tjayz
#9061 Post by tjayz » Fri Oct 27, 2023 3:18 am
I'm not sure when it changed, but Emby can now cast P7 DL DT or ST in any container that I tested, TrueHD 7.1 or DTS-HD MA 7.1, direct from the server to the media player via UPnP. When using the UBP-X800m2 which cannot add client apps to it, this makes Emby the only choice. I could never get Jellyfin or Kodi to work with the UBP and was always using Windows Media Player to cast FEL P7 titles with lossless audio. There is now an all in one solution that makes your library look good! Thought I'd share since I learned so much from this thread, been reading it for years on and off. Cheers!
UBP-X800M2 / LG OLED CX / NAD M17 V2i
valington
#9062 Post by valington » Fri Oct 27, 2023 10:48 am
RESET_9999 wrote:
Thu Oct 26, 2023 7:08 pm
The core in a DTS-HD7.1 track is only 5.1 so if you have a 7.1 audio system, DDP may be better.
Hallo Reset my question is if i take mkv 7 profile dolby vision and then muxe it in ts muxer to ts container could i play it in clon oppo in ts container 7 profile dolby vision and do i get true dolby vision like in bdmv container ? Cause my friend tried it and said that this oppotunity don t work
#9063 Post by RESET_9999 » Fri Oct 27, 2023 12:51 pm
Yes,but as noted in the excel sheet in my signature, on the x700/x800m2 and oppo, some ST P7 rip will not work.
Use workflow 4-3 to get a dual track dual layer file and all the rips will work.
ArArdin
STDL mkv --> DTDL mp4
#9064 Post by ArArdin » Fri Oct 27, 2023 12:58 pm
It's been quite a while since using RESET_9999's scripts and I'm somewhat struggling with the current ones. My newbee apologies for asking.
Is it possible to convert a dovi P7 mkv (singletrack duallayer) into a P7 dualtrack-duallayer mp4 file? If so, can someone tell me which steps in what script?
Re: STDL mkv --> DTDL mp4
#9065 Post by RESET_9999 » Fri Oct 27, 2023 12:59 pm
MP4 version of my script and then workflow 4-3
ArArdin
#9066 Post by ArArdin » Fri Oct 27, 2023 1:13 pm
Nice. Went flawless after clearing some path-related issues. Really feel like a blundering novice here.
Thanks a bunch for your quick response :D
ArArdin
mp4 STDL and chapters?
#9067 Post by ArArdin » Fri Oct 27, 2023 1:46 pm
A few questions regarding the options after the first "4" (DoVi Profile 7 Input (MKV/BDMV)) if you don't mind, RESET_9999.
It is possible for P7 mp4 to be STDL (IIRC the old Yusesope tool could do so), where BL and EL+RPU be interleaved in one hevc track. Is there a particular reason to why there's no option to output such STDL mp4?
Another thing is, I've recently learned that chapters can be muxed in mp4. Can you tell me how this is done in case I have a - let's say chapters.txt file - or do I have to add the chapters in mkv first?
Re: mp4 STDL and chapters?
#9068 Post by RESET_9999 » Fri Oct 27, 2023 2:13 pm
the ST-DL P7 workflow is hidden a bit but it's there in workflow 4-1-2. It's only for BDMV or DT-DL input though.
I guess I could let workflow 5 to mux the ST P7 video untouched(right now it convert to p8)
DjObama
#9069 Post by DjObama » Fri Oct 27, 2023 4:58 pm
I have LG B8, your spreadsheet doesn't list support for the B series, however every MEL title has worked so far. I'm getting confused about the FEL titles. So far none has worked for me after converting to ts or m2ts, some dont play some stutter for a bit and stop playing. However with the last movie I decided to follow the 4-3 workflow and created a DT-DL mp4 which plays fine.
My question is: Is it possible that my tv just doesn't play the second (1080p fel) video stream and I see only the BL+RPU on the screen? Or does DT-DL playing in DV mean everything works fine? How can I verify this as an total amateur?
Gatorman
#9070 Post by Gatorman » Fri Oct 27, 2023 7:50 pm
RESET_9999 wrote:
Tue Oct 24, 2023 11:22 pm
if you use the dovi_scripts, it's not too complicated.
automated: workflow 8-6-2
manual (with staxrip or in cli x265.exe):
1. workflow 7-1 in manual mode.
2. edit the avs script: remove the text overlay and uncomment convertbits(10)
3. convert the rpu to p8.
4. encode the avs file just like any HDR video file(with the rpu or inject it after the encode).
Sorry for my ignorance. The first section is was created with the 7-1 Manual option. Is the second section edited correctly for encoding with StaxRip?
LoadPlugin("I:\Working\Dolby-Vision-Tools\tools\DoViBaker_x64.dll")
LoadPlugin("I:\Working\Dolby-Vision-Tools\tools\avs_libplacebo.dll")
LoadPlugin("I:\Working\Dolby-Vision-Tools\tools\dgdecnv_242\DGDecodeNV.dll")
bl = DGSource("I:\Working\Dolby-Vision-Tools\Movie_BL.dgi")
el = DGSource("I:\Working\Dolby-Vision-Tools\Movie_EL.dgi")
SetFilterMTMode("DoViBaker",2)
DoViBaker(bl, el, rpu= "I:\Working\Dolby-Vision-Tools\Movie_RPU_FEL.bin")
# libplacebo_Tonemap(src_csp=1, dst_csp=0, dynamic_peak_detection=true, tone_mapping_function=0, tone_mapping_mode=1)
# ConvertToYUV420(matrix="709")
# SetFilterMTMode("DoViBaker",2) and Prefetch(8) must be removed to use libplacebo
ConvertToYUV420(matrix="2020")
# ConvertBits(10)
# Crop(0, 280, -0, -280)
# Spline36Resize(1920, 1080)
Prefetch(8)
More reasons to collect physical media. Ugoos AM6B+.
