n7qpp
WP50NB40 - I think someone have been here
Post by n7qpp » Thu Oct 26, 2023 8:14 pm
I just purchased a WP50NB40 from Amazon Warehouse. MKV shows this about the drive:
OS device name: I:
Product: BD-RE BU40N
Revision: 1.00
Serial number: SIK04N1UJ4914
Firmware date: 2116-12-20 15:28
Firmware version: 1.00
BD raw metadata read: Ye
Unrestricted read speed: Yes[/list][/list]
The sticker shows:
S/N 301HSXJ016986
ROM VER: 1.03
Joe (new to the broad)
Re: WP50NB40 - I think someone have been here
Post by MartyMcNuts » Thu Oct 26, 2023 9:41 pm
n7qpp wrote: Thu Oct 26, 2023 8:14 pm I just purchased a WP50NB40 from Amazon Warehouse. MKV shows this about the drive:
OS device name: I:
Revision: 1.00
The sticker shows:
S/N 301HSXJ016986
ROM VER: 1.03
It's obviously not brand new as it's already been cross-flashed!!
Have you tried a UHD disc yet?
Post by Billycar11 » Thu Oct 26, 2023 10:38 pm
MartyMcNuts wrote: Thu Oct 26, 2023 9:41 pm
OS device name: I:
Revision: 1.00
The sticker shows:
S/N 301HSXJ016986
ROM VER: 1.03
lol i wonder who returned that
n7qpp
Post by n7qpp » Fri Oct 27, 2023 2:41 am
Would there be a need to change the current firmware version? Sorry have not have the time to read all the good info yet
Joe
Post by Billycar11 » Fri Oct 27, 2023 1:16 pm
n7qpp wrote: Fri Oct 27, 2023 2:41 am Would there be a need to change the current firmware version? Sorry have not have the time to read all the good info yet
Joe
Leave it as is
You got one of my reject drives
n7qpp
Post by n7qpp » Sat Oct 28, 2023 1:54 pm
Interesting what was the reason for the rejection? I cam always return it
Joe
Post by Billycar11 » Sat Oct 28, 2023 2:15 pm
n7qpp wrote: Sat Oct 28, 2023 1:54 pm Interesting what was the reason for the rejection? I cam always return it
Joe
Failed my testing but I test with hard to read discs so it might be fine for you or you might find out why it was sent back
WandStick9898
Post by WandStick9898 » Wed Nov 01, 2023 4:07 pm
I just got this Archgon MD-8107S-U3-UHD :) drive from Amazon:
OS device name: E:
Revision: 1.02
Serial number:
Bus encryption flags: 1F
Highest AACS version: 77
Harware support: Yes
Firmware support: No
Firmware version: 1.02
I'm on Windows 11 - connected from USB 3.0 to USB-C, but can switch cables if that matters.
Following this: viewtopic.php?p=74718#p74718 post,
I understand that I need to:
1 - Download the "The all you need firmware pack.zip\The all you need firmware pack\LG slim BU40N\HL_DT... 1.03...bin" [DONE]
2 - Download the latest GUI SDF tool from here: (viewtopic.php?f=16&t=22896).
In this post, I scrolled down to the MediaFire link to the latest tool, and am getting a "Can't reach that page".
The firmware pack came down just fine, but that one I can't seem to grab. Has the link changed and referenced in a different post?
With this drive, can I simply use the built in Powershell MKV Flasher instructions found here:
https://www.youtube.com/watch?v=jyQV1aPlbow
Thanks in advance for any advice!
Post by d00zah » Wed Nov 01, 2023 4:18 pm
WandStick9898 wrote: Wed Nov 01, 2023 4:07 pm ...
SDFtoolFlasher link is active for me... something (AV, etc) blocking?
https://www.mediafire.com/file/rak1mk0p ... 9.zip/file
WandStick9898
Post by WandStick9898 » Wed Nov 01, 2023 4:47 pm
d00zah wrote: Wed Nov 01, 2023 4:18 pm
My bad - it must have been a local firewall thing. Got the file fine from my phone. Thanks for the quick response.
WandStick9898
Post by WandStick9898 » Wed Nov 01, 2023 5:35 pm
Thanks for all the help - and it appears to have flashed successfully. I tried a couple test discs (an "older" UHD disc (The Fifth Element) and a "newer" one "All Quiet on the Western Front"). Both are giving "failed to open disc" errors.
Here's the current MakeMKV info:
OS device name: E:
Revision: 1.03
Serial number: MO1M#######
Firmware version: 1.03
Disc Information
Label: FIFTH_ELEMENT_THE
Timestamp: 2017-05-17 14:13:04
Protection: AACS2.0/C v61
Data capacity: 60.37 Gb
Disc type: BD-ROM UHD
Number of layers: 2
Bus encryption flags: 80
MakeMKV v1.17.5 win(x64-release) started
Downloading latest SDF to C:\Users\user/.MakeMKV ...
Automatic SDF downloading is disabled or failed.
Using LibreDrive mode (v06.3 id=866A98CB9C4E)
Downloading latest HK to C:\Users\user/.MakeMKV ...
Saved AACS dump file as C:\Users\user/.MakeMKV/MKB20_v61_Fifth_Element_CBBF.tgz
My MakeMKV is 1.17.5 - updated this week. Did I miss a step? Eg, do I need to manually download the SDF and HK files?
Sorry if I'm being dense.
Post by d00zah » Wed Nov 01, 2023 6:01 pm
WandStick9898 wrote: Wed Nov 01, 2023 5:35 pm ...
Source: Fixing Volume Key is Unknown
Step one: Send the TGZ file to svq@makemkv.com so that the program's author can create a decryption key for it.
Step two: Wait a few days for the key to be created and made available in the official Hash Key file that MakeMKV downloads when needed. You won't get an email saying this has happened; you need to retry the rip occasionally.
OK, you've been waiting for a while, and no success. Worse, you see where other people are able to rip the disk you cannot, but it still defies you...
see source
WandStick9898
Post by WandStick9898 » Wed Nov 01, 2023 7:03 pm
d00zah wrote: Wed Nov 01, 2023 6:01 pm
Ah, I wasn't aware of that post, sorry for not searching better. Looks like Geoblocking is my issue. I will whitelist that HK IP address.
Thanks again d00zah - you're the best.
Post by d00zah » Wed Nov 01, 2023 7:32 pm
WandStick9898 wrote: Wed Nov 01, 2023 7:03 pm
Happy to help. Just in case the problem persists, also check out:
hkdata.crabdance.com or hkdata.fairuse.org not found
WandStick9898
Post by WandStick9898 » Wed Nov 01, 2023 8:00 pm
d00zah wrote: Wed Nov 01, 2023 7:32 pm
Thanks for the additional links. Just to confirm, removing the country specific geo-blocking did the trick!
