Ultimate UHD Drives Flashing Guide Updated 2025
kululu wrote:
Sun Oct 22, 2023 6:29 am
Hello
Anyone can use Pioneer BDR-X13J-S in MKVmaker?Change Rom after can’t use it to rip 4K UHD, Thanks
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR -X13U
Revision: 1.03
Firmware date: 2022-12-12
Bus encryption flags: 18
Highest AACS version: 78
Status: Possible, not yet enabled Drive platform: Pioneer RS9401
Firmware version: ID43
There's a whole thread about recent Pioneer firmware specifically disabling MakeMKV support. At the moment, once a Pioneer drive gets on the recent firmware, you're stuck.
viewtopic.php?f=19&t=30383
trleith
Get Platform Information
Post by trleith »
STOP READ BEFORE FLASHING
IMPORTANT Before you flash:
  • 1. Make sure your Drive was built after 2016 on label or late 2015 if you want to risk it.
    2. Drive Platform MT1959<Most important in makemkv
    3. SVC NS50+ LG only on label for NB drives NB50+
    4. Just because your drive is the same model number does not mean it will work, if you are unsure ask me i offer remote flashing and check everything before i flash.
    5. Dont flash your dive if it does not meet these requirements if you do you will be unable to read all disks and unable to restore without dosflash that does not work on most modern computers
Alrighty then. (tiny bit of reformatting for readability) On Linux (inside Docker)
Note I'm using sdfTool because that's what was already in the Docker image with MakeMKV
It would be possible to put sdf.bin in there. Is it necessary?
root@176acc477e6a:/usr/local/bin# ./sdftool --version
LibDriveIo/SdfTool version: 2.6
root@176acc477e6a:/usr/local/bin# ./sdftool  --drive=dev_21:2 --info
SDF.bin version: 0x0097
Drive Tool SDF present
Drive Specific SDF present
[Drive Specific SDF] Embedded Info Strings:
8000:LibreDrive Information
8013:Status
8109:Possible (with patched firmware)
[b][i]8001:Drive platform :MT1959[/i][/b]
8010:Harware support
8100:Yes
8011:Firmware support
8101:No
8002:Firmware type
8108:Original (patched version available)
8003:Firmware version:1.05
8005:DVD all regions
8006:BD raw data read
8007:BD raw metadata read
8009:Unrestricted read speed
[Drive Specific SDF] Embedded Status Message:
8096:LibreDrive mode for this drive is only possible with firmware upgrade (id=%1):36338EC9581D
Identification SDF present
8013:Status
[Identification SDF] Drive autodetect string:mtk:[b][i]19:59[/i][/b]:JB8 :HL-DT-ST:BD-RE  WH16NS40 1.05:N000900:-
WH16NS40 on any Firmware directly to > WH16NS60 1.02MK
So, apparently I can do a flash to enable LibreDrive, and even though the WH16NS40 is a BDXL drive, doing this will fix the Sleep Bug because WH16NS60 is a UHD "official" drive.
First, save the existing firmware
./sdftool f --device=dev_21:2 dump --out=./HL-DT-ST-BD-RE _WH16NS40-1.05-N000900.bin
Then flash the drive
./sdftool f --device=dev_21:2 [b]enc[/b] --in=./HL-DT-ST-BD-RE_WH16NS60-1.03-NM00600-212005081010.bin <<== from the mk-firmware-pack-20200720
The command "enc" I am guessing at from examples. Neither is mentioned in sdftool --help
Have I got all this correct?
Thanks,
t
n7qpp
WP50NB40 - I think someone have been here
Post by n7qpp »
I just purchased a WP50NB40 from Amazon Warehouse. MKV shows this about the drive:
OS device name: I:
Product: BD-RE BU40N
Revision: 1.00
Serial number: SIK04N1UJ4914
Firmware date: 2116-12-20 15:28
Firmware version: 1.00
BD raw metadata read: Ye
Unrestricted read speed: Yes[/list][/list]
The sticker shows:
S/N 301HSXJ016986
ROM VER: 1.03
Joe (new to the broad)
Re: WP50NB40 - I think someone have been here
n7qpp wrote:
Thu Oct 26, 2023 8:14 pm
OS device name: I:
Revision: 1.00
The sticker shows:
S/N 301HSXJ016986
ROM VER: 1.03
It's obviously not brand new as it's already been cross-flashed!!
Have you tried a UHD disc yet?
