you should be able to use a much newer version of MakeMKV to rip HD DVDs.