#9071 Post by RESET_9999 » Fri Oct 27, 2023 7:52 pm
Yes, the 2018 LG TVs support FEL but indeed, the support in TS/M2TS containers is not great for the Single track rip (makemkv) and the dual track rip will not work.
So the best option for FEL playback on this TV is the MP4 container and DV is processed properly(BL+EL+RPU) as far as I know.
#9072 Post by RESET_9999 » Fri Oct 27, 2023 7:54 pm
You have to uncomment ConvertBits(10) from the avs script or add a bit-depth 10bit conversion in staxrip.
ConvertBits(10)
Prefetch(8)
Gatorman
#9073 Post by Gatorman » Fri Oct 27, 2023 8:26 pm
Since baking in FEL with StaxRip I've been getting validate_metadata errors like these, when adding the converted RPU. Is this normal?
WARNING: L1=0,0,0 metadata at shot: UniqueID = e822cd1d-e184-4959-bd7f-4fcc0f6754fb @[0-43].
WARNING: shot: UniqueID = bc0fa9d6-cce2-4d50-b990-9b3f88a48802 @[175549-175794] contains target trim(s) without a 100-nit, Rec.709 trim.
#9074 Post by RESET_9999 » Fri Oct 27, 2023 8:53 pm
This is the same in the original RPU. The p7 to p8 conversion does not touch the dynamic metadata (L1/L2 etc..)
BTW, the warnings in metafier is not really a problem. Errors on the other hand is a problem.
FYI, in the new Mission Impossible, it looks like the colorist missed the memo about L2 0.025 lift. These shots will most likely result in grey letterbox on devices that ignore L5
And you can clearly see on this video how the trims raise the brightness: https://www.youtube.com/watch?v=Hk6ria8_PFo
WARNING: Positive Level2 lift value at shot: UniqueID = b42d5b72-2b5c-431a-a160-d7204bb67330 @[18280-18325]
WARNING: Positive Level2 lift value at shot: UniqueID = 3cff3948-45b7-4179-9260-51d41aadbdb8 @[18326-18421]
WARNING: Positive Level2 lift value at shot: UniqueID = 64ab0852-6218-435c-ab93-80c821f553c8 @[19192-19290]
WARNING: Positive Level2 lift value at shot: UniqueID = 2b8c89f0-82ae-449f-a2e8-f25cbb26ff19 @[19380-19479]
WARNING: Positive Level2 lift value at shot: UniqueID = 40c08837-aa0e-4eb6-a42c-d4b19fa30530 @[19914-19932]
WARNING: Positive Level2 lift value at shot: UniqueID = 43bb1490-66a7-4b78-b6f4-b2f2d9bbb6a6 @[50546-50583]
WARNING: Positive Level2 lift value at shot: UniqueID = 9819a8e5-d54b-4617-bbf4-555f0da2482b @[201575-201632]
WARNING: Positive Level2 lift value at shot: UniqueID = 9f396c99-2bbc-4546-8be6-341c36b6cde9 @[222752-223708] and frame: 223036 (offset=284)
WARNING: Positive Level2 lift value at shot: UniqueID = 9f396c99-2bbc-4546-8be6-341c36b6cde9 @[222752-223708] and frame: 223037 (offset=285)
WARNING: Positive Level2 lift value at shot: UniqueID = 9f396c99-2bbc-4546-8be6-341c36b6cde9 @[222752-223708] and frame: 223038 (offset=286)
WARNING: Positive Level2 lift value at shot: UniqueID = 9f396c99-2bbc-4546-8be6-341c36b6cde9 @[222752-223708] and frame: 223039 (offset=287)
WARNING: Positive Level2 lift value at shot: UniqueID = 9f396c99-2bbc-4546-8be6-341c36b6cde9 @[222752-223708] and frame: 223040 (offset=288)
WARNING: Positive Level2 lift value at shot: UniqueID = 9f396c99-2bbc-4546-8be6-341c36b6cde9 @[222752-223708] and frame: 223041 (offset=289)
WARNING: Positive Level2 lift value at shot: UniqueID = 9f396c99-2bbc-4546-8be6-341c36b6cde9 @[222752-223708] and frame: 223042 (offset=290)
WARNING: Positive Level2 lift value at shot: UniqueID = 9f396c99-2bbc-4546-8be6-341c36b6cde9 @[222752-223708] and frame: 223043 (offset=291)
WARNING: Positive Level2 lift value at shot: UniqueID = 9f396c99-2bbc-4546-8be6-341c36b6cde9 @[222752-223708] and frame: 223044 (offset=292)
WARNING: Positive Level2 lift value at shot: UniqueID = 9f396c99-2bbc-4546-8be6-341c36b6cde9 @[222752-223708] and frame: 223045 (offset=293)
WARNING: Positive Level2 lift value at shot: UniqueID = 9f396c99-2bbc-4546-8be6-341c36b6cde9 @[222752-223708] and frame: 223046 (offset=294)
WARNING: 17 Shots contain identical Level1 values
WARNING: 15 Shots contain identical Level2 values
Gatorman
#9075 Post by Gatorman » Fri Oct 27, 2023 10:11 pm
Regarding this film, it looks like the MDL of the BL and RPU is .0050/4000 and the MaxCLL is 997 for both. Does the MDL need to be changed to 1/1000, when baking in the FEL with StaxRip? Perhaps the trims take care of this?
BTW, 6-2 is crashing for me when I try to plot HDR.