MartyMcNuts wrote:
Thu Oct 26, 2023 9:41 pm
OS device name: I:
Revision: 1.00
The sticker shows:
S/N 301HSXJ016986
ROM VER: 1.03
lol i wonder who returned that
n7qpp
Post by n7qpp »
Would there be a need to change the current firmware version? Sorry have not have the time to read all the good info yet
Joe
n7qpp wrote:
Fri Oct 27, 2023 2:41 am
Joe
Leave it as is
You got one of my reject drives
n7qpp
Post by n7qpp »
Interesting what was the reason for the rejection? I cam always return it
Joe
n7qpp wrote:
Sat Oct 28, 2023 1:54 pm
Joe
Failed my testing but I test with hard to read discs so it might be fine for you or you might find out why it was sent back
WandStick9898
Post by WandStick9898 »
I just got this Archgon MD-8107S-U3-UHD :) drive from Amazon:
OS device name: E:
Revision: 1.02
Serial number:
Bus encryption flags: 1F
Highest AACS version: 77
Harware support: Yes
Firmware support: No
Firmware version: 1.02
I'm on Windows 11 - connected from USB 3.0 to USB-C, but can switch cables if that matters.
Following this: viewtopic.php?p=74718#p74718 post,
I understand that I need to:
1 - Download the "The all you need firmware pack.zip\The all you need firmware pack\LG slim BU40N\HL_DT... 1.03...bin" [DONE]
2 - Download the latest GUI SDF tool from here: (viewtopic.php?f=16&t=22896).
In this post, I scrolled down to the MediaFire link to the latest tool, and am getting a "Can't reach that page".
The firmware pack came down just fine, but that one I can't seem to grab. Has the link changed and referenced in a different post?
With this drive, can I simply use the built in Powershell MKV Flasher instructions found here:
https://www.youtube.com/watch?v=jyQV1aPlbow
Thanks in advance for any advice!
Post by d00zah »
WandStick9898 wrote:
Wed Nov 01, 2023 4:07 pm
SDFtoolFlasher link is active for me... something (AV, etc) blocking?
https://www.mediafire.com/file/rak1mk0p ... 9.zip/file
WandStick9898
d00zah wrote:
Wed Nov 01, 2023 4:18 pm
My bad - it must have been a local firewall thing. Got the file fine from my phone. Thanks for the quick response.
WandStick9898
Thanks for all the help - and it appears to have flashed successfully. I tried a couple test discs (an "older" UHD disc (The Fifth Element) and a "newer" one "All Quiet on the Western Front"). Both are giving "failed to open disc" errors.
Here's the current MakeMKV info:
OS device name: E:
Revision: 1.03
Serial number: MO1M#######
Firmware version: 1.03
Disc Information
Label: FIFTH_ELEMENT_THE
Timestamp: 2017-05-17 14:13:04
Protection: AACS2.0/C v61
Data capacity: 60.37 Gb
Disc type: BD-ROM UHD
Number of layers: 2
Bus encryption flags: 80
MakeMKV v1.17.5 win(x64-release) started
Downloading latest SDF to C:\Users\user/.MakeMKV ...
Automatic SDF downloading is disabled or failed.
Using LibreDrive mode (v06.3 id=866A98CB9C4E)
Downloading latest HK to C:\Users\user/.MakeMKV ...
Saved AACS dump file as C:\Users\user/.MakeMKV/MKB20_v61_Fifth_Element_CBBF.tgz
My MakeMKV is 1.17.5 - updated this week. Did I miss a step? Eg, do I need to manually download the SDF and HK files?
Sorry if I'm being dense.
Post by d00zah »
Wed Nov 01, 2023 5:35 pm
Source: Fixing Volume Key is Unknown
Step one: Send the TGZ file to svq@makemkv.com so that the program's author can create a decryption key for it.
Step two: Wait a few days for the key to be created and made available in the official Hash Key file that MakeMKV downloads when needed. You won't get an email saying this has happened; you need to retry the rip occasionally.
OK, you've been waiting for a while, and no success. Worse, you see where other people are able to rip the disk you cannot, but it still defies you...
see source
WandStick9898
d00zah wrote:
Wed Nov 01, 2023 6:01 pm
Ah, I wasn't aware of that post, sorry for not searching better. Looks like Geoblocking is my issue. I will whitelist that HK IP address.
Thanks again d00zah - you're the best.
